Question about Cycling
Kazuma jaguar fuse box
No headlamps light when switched on
5 Suggested Answers
RixsFixes
  • 2200 Answers
SOURCE: headlamps,radio,tailights and dashlights all died
Have you checked the relays under the hood as well as the fuses inside the car?
This problem is caused by something more than a fuse. If the relays all check out fine then a bad earth or faulty wiring harness is suspect.
Have you done any electrical work to the car recently? e.g fitted an aftermarket stereo or anything?
If you check the relays and find these are not the cause, please supply the exact make, model and year of the vehicle along with any other detail you can give.
Thanks for using FixYa.
Posted on Nov 19, 2010
alicantecoli
  • 22156 Answers
SOURCE: jaguar x type 2.0 diesel,
have you checked the bulbs first ?? they go long before any fuse ,their are relay units behind the headlights as well on this vehicle ,If you dont know what to do then please ask a local mechanic to do it for you ,these cars are not to be messed around with they dont like it .polish it and clean seats with leather cream and they never go wrong mine hasnt and i have had it 4 years now .ps they like the chrome buffed up as well
Posted on Jan 03, 2011
Inside the engine compartment, behind your battery is the fuse box. Open your plastic cover and on the underside you will see the fuse schematic. Look for F16. That is the fuse for your left head lamp. 20 amp yellow fuse.
Posted on Jan 05, 2011
  • 233 Answers
SOURCE: have a 2003 jaguar s-type r, lights won't work and won't do anything from switch. any help.
Hi have you check the accy rely its in that circuit bench test it
Posted on Jan 11, 2016
Where is the passenger side low beam fuse located on a 2006 Nissan Altima
Low Beam Operation With the lighting switch in 2ND position, the BCM receives input requesting the headlamps to illuminate. This input is communicated to the IPDM E/R across the CAN communication lines. The CPU of the IPDM E/R controls the headlamp low relay coil. When energized, this relay directs power ? through 15A fuse (No. 36, located in the IPDM E/R) ? through IPDM E/R terminal 20 ? to headlamp RH terminal 1, and ? through 15A fuse (No. 45, located in the IPDM E/R) ? through IPDM E/R terminal 30 ? to headlamp LH terminal 1. Ground is supplied ? to headlamp RH terminal 2 ? to headlamp LH terminal 2 ? through grounds E15 and E24. With power and ground supplied, low beam headlamps illuminate.
IPDM E/R - fuse box E/R -- engine room , under hood fuse box .
System Description EKS008LH Control of the headlamp system operation is dependent upon the position of the combination switch (lighting switch). When the lighting switch is placed in the 2ND position, the BCM (body control module) receives input requesting the headlamps (and tail lamps) to illuminate. This input is communicated to the IPDM E/R (intelligent power distribution module engine room) across the CAN communication lines. The CPU (central processing unit) of the IPDM E/R controls the headlamp high and headlamp low relay coils. When energized, these relays direct power to the respective headlamps, which then illuminate. OUTLINE Power is supplied at all times ? to headlamp high relay, located in the IPDM E/R, and ? to headlamp low relay, located in the IPDM E/R, and ? through 50A fusible link (letter f , located in the fuse and fusible link box) ? to BCM terminal 70. With the ignition switch in the ON or START position, power is supplied ? through 10A fuse [No. 1, located in the fuse block (J/B)] ? to BCM terminal 38. With the ignition switch in the ACC or ON position, power is supplied ? through 10A fuse [No. 6, located in the fuse block (J/B)] ? to BCM terminal 11. Ground is supplied
https://carmanuals2.com/brand/nissan/altima-2006-4924
May 05, 2017 | Nissan Cars & Trucks
2005 merc grand marquis Headlights keep blowing a fuse
Does your Grand Marquis have head lamps with auto lamps ? Which fuse keeps blowing ? Could be a shorted LCM - lighting control module ?
