Question about Car Audio & Video
Witch amplifier is strong enough to take two dvc starsound subwoofers 3500watt 2 ohm
leehumphreys
  • 38 Answers
SOURCE: noise when turn on and play music
Good chance that it is alternator noise mate, there is a little component that you can buy what you fit onto the alternator to stop unwanted noises feeding back threw the audio, ask in a car audio shop i would tell you the name i just cant remember it at all.
also check that all the earths are perfect, *bare metal* 80% of audio problems are due to a bad earth.
Posted on Apr 10, 2009
Icehockey35
  • 16 Answers
SOURCE: Output problem
dude TRUST me what you are using and have setup already is plenty..ONE TIP...of all things anyoine ever needs to worry about is the R...M....S power rating...the PEAK means NOTHING! its safe and fine to use what you got.
Posted on Jul 02, 2009
  • 53 Answers
SOURCE: 2 alpine type r 15's 4 ohm dvc and 2 american bass
Option 1 (parallel) = 0.5 ohm load
Voice coils wired in parallel
Recommended Amplifier: Stable at 1/2 ohm mono This set up will blow your mind as your amp will put out 1800rms at 0.5 ohm
Posted on Oct 19, 2009
  • 1126 Answers
SOURCE: 2 12" dvc subs 2 ohm stable amp
+ on amp output to + on speaker #1 to + on speaker #2. - on amp output to - on speaker #1 to - on speaker #2. This is a parallel circuit....4 ohms in parallel with 4 ohms = 2 ohms. IF it were wired in series....would represent 8 ohm load.
Posted on Nov 12, 2009
  • 306 Answers
SOURCE: How to connect Kenwood KAC-6104D to a single 4ohm
you want to parallel the terminals on the woofer. a jumper from positive to positive and the same on the negative will equal 2 ohm load at the amp
Posted on Feb 07, 2010
How do i wire alpine swr1243d subwoofer
There are a couple different ways you can wire up this speaker as it is a DVC speaker. Duel Voice coil, it has two + post and two - post. A dual 4-ohm voice coil subwoofer with its coils wired in parallel presents a 2-ohm load to your amplifier. Since an amplifier produces more wattage at a lower impedance, the parallel connection ensures you'll get the most output from your amp.
Series wiring lets you configure multiple woofers to one amplifier at an acceptable impedance. Wire both coils in series for an 8-ohm impedance, and then wire two 8-ohm subs together in parallel for 4-ohm total impedance.
You can wire each voice coil to a separate channel of your amplifier, if you prefer not to bridge your amp. Independent wiring is a nice option if you're wiring two DVC subs to a 4-channel amplifier - one voice coil per channel
Depending on what you are hooking it up to i.e. a mono amp or a bridged four channel amp. I can tell you post to wire exactly if I know how you want to hook it up and what ur hooking it up to.
Sep 15, 2014 | Car Audio & Video
Can someone please show me how to wire my subs to amp.. i have a 2600 watt planet audio 2 channel amp (2 ohm stable) and my subs are soundstream tarantulas t4 12s 900/1800 watts total. they are 1 ohm subs...
for your subs and amp the best way would be for the speakers to be wired in series1ch (mono or bridged)to have a 4 ohm load to your amp stable at 2 ohms
see pic for wiring diagram for 2 1 ohm dvc subs wired in series.
you will need more than one speaker wire for wiring the subwoofers coils(positive & negative terminals) together
hope this helps :~)
Mar 03, 2014 | Car Audio & Video
I have 2 15" dvc 4 ohm kickers 1000 watt / 500 rms &a1000 watt avionixx 4 channel amp what would be the right wiring scheme?
need to know the ohms on the amplifiers then might can tell you best solution for system
Mar 05, 2013 | Car Audio & Video
I have a sony deck with a 200 terminatorand 2 legacy 12" subs. i hook everything up an when i hook up the remote wire the light turns from green to red an it whistles the subs **** up.
Your giving a wrong load / Ohms impediance to your amplifier.
What are the specifications of your subwoofer? Is it SVC 4ohms or DVC 4ohms or DVC 2ohms? Whats the specs of your amplifier?
