Question about Miele Novotronic T230C Electric Dryer
No heat out Miele T430 - Miele Novotronic T230C Electric Dryer
I have a miele novotronic dryer t430 have power when door closed wont start I get one click and door opens on its own
-Possibly door switch is faulty or screw that hole the switch is too lose. Check & tight it or replace.
-Att! Make sure disconnect power before work on!!!
Good Luck
mai
Sep 19, 2014 | Dryers
Miele tumble dryer Novotronic T430 door keeps popping open why
Clean all filters on machine this will sort the problem out .
Jun 29, 2014 | Miele Dryers
The dooron my T430 keeps poping open for no reason- even when empty?
Thank you so much. My family is happy the heater is working again-
Kind regards from Germany
Feb 13, 2013 | Miele Novotronic T230C Electric Dryer
No heat when drying
I have a Miele WT2780 where the fan motor stops spinning. This will stop the dryer from working even though the element heats up. The failure of the fan will not blow the air across the heating element and thus into the drum. New motors fitted are around £400 min. I am never going to buy another Miele - mine failed after 6yrs.
Another problem is the thermostat can trip. This is a small button inside the machine (TURN OFF MAINS ELECTRIC AND UNPLUG FROM WALL then remove the lid) on the right hand side of the alloy centre channel at the top. It has two wires connected to the switch and in the centre there is a small black button. Press it firmly and it will heat up again. If this keeps tripping then the air duct could be blocked with fluff. This is my next task as mine now trips more frequently so will post back here with instructions.
Update 12/10/16 - problem returned so dismantled top of air duct having removed the lid - tight torx screws - inside chamber was full of fluff. Removed and cleaned - all good now!.
Jan 04, 2013 | Miele WT 2780 Front Load Washer
How can i print duplex with two pages per sheet without having one page up and the other is down plz help thanks
If the model number of your printer is T430, this model does not have integrated duplex on paper handling standard, no duplex features.
However, a similar printer model T430d or T430dn has integrated duplex on paper handling standard, it means the printer is capable in printing duplex. Please find the link below to check printer specs for more information.
T430d - http://bit.ly/n65FdK
T430 - http://bit.ly/nWpAzX
To display more information on the specs, just click on the link on the lower right view more spec.
For further assistance, please contact Lexmark Technical Support.
Jul 15, 2011 | Lexmark T430 Laser Printer
THE POWER CLICK WHEN I PLUG IN THE T430 LEXMARK PRINTER
1.change power cable .
2. or check its power supply .(Technical Job)
Jun 10, 2009 | Lexmark T430 Laser Printer
Open Questions:
See all Miele Novotronic T230C Electric Dryer Questions
Miele Novotronic T230C Electric Dryer Logo
32 people viewed this question
Top Miele Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