Lighting Control Module (LCM)
The LCM eliminates the electronic interference and heat associated with the thermoelectric devices used previously. The LCM is a microprocessor-based module that controls several vehicle subsystems. It responds to electrical input signals from various switches, sensors, and external modules..
Visual Inspection Chart Mechanical Electrical
  • Headlamp switch
  • Central junction box (CJB) fuse(s).
    • 1 (15A)
    • 9 (20A)
    • 26 (10A)
    • 15 (7.5A)
    • 7 (10A)
  • Headlamp bulb
  • Circuitry
  • Headlamp switch
  • Lighting control module (LCM)
  • Underhood power distribution box (PDB)
    • F104 (40A)
    • F01 (20A)
    • F02 (25A)
Feb 12, 2017 | Cars & Trucks
I HAVE NO HEAD LIGHTS i HAVE A 2000 Grand am I have parking lights and tail lights
No headlamps , low or high beam ? Does it have DRL - daytime running lights an automatic headlamp control ? Have you check the headlamp fuse's in the under hood fuse box ? Do you know how to do basic electrical testing ? There are videos on you tube , also google automotive electrical testing . Find free wiring diagrams at http://bbbind.com/free_tsb.html , get yourself a DVOM - digital volt ohm meter . Without testing the headlamp electrical circuit It would be any ones guess . Could have a bad headlamp switch , a bad dimmer switch , electrical wiring problem , a problem in the power distribution box etc...
Nov 13, 2016 | Pontiac Grand Am Cars & Trucks
2003 ford focus having problem with lights tail lights license plate light reverse lights have blinkers stop lights hazard. Funny thing the fuse they say is the one for license plate lamp
Fuse F2.62 - 7.5 amp , location central junction box . is this the one you checked for license plate lights ? This fuse is powered by the headlamp switch , park or headlamp position . Fuse F2.30 - 10amp powers headlamp switch , location central junction box .
Nov 02, 2016 | Ford Cars & Trucks
Where is the fuse located for the daytime running lights on a 2005 Chev Siveraado?
It is located in the underhood fuse/relay box , marked DRL 10 amp fuse ! Also if that is good check the DRL relay in the same fuse/relay box .Your light sensor could also be bad .
The daytime running lamps (DRL) will operate when the ignition switch is in the RUN position, for automatic transmissions (A/T), the gear selector is not in the PARK position, the headlamp switch is in the AUTO position, and for manual transmissions (M/T), the park brake is released. When these conditions have been met and the ambient light sensor indicates daytime conditions, the DRL will illuminate. The ambient light sensor is a light sensitive transistor that varies its voltage signal to the body control module (BCM) in response to changes to the outside (ambient) light level. When the BCM receives this signal it will either turn on the DRL or the headlamps for auto headlamp operation. Any function or condition that turns on the headlights will cancel the daytime running lamps operation. The DRL can be manually turned OFF by depressing the AHL/DRL switch in the headlamp switch
Do you know that on inside of fuse box lid it shows what fuse is what .
Feb 01, 2016 | 2005 Chevrolet Silverado
Where's headlight relay @ on a 2010 ford fusion 2.5
There is no relay for low beams , the ( SJB) smart junction box , a control module an fuse / relay center in one.
When the SJB receives an input requesting the headlamps on, the SJB supplies voltage to the low beam and high beam bulbs as necessary.
The smart junction box (SJB) monitors the headlamp switch position by sending voltage reference signals on multiple circuits to the headlamp switch. At any given time, one of the signal circuits is routed to ground. If the SJB does not detect any of the inputs to the headlamp switch is active (routed to ground) for 5 seconds, the SJB turns on the exterior lights and keeps them on for 10 minutes after the ignition switch is turned off (or 10 minutes from the time the SJB does not detect any headlamp switch input if the ignition switch was already off). If the SJB detects multiple circuits short to ground, the SJB implements a planned strategy depending on the multiple inputs received. If either of these situations occur, the SJB should NOT be ruled immediately as being at fault. This is normal behavior of the SJB design as it has detected a fault with the inputs from the headlamp switch.