Apr 08, 2011 | MTX Terminator TN200/2 Car Amp
I have a rockford fosgate 1001d and 2 audiopipe dvc 12s need 2 know how wire speakers
Check to determine if your sub woofers are DVC 4OHM or DVC 2OHM SOLUTION 1 If your sub woofers are DVC 4OHM then, from the positive (+) of the amplifier run your cable to the positive terminal of voice coil 1 on sub woofer 1 then continue to connect all the positive voice coils together on both sub woofers. Do the same for the negative from amplifier to all the negative voice coils of both the sub woofers. RECAP: all positives together on the positives and all the negatives together on the negatives. This will give you a 1 OHM load to the amplifier making it deliver all its power but will also run hot. So if you are living in a hot climate take care. SOLUTION 2: Connect the negative on voice coil 1 to the positive of voice coil 2 on sub woofer 1 Do the same for subwoofer 2 now you should have a free negative and a free positive on each of the sub woofers. connect the free positives together and follow through to the positive on the amplifier. do the same for the free negatives sending them to the amplifiers negative. This will give you a 4 OHM load to the amplifier. Not full power in this mode but the most stable working condition for your amplifier. SOLUTION 3 If your sub woofers are DVC 2 OHM then you only have one reasonable wiring solution. Connect like solution 2. This time because of the DVC 2 OHM sub woofers you would have a 2 OHM load to the amplifier. This is also a stable load for the amplifier and does not generate to much heat and still deliver over 50% to 70% of the amplifiers power. good luck and drop me a line if you still have doubts. dreamsystems
Feb 10, 2011 | Car Audio & Video
How to wire up an audiobahn aw1251t i want to invert it
Two 4 ohm Dual Voice Coil (DVC) Speakers Option 1 (parallel/parallel) = 1 ohm load
Voice coils wired in parallel, speakers wired in parallel
Recommended Amplifier: Stable at 1 ohm mono 2_4ohm_dvc_1ohm.gif
Option 2 (series/parallel) = 4 ohm load
Voice coils wired in series, speakers wired in parallel
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_4ohm_dvc_4ohm.gif
have any more question let me know
http://www.tintingbyfredjohnson.com
Dec 23, 2010 | AudioBahn Car Audio & Video
Is right use the amp with the x-over in lpf and also with and impedance of 2
If your amo is a subwoofer amp yes you want a LPF. Low pass filters are capable of passing low frequency energy. As far as the impedance of your amp goes check with the manufacturer for proper the proper load. What speaker config do you have?
2 DVC 8 ohms in parallel (voice coils) then series (speakers) are 8 ohms
2 DVC 4 ohm - in parallel (voice coils) then series (speakers) are 4 ohms
DVC is dual voice coil
Impedence for parallel is (Z1^-1+Z2^-1)^-1 or 1/((1/Z1)+(1/Z2))
Use those to figure out parallel impedance, series you just add them together.
Dec 21, 2009 | Hifonics Titan TXi 6006 Car Audio...
I have two dvc cvx andbrutus 1608d mono need help
Both Positives on both subs ultimately to + on amplifier
Both Negtives on both subs ultimately to - on amplifier
This will net a 1 ohm mono load for your amplifier.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 20, 2009 | Kicker CompVX CVX104 Subwoofer - 10" Dual...
How to wire 2 dvc subs to a orion 2150sx ? dont know the wire colors or how to hook um to my amp.
what impedence are the voicecoils?
Dual 4 - Dual 2 - Dual 1 ??
Orion SX / GS / HCCA amp Wiring guide:
Orange = Right Positive
Black/ Orange = Right Negative
Yellow = Left Positive
Black/ Yellow = Left Negative
Blue = 1+1
Bridging of SX or HCCA Amps:
1. Use the Orange wire for Positive.
2 Use the Black/ Yellow wire for Negative
3. Push "in" the Mono Button
That amplifier is only 4ohm mono stable - so assuming the subs are dual 4 ohm voicecoils...
First wire both in Parallel Independently So each subwoofer is now a 2 ohm load. (combine + and + - and- on both subwoofers)
Now Take a positive on one voicecoil of sub #1 and attach to amplifier+(orange)
Take a - on that same subwoofer and attach it to a + on the OTHER subwoofer.
Finally, take a - from the second woofer to the amplifier -(black/yellow)
Now you have a 4 ohm load on your bridged channels.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 23, 2009 | JBL 1200GTi Car Speaker
Best results
huge shared common space slot loaded box (size depends on sub 10", 12" 15" you need to clarify that please) the amp specs on earthquakes site say the phd5000 is rated at a max output of 5k watts at 1 ohm 3k watts at 2 ohm so, with 3 dvc 2 ohm subs you only have 3 options of which only 2 will be a usable solution:
1. 3- 2ohm dvc series at sub parralel at amp = about 1.33 ohms at the amplifier this is the best option to get the most power to the subs as each sub will produce a 4 ohm load then wire each one to the amp the amp sees 3 4 ohm parralel loads which = 1.33 ohm so based on the amp specs you would be close to 1200 watts per sub.
2. 3- 2ohm dvc wired in series at sub and all 3 subs series wired together very difficult to wireand will give you a 12 ohm load which is next to no power at all (not a viable solution)
3. 2- 2ohm dvc parralel wired to each other and then at amp the amp sees a 1 ohm load and makes 5k watts max but you can only (REREAD THAT LINE! ONLY USE 2 SUBS IN THIS WAY) WHICH GIVES THE MOST POWER BUT ONLY USES 2 SUBS
Jul 09, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Car Audio & Video Logo
21 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
