Question about Siemens HF87950GB Convection Microwave Oven
Change light bulb - Siemens HF87950GB Convection Microwave Oven
How to change a light bulb in microwave
Things You'll Need
30-watt incandescent light bulb
Screwdriver
Light
Unplug the Magic Chef microwave from the wall outlet.
Remove the screw from the light cover located on the left side of the underside of the microwave. The light cover is connected to a hinge and will lower, but cannot be removed from the microwave.
Unscrew the light bulb, then screw in the new light bulb. hope this helps
Oct 08, 2016 | Magic Chef Microwave Ovens
GE double Oven range PLT059-2 How do you access surface light bulb to change it?
There should a sliding panel of glass or plastic covering the light. Remove the glass or plastic then you should see the light bulb. If the light buld is a regular old bulb unscrew it if its a small floorisent bulb twist it so it will roll out of its sitting position. Then you can take the bulb to any hardware store to match the bulb. DO NOT PAY FOR SOME ONE TO CHANGE A LIGHT BULB....Please if this helped you post that I helped you with the correct answer so i may get credit....
Nov 17, 2014 | Microwave Ovens
FGMV205K cover removal
Good Afternoon Friend,
I understand that you want to know how to remove the cover on your Frigidaire microwave, model# FGMV205K. There are two different covers that you are able to remove for access to two different light bulbs.
If you are trying to change the Microwave Oven Light for inside your microwave:
    1)To replace light bulb, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
    2)Remove the louver by removing the three Hood Louver Screws.
    3)Push in the upper tabs and pull the louver away from your appliance.
    4)Remove the light bulb and replace with a new 20 watt light bulb. DO NOT USE BULB LARGER THAN 20 WATTS.
    5)Close the Oven Light Cover by carefully pushing into place. Push the louver back into place (engaging both the bottom and top tabs) and change to hood Louver Screws.
    If you are trying to change the light bulbs underneath your Microwave:
      1)To replace light bulbs, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
      2)To open Light Cover, remove the screw on the light cover.
      3)Replace the light bulbs with new 20 watt light bulbs. DO NOT USE BULBS LARGER THAN 20 WATTS.
      4)Close the Light Cover and secure with screw removed at step 2.
      If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
      -Best Regards-
      WP
Jun 07, 2014 | Frigidaire Gallery FGMV205K 2.0 cu. ft....
I need to change the interior light bulb in my Frigidaire over the counter microwave. The model # is FMV156DCA.
Good Morning Evelyn, thank you for allowing me to assist you!
Here are some simple troubleshooting tips to help replace the light bulb on your Frigidaire microwave, FMV156DCA.
    ·First, disconnect power to your microwave. This can be done by either unplugging it or at the circuit breaker panel.
    ·To release cover, remove the screw on the light cover (light cover may become very hot, do not touch glass when light is on).
    ·Remove old light bulb and replace only with equivalent watt bulb available from parts distributor or the manufacturer directly. Bulbs are also available at most hardware stores or lighting centers. Bulbs larger than 30 watts are NOT recommended.
    ·Close light cover and secure with screw removed in step 2.
    I hope this information proves to be helpful. If you have further questions, please do not hesitate to reconnect.
Nov 25, 2013 | Frigidaire FMV156DC Microwave Oven
Changing interior light bulb on GE jes1289sk
I have had this trouble before but with a different model. There may be a plastic screen inside the microwave that will just pop off exposing the bulb. Now all you will need to do is to find out what type of bulb you will need to change the other bulb. I hope this made things easier on you.
Jul 25, 2013 | Microwave Ovens
The light bulb in my emerson 8997B stopped working. It had come backThe light bulb in my emerson 8997B stopped working.
Buy a different brand of Microwave. This is ridiculous! We are now buying a new microwave - a different brand, one that has a light bulb that is easy to change
Dec 16, 2012 | Emerson Black Microwave Oven
How do you change the light bulb under the microwave?
put the bulb of microwave down . and then install a new bulb on it .before do these .you should turn off the switch .
home light bulbs
May 02, 2012 | GE JVM1650 1000 Watts Microwave Oven
Need to change the light bulb. found it but can't
push in on the bulb and then turn a quarter turn counter-clockwise,its a bayonet base bulb,not a candelabra base like a typical light bulb has
Jul 26, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Changing Microwave bulb
Remove lid, you'll probably need a pozi drive screw driver and a tamper proof torx drive.
The bulb is located near the front.
Mar 15, 2009 | Microwave Ovens
Can not change interior lightbulb
how do I change the little light bulb on the top to take off the cover what do i need.
Please, lvinci@gmnew.com
Feb 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Siemens HF87950GB Convection Microwave Oven Logo
126 people viewed this question
Top Siemens Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Bill Olaschinez
Bill Olaschinez
Are you a Siemens Microwave Oven Expert? Answer questions, earn points and help others
