Question about Home
Chouchin ch 899
Clock worked one month fine. then stopped. changed battery. now clock does not give proper time anymore
2 Suggested Answers
SOURCE: i have a radio controlled clock they told me it
Hi Follow this link for a copy of the clock instructions http://www.precisiontimekeepingshop.com/WebRoot/Store3/Shops/es119696_es124040752439/4A01/ADE9/E32C/D6DB/8872/50ED/8971/B0A9/PREC0007_0020_Instructions_0020_copy.pdf
Posted on Oct 31, 2010
Second hand on HTAWI CH-899 clock moves in one spot-won't move forward
The second hand is a press-fit on the clock shaft. Sometimes operation can be restored by pressing the second hand down firmly (without destroying the hour and minute hands.
Nov 12, 2016 | Home
Chouchin ch 899
You may need to try to repair or replace the quartz movement, this link will help you out.
http://usedclockparts.com/14-clocks/clock-videos/126-quartz-battery-operated-clock-movement-repair
Jul 11, 2014 | Home
Sharp spc403 instruction manual
hold "Cal C/F" for 2 or 3 second then the year will blinking. The press "Adj CH" to move year.
Then press "Cal C/F" again it will blink month then press "Adj CH" to change month, and date.
May 21, 2012 | Audio Players & Recorders
After a power outage of approximately 45 minutes i have no display
Hello
There is a Lithium battery inside your clock to get a backup even the power is interrupted for a long time. This battery may last up to 3 years eventhough there is no power to the device. If this has gone weak, the backup fucntion will not be. so check this battery.
Just reset the device. It will make it work properly. To reset the clock after total memory loss; do the folloing.
[1] Connect the radio to your AC outlet and let the clock set itself.
[2] Depress the MONTH/DATE and TIME buttons together. The display will change
from 'Time'to 'Year'
While holding the MONTH/DATE and TIME buttons, press the SET + button
to set the display to the correct Year, then release the buttons
OK.
Jul 24, 2011 | Emerson Smartset Clock Radio
My WWVB radio controlled quartz ch 899 clock is 21 minutes off the correct time. How do I set the clock by minute intervals?
these really aren't atomic clocks and are set at the factory. It receives, it's LF signal out of Colorado and should correct itself. If not contact the manufacturer.
Jan 12, 2011 | La Crosse Radio Controlled Atomic Clock
Changed battery and now pendulum wont swing. Clock doesn't operate at all. All was fine until I changed the battery.
Give the pendulum a shove and do it every time you pass the clock. I got mine going from swinging for just 20 seconds to working permanently, at least until the next battery change.
Jul 07, 2009 | Howard Miller 645-627 Clock Radio
Wireless thermo clock not reading outside temp
I've had a similar problem with another model, an Oregon Scientific Model IWA-80055 Wireless Thermo Clock, in which when I replaced the batteries in the remote sensor, the clock would not read the temperature from the remote sensor.
I found it fairly consistent to solve this by taking a battery out of place in the clock and putting it back in.  Unfortunately this also messed up the clock's time and date.  This is also in the instructions catalogue for the device, check and see if yours gives a similar solution.
Dec 30, 2008 | Oregon Scientific Lwb0997110113004...
Home Logo
35 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