  • Headlamp switch
  • Multifunction switch
  • Headlamp assembly
  • Battery junction box (BJB) fuse(s):
    • 19 (40A) (low beams)
    • 26 (15A) (LH high intensity discharge [HID] headlamp)
    • 27 (15A) (RH HID headlamp)
  • Smart junction box (SJB) fuse 11 (15A) (high beams)
  • Ballast
  • SJB
  • Bulb(s)
  • Circuitry
Jun 20, 2015 | Ford Cars & Trucks
Jaguar x type 2.0 diesel 2004, which fuses are for the front left headlamps and where are they located engine compartment or glove box what amp and what number fuse, outside front headlamp wont come on...
Jan 03, 2011 | 2004 Jaguar X-Type
Headlights dont work, but park lights and signal lights do. all fuses in passenger kickpannel are good. Is there anoyher fuse box.
there should be another fuse / relay box under the hood - the headlamps will probably have a fuse and a relay. if the fuse is ok - try swapping the headlamp relay with another in the box - if all is ok start looking at the headlamp and or highbeam switches
Oct 24, 2009 | 1998 Jeep Grand Cherokee
Headlights do not turn on at the light switch.
manual headlamps
  • Headlamp switch
  • Central junction box (CJB) fuse:
    • 7 (30A)
    • 30 (15A)
    • 46 (10A)
    • 47 (10A)
  • Circuitry
  • Headlamp bulbs
  • Daytime running lamp (DRL) relay No.1
Autolamps
  • Headlamp switch
  • Central junction box (CJB) fuses:
    • 19 (5A)
    • 56 (30A)
  • Circuitry
  • Headlamp bulb
  • Daytime running lamps (DRL) full relay No.1 (if equipped)
  • Vehicle security module
  • Photocell
If autolamp system, Vehicle security module has a headlamp rela inside of it. under left side of dash.
May 26, 2009 | 2002 Ford F250 Super Duty SuperCab
My headlights dont work,.all other lights are fine though,.is it the fuses or the bulbs? im not sure what fuses they would be,.there seem to be different ones for the same thing
do your flash to pass lamps light when you pull the stalk towards you? If yes, the bulbs are ok.
Do the hig beams work?
Your headlamps have sepaerate fuses for each headlamp and you have a low beam relay and a high beam relay under the hood in the black box.
If everything is out, I suspect a bad headlamp switch.
Check car-part.com and look on page with * for cheapest price.
Your owner manual will identify fuses & relays.
PS, You did not recently instal high current bulbs did you? If yes, put originals back in.
HEADLAMPS
The voltage is supplied to the lamp switch through a fuse. This fuse is located in the central junction box in the left-hand footwell.
When the headlamps are switched on, a voltage is supplied to the high beam/low beam switch and to the low beam relay. The relay for the low beam is located in the battery junction box (BJB) in the engine compartment.
If the high beam/low beam switch is set to "low beam", then a voltage is supplied through the low beam relay to the low beam part of the headlamp assembly. The left and right-hand low beams are fused separately. The fuses are located in the battery junction box (BJB) in the engine compartment.
If the high beam/low beam switch is set to "high beam", then a voltage is supplied through the high beam relay to the high beam part of the headlamp assembly. The left and right-hand high beams are fused separately. The fuses are located in the battery junction box (BJB) in the engine compartment.
Lamp Switch
Removal
  1. s2y~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Disconnect the battery ground cable. For additional information, refer to Section 414-01 .
    Remove the lower driver's side footwell trim.
  1. Detach the lamp switch bezel.
    • Remove two screws.
  1. Remove the light switch.
    • Remove three screws.
    • Disconnect the electrical connector
Feb 23, 2009 | 2005 Ford Focus
Cycling Logo
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
