Question about eMachines Computers & Internet
The best way to clean computer
Just want to clean what needs to be cleaned to keep computer running better
  • eMachines Master
  • 17,322 Answers
Leave it plugged in to eliminate static discharge, take the covers off and use a small brush and a vacuum to clean out all the dust that is on the heat sinks on the CPU and the power supply. Clean the fans and the motherboard.
Posted on Feb 09, 2014
Testimonial: "ty so much. it really needed it"
Tip
Computer Care
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} How to Save Money with Preventive Computer Care
The most important activity that you as a computer user can do is to keep your computer as clean as possible. Your system's user guide is the best source to find specific information about how to clean your system's outer components; but here are some basic tips you should always follow.
Computers are an everyday part of life in the modern world. However, computers require special attention and care in order for them to function properly and to operate safely. Here are some basic guidelines to help you maintain your computer equipment and to keep your equipment functioning for a long time. After all, keeping your equipment running will save you money.
Prevention to be taken on your computer
  • Keep computer equipment away from direct sunlight to prevent overheating.
  • Keep computer equipment away from direct exposure to water or humidity to prevent damage.
  • Keep computer equipment in a clean and dust free area.
  • Always use surge protectors to prevent electrical surge damage to your system.
  • Place an anti-static mat in the area where you are operating your computer to eliminate or prevent anti-static damage to your system.
  • Have your system's interior cleaned at least once every year to keep it running smoothly and to protect your investment.
Things to be cautioned about while operating your computer.
  1. NEVER eat or drink while operating your computer. Food crumbs can easily damage your computer.
  2. NEVER place an open container containing water on or near your computer to avoid electrical shock.
  3. NEVER use your computer's keyboard with dirty or sticky hands.
  4. NEVER allow your pets near your computer. Dust and hairballs can accumulate inside the computer's case and cause your system to overheat.
  5. YOU SHOULD NEVER spray any type of cleaner into your computer's air vents or you could damage your system.
Computer maintenance
Basic computer maintenance should be part of your regular routine. Keeping your computer dust and dirt free, will guarantee that your computer will last and will give you years of reliable performance. Please consult your user's guide for more specific maintenance practices and intervals.
How to clean your computer system
Computer systems require cleaning of internal parts especially when used outside of a clean environment. However, only an authorized technician should open the computer case and clean sensitive electronic components. Consult your user guide to determine the best interval for internal cleaning and take your computer to a certified technician.
Monitor screen
Your computer monitor is likely to be the component that will require the most attention, because computer monitors tend to get dirty from regular use and from dust. To clean your computer monitor or LCD, you can use special chemicals design to clean computer monitors without damaging them.
To clean your computer's screen you can use OPTECH CTR Screen Care. This special cleaner is an anti-static cleaner and coating which safely removes fingerprints and smudges from computer display screens. This cleaner also leaves the surface treated with an invisible dust repellent film, which contains an optical ingredient which fills-in minute scratches eliminating surface distortion and reducing eye fatigue.
How to apply a computer screen cleaner
First, NEVER spray the cleaner directly onto your computer. Instead, spray a lint-free cloth lightly with the computer screen cleaner, and then clean your screen. Be sure to hold the cloth away from your computer when spraying the cleaner to the cloth.
Keyboard maintenance
Dirt and other debris can fall or accumulate between the keys and cause damage or prevent the keys from functioning properly. To clean your computer's keyboard you must use either canned air/gas or a small computer-specific vacuum cleaner. NEVER apply any cleaner or liquid directly to your keyboard. If the keys are dirty, use a lint-free cloth that has been sprayed with computer cleaner to lightly and carefully clean your computer's keyboard. DO NOT clean your computer while the computer is operating, and avoid using your computer till the cleaner has dissipated to avoid possible damage to your equipment. Consult your user's guide for precise instructions on your particular machine.
Case/Tower maintenance
Your computer case will require maintenance. You should remove dust and grime from your computer's air vents and your computer's case. ALWAYS use canned air/gas to clean your computer's vents or air intakes. Canned air/gas cleaners are idea for cleaning air vents, keyboards, disk drives and computer case crevices. The exterior of your computer's case can be cleaned with a lint-free cloth sprayed with an anti-static computer cleaner. When in doubt about how to clean your computer system, ALWAYS consult your user manual or call your system's technical support department.
Safe and clean computing will save you money!
Following these basic computer care guidelines should help you to take good care of your computer system, and keep it running for years. Preventive maintenance will keep your system from having problems and will save you money in the long run. For specific questions about your particular system, you should ALWAYS check your user guide or contact technical support.
on Feb 27, 2010 | Computers & Internet
Can you show me how to fix it on my 2015 taotao so it will run better
Hello David,
There isn't much you can actually do for it,, just keep the air filter clean and treated, keep a fresh spark plug in it.. its about the best it will be like it is..
Jun 15, 2015 | TaoTao Manufacturer Inc Kids Skateboard &...
My dell computer keeps shutting down every 5 min or so. I cleaned th fan and still the problem happens. I bought this almost 4 and a half years ago.
You may have cleaned the fan but have you cleaned the metal cooler (heat sink) under the fan? Its better to remove the fan from the heat sink and hoover it out, then refit the clean fan. Also hoover out the power supply vents too. Also make sure any case vents are clear too. If you think overheating is the problem then run the pc with the case open and if it runs ok then overheating is the problem.
Jul 10, 2011 | Dell Inspiron 1525 Laptop
When printing clip art, photos, etc. my graphics constantly have a series of evenly spaced lines crossing the art work. I can't find any printer head cleaning prompts. Even when I replace the ink...
Hmm, nozzles are blocked. Try Isopropyl Alcohol on a cotton tip or better still, a rag piece and run under the print head.
If this doesn't help, maybe this video will -
https://www.youtube.com/watch?v=CspEIN8EsZ4
Lastly, the printer should have come with a program that can clean the print heads.
Dec 24, 2017 | HEWLETT-PACKARD Hewlett Packard Officejet...
The "Clean" button keeps flashing...
If the clean button is flashing all the time then there is a problem with the button itself. The unit will not operate until the problem is fixed.
Might need the dishwasher make and model to assess the problem better.
Jan 29, 2011 | Dishwashers
What kind of oil does a jeep grand cherokee use
Regular 10W/30 should be OK. Synthetics or blends are better , but having CLEAN oil and doing regular changes and filter changes is the best way to keep your car running for a long time.
Sep 20, 2010 | 1996 Jeep Grand Cherokee
What is the best software to use to clean up my harddrive of viruses? My computer is running slower all the time.
the windows software found at the microsoft page
but the alternative is much better
reinstall the os, this is just something all windows users will have to face one day
Jul 16, 2010 | Dell Dimension 8400 PC Desktop
Upgrading my laptop processor
hey, your best bet is upgrading the ram, if its ddr 2 will cost about 25-30 pounds for a extra gb, which will make it run a bit smoother. noone ever upgrades processors on laptops as your usually restricted to what u can uppgrade it too or costs too much.
i would suggest the memory upgrade...
if i can help anymore just ask..
All the best
John
Jul 26, 2008 | HP Pavilion dv9000z Notebook
Emachine w3615 keeps running
bug do a clean up run ccleaner and windows live one care free ok shut down the computer when u dont use it blow dust out inside well and get nice fans moving more the better
Jan 24, 2008 | Computers & Internet
Computers & Internet Logo
43 people viewed this question
Top eMachines Computers & Internet Experts
Computer Links
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
