Question about Refrigerators
Upright freezer trips circuit after moving across room
It worked perfectly until we moved the pair carefully, upright about six meters. The fridge ran fine but the freezer trips the house power circuit every time. I can see no damage or exposed wires anywhere. The compressor is still hot to touch, but it was running constantly until we moved it about two hours ago. I wondered if something like the heater coil could have come loose from the movement?
  • 1,230 Answers
If compressor is hot, it could be an issue with the starting components. Let it cool down for about an hour an it is room temperature to the touch. If the breaker trips when the compressor attempts to start, I would look at the start components. It may be just a case of unusual timing that they went bad at this time. Make sure there is nothing else on the circuit you have it plugged into. Could be an overloading issue of the circuit.
Posted on Aug 04, 2017
robotek
  • 1512 Answers
SOURCE: suddenly tripped off house
Hi akula, 200 ks to a fridgie, LG appliance, you must be in Australia;) Is it the earth leakage circuit breaker operating. If so, then you have a leakage problem to earth from the heater pad(not quite sure what that is, but this problem will need to be repaired. Am doing some research to see if there is anything that can be done without just getting a new fridge. Back to you soon.
regards
Graeme
Posted on Mar 21, 2008
  • 82 Answers
SOURCE: Fridge not cooling
Hello.
The most common thing that happens while moving a frig is when moving it they put the dolly underneath the condenser fan housing and bend it into the fan causing the compressor to overheat before it has a chance to cool down everything. If this isn't the case then I will send you a list of things to check out. Let me know.
Posted on Dec 07, 2008
landsend
  • 1066 Answers
SOURCE: freezer cold, fridge warm
The small cooling fan in the freezer compartment that sends chilled air to the food side is defective and needs replacement.  Sometimes that are only frozen stuck.
When you receive advice from this website you have to understand that without the item in front of us, we are only able to provide "a best guess" as to what the problem might be based on you description of the defect.  If you haven't described a clear and precise description of the defect you decrease the chances of an accurate reply.  Thank you.
Posted on Apr 29, 2009
richroth
  • 9472 Answers
SOURCE: compressor rattles, runs hot, and runs longer than normal
This is the first sign of the compressor starting to fail.The more wear a compressor experiences, or the closer it is to failing, the longer the system will need to run to cool the refrigerator down to the proper level. This long running time will lead to higher electricity bills than usual, which is one of the first signs that something may be wrong with your compressor.
Posted on Apr 25, 2012
larry804
  • 3 Answers
SOURCE: upright freezer quit cooling, interior fan runs, compressor runs
Upright and chest type freezers have their condensor coils located in the walls of the freezer. When the unit is running, the walls will be warm at the top and cooler at the bottom. If the walls aren't warm the compressor isn't running. You won't find a cooling fan in back because there aren't any coils to cool back there.
Posted on Dec 17, 2012
I have moved my bush fridge freezer bsbm166s and now the light is on but its not working
If you have laid it down when you moved it you need to have it in the upright position for 24 hrs. before plugging it in. (so unplug it. let it sit for 24 hrs. then plug it in.)
Sep 20, 2013 | Freezers
After transporting the fridge on its back for approx 10mins, and leaving it to stand upright for 24 hours, it was switched on, after a short while the fridge started clicking, then began freezing, then...
Here is a tip that I wrote on moving refrigerators...if you did not do it thisway then you may well have ruined a perfectly good refrigerator.
Moving a Refrigerator What is thebest way
If you already have moved it wrong, you can sometimes get it working byplugging it in and unplugging it a number of times with an hour or so inbetween.
heatman101
Aug 21, 2011 | Indesit INCH310AAVEI Bottom Freezer...
I had to lay down my upright freezer for transport how long before plugging in and using it
heatman101
Aug 07, 2011 | Amana 19.7 cu. ft. / 558 liter Upright...
Just moved a Kenmore 15 upright freezer. Plugged it in and the motor does not come on.
IT MAY SOUND FUNNY BUT STAND THE FRIDGE ON ITS END FOR THE GASES TOCLEAR.LEAVE UNPLUGGED WHILE ON ITS END FOR ABOUT 2/3DAYS THEN STAND UPRIGHT AND PLUG BACK IN THIS MAY NOW WORK..ROB.
Aug 29, 2010 | Kenmore Freezers
We bought a Woods all fridge and upright freezer pair
Do you know what parts are needed? Some are available and some are not.
Apr 24, 2010 | Woods Upright Freezer MU07W
Taking out trays for cleaning
Usually the holes are deeper than they appear in the side walls. Lift the shelves just a hair and then push them left...the right side should now be outside the hole and able to be moved upward until left side clears.
Reverse this process to reinsert. Good Luck.
Aug 21, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Freezer LFFH21F7HW upright is making to much noise when it runs. Is this an ongoing problem?
Hi, What kind of noise is it making?
Also have you tried moving the fridge slightly incase its up against a unit or sitting uneven as this can cause a noise if after this you still have the noise their isnt much you can do about it as its not worth replacing parts that are working fine.
I would move the fridge slightly or adjust the legs so its sitting even as this can cause a vibrating noise.
Let me know how you get on or if you need further assistance ok
Aug 11, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
Fridge not cooling
Hello.
Dec 07, 2008 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Kenmore freezer not cold at all!
We had a Kenmore upright which worked fine but then suddenly was not keeping food frozen. Long story short, do not store anything on top of the freezer unit. It will insulate the coils that run across the top of the unit, and cause your compressor to work harder than it needs to, and eventually overheat and become ineffective. Says nothing about it in the user manual. We learned the hard way by losing food.
Jul 30, 2007 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
