Question about Lasko 5540 Ceramic Compact Heater
Themostat sending signal scr receiving signal green light is on but heating doesnt come on thanks joe
The DELL E172FPb LCD Monitor (switch light flicks green)scr black
You need to open it up and inspect the componente inside, look at the fuse and the transistors in the inverter circuits first, also look for sign of over heating on the board, see pictures here for the guide: http://s807.photobucket.com/home/budm/allalbums
Mar 20, 2010 | Dell E173FP 17" LCD Monitor
Drayton Digistat SCR thermostat not working.
Go online to www.cheapboilers.com who deal with this type of boiler. It would be very difficult to troubleshoot this boiler with the information supplied. I hope this will be of some help to you.
Sincerely, Shastalaker7
They should also be able to get you a manual for your thermostat.
Oct 27, 2009 | Heating & Cooling
It is over heating and i can't find the temperatre gauge under the hood...
first of all check the radiator for leak or blockage. make sure the coolant is fresh. follow th eupper radiator hosr to the emgine block. there should be 3 bolts attached the themostat housing. take the themostat out and put it with hot water, maks sure the opens. the temperture sending unit should be directly under the themostat. msot likely the themostat is cause or the problem. unless the temperture gage is not reading correctly.
Jun 09, 2009 | 1998 Mercury Mystique
I have a digistat scr with a flashing red light and no heating there is nothing wrong with the batteries, this only occured after a poweer cut.
Try this first before condeming the unit.
1. Turn off the power supply to the Digistat SCR (receiver unit)
and leave for 5 seconds.
2. Turn on power to SCR unit and check red light is on.
3. Press override button No.2 and check the green light comes
on and boiler fires.
4. Press & hold down button No.1 (Keep depressed), then
press No.2 and keep depressed. {The Red LED light will flash
a couple of times and then it will go out}
5. Now release both the buttons – {the two LED lights should
come back on}
6. Get the Digistat+2RF/+3RF unit and stand two metres away
from the SCR unit with the Digistat+2RF/+3RF unit in your hand.
7. Remove the battery cover and fit the batteries.
8. The Red LED light on the SCR will now flash for approx. 7
seconds.
9. This confirms that the radio signal is being sent and
received.
10. The Digistat+2RF/+3RF and the SCR are now successfully
linked by a dedicated RF address.
Mar 21, 2009 | Water Heaters
Pilot light goes out when i turn on heat. pilot light is blue flame lights good but when try to turn on heat it clicks and goes out therefor heat doesnt come on
How long do you leave the pilot on before you turn on heat. The thermal pile will take 3-5 minutes to heat up before it will send a signal to gas valve. If thermal pile doesn't send signal then gas valve closes. You might need a new thermal pile.
Jan 18, 2009 | Rinnai Toyostove Direct Vent Heater:...
My Drayton Digistat RF3 boiler control is not working. The thermostat module indicates it is sending a signal, but the unit beside the boiler has a red alarm LED lit. I've removed the batteries and turned...
I found that this solved the problem hope it helps you too.
come back on}
seconds.
received.
Nov 04, 2008 | Heating & Cooling
Shark professional model 505.
It sounds like the themostat inside the unit is broken. The only solution to fix the unit is to send it to the manufacturer for repair.
I'm unsure of the cost for the repair but it might be cheaper if the unit is older to throw it away and buy a new steamer.
Sep 02, 2008 | Euro-Pro Shark SC-505 Handheld Steam...
Pioneer PDP-435PG
I buy receiver of the plasma pdp 435pd my e-mail it is sergiofleitas@yahoo.com.ar
Apr 20, 2008 | Televison & Video
Wireless light is green but i don't receive any signal on my laptop?
Check to see if the SSID is being broadcast. That could probably you be your problem.
Thanks,
Jan 02, 2008 | Actiontec GT701WG Router (actiongt701wg)
Lasko 5540 Ceramic Compact Heater Logo
21 people viewed this question
Top Lasko Heating & Cooling Experts
Steve
Steve Oakes
Mack Baxter
Are you a Lasko Heating and Cooling Expert? Answer questions, earn points and help others
