Question about Casio TE-4500F Electronic Management Cash Register
Won,t let me ring any iems in just keeps saying wrong mode
My laptop won't allowed me to login II don't what wrong with it..in the screen it says configuring updates then goes off and back again to configuring updates but just keep doing it again and
you can login to safe mode using F8 key on boot or just waite for fully updates instalation it can take some time and can reboot many times if it's installed many updates
Nov 14, 2012 | Toshiba Satellite M300-ST3403 Notebook
Will not receive faxes or copy Fax line rings but the machine says its receiving but nothing will print out and it won't copy pages either I've tried turning the machine off for up to 5 minutes,...
To begin troubleshoot,you should set the machine to basic Fax/Tel mode only.
1 If it is not illuminated in green, press (Fax). 2 Press Menu/Set, 2, 1, 2. 3 Press ? or ? to select how long the MFC will ring to alert you that you have a voice call (20, 30, 40 or 70 seconds). Press Menu/Set. 4 Press Stop/Exit. Even if the caller hangs up during the pseudo/double-ringing, the MFC will continue to ring for the set time.
After you confirm your Brother MFC-5440CN is able to receive fax then you can pick one of the 4 modes as describe on the owner manual.
You can download it HERE Detail Information is on 3-10
Jul 28, 2011 | Brother MFC-5440CN All-In-One InkJet...
How do I increase the number of rings on my Brother MFC-780n fax/printer before it picks up?
Setting the Ring Delay
The Ring Delay sets the number of times the
MFC rings before it answers in Fax Only or
Fax/Tel mode. If you have extension
phones on the same line as the MFC or
subscribe to the telephone company’s
Distinctive Ring service, keep the Ring Delay
setting of 4.
(See Operation from extension telephones on
page A-4 and Easy Receive on page 4-3.)
(Fax).
2 Press Menu/Set, 2, 1, 1.
3 Press ▲ or ▼ to select how many times
the line rings before the MFC answers
(00 - 04).
Press Menu/Set.
(If you select 00, the line won’t ring at
all.)
4 Press Stop/Exit.
Initial Setup
1.Receive Mode
Current Receive Mode
Fax : Fax Only
F/T : Fax/Tel
TAD : External TAD
Mnl : Manual
Setup Receive
1.Ring Delay
Apr 02, 2010 | Brother MFC-7820N All-In-One Laser Printer
Not receiving faxes. Machine just keeps ringing.
Make sure fax is not set to TEL mode...it will keep ringing and never answer. It should be set to FAX. mode.
Mar 15, 2010 | Office Equipment & Supplies
I have a nikon d40 and just purchased a 52mm lense reverse ring for it but when i attatch it to camera it keeps saying lense not attatched. what am i doing wrong?
You need to switch to Manual (M) mode. You won't be able to meter through the lens. Nor will you be able to autofocus.
Aug 29, 2008 | Nikon Cameras
NO RINGING TONE
hi!
check your mobile is in silent mode!
After that goto tone setting->ringing mode->you keep it is ringing->select alter for all calls->and than check volume!
or
Otherwise goto profile personalise setting tone setting->ringing mode->you keep it is ringing->select alter for all calls->and than check volume
Good luck
Jul 18, 2008 | RIM BlackBerry Pearl Smartphone
Set up to receive fax
To select or change your Receive Mode
2 Press Menu/Set, 0, 1.
3 Press ▲ or ▼ to select Fax Only,
Fax/Tel, External TAD or
Manual.
Press Menu/Set.
4 Press Stop/Exit.
The Ring Delay sets the number of times the MFC rings before it
answers in Fax Only or Fax/Tel mode. If you have extension
phones on the same line as the MFC or subscribe to the telephone
company’s Distinctive Ring service, keep the Ring Delay setting of 4.
(See Operation from extension telephones on page A-7 and Easy
Receive
on page 4-4.)
times the line rings before the MFC
answers (00, 01, 02, 03 or 04).
Press Menu/Set.
(If you select 00, the line won’t ring at all.)
4 Press Stop/Exit.
Initial Setup
1.Receive Mode
Fax : Fax Only
F/T : Fax/Tel
TAD : External TAD
Mnl : Manual
Setup Receive
1.Ring Delay
Apr 02, 2008 | Samsung CLX 3160fn All-In-One Printer
Same fax and phone number
check the setting in the receive mode button. set it to fax
Mar 29, 2008 | Canon FAX-JX200
Fax
This si str8 from the manual! The Ring Delay sets the number of times the MFC rings before it answers in Fax Only or Fax/Tel mode. If you have extension phones on the same line as the MFC or subscribe to the telephone company?s Distinctive Ring service, keep the Ring Delay setting of 4. 1 If it is not illuminated in green, press (Fax). 2 Press Menu/Set, 2, 1, 1. 3 Press ▲ or ▼ to select how many times the line rings before the MFC answers (00, 01, 02, 03 or 04). Press Menu/Set. (If you select 00, the line won?t ring at all.) 4 Press Stop/Exit. Full Manual URL http://welcome.solutions.brother.com/BSC/public/files/dlf/doc000219/MFC-210C_UsaEngUsr_B.pdf Hope this helps! Regards, Babb
Apr 28, 2007 | Brother MFC 420CN All-In-One InkJet...
Casio TE-4500F Electronic Management Cash Register Logo
Top Casio Retail Supplies Experts
Electroboy
Electroboy
Gareth Cockram
Gareth Cockram
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
