Question about 2004 Mustang Factory Wiring Diagrams
Oil pump and oil pick up for 5.0 holden - 2004 Mustang Factory Wiring Diagrams
    New Friend:
  • 122 Answers
Inside oilpan you will find these
Posted on Jan 02, 2015
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Holden Combo oil relief valve location and repair
The pressure relief valve is built into the engine oil pump inside the engine.
Dec 02, 2017 | Holden Cars & Trucks
Oil pressure on my 1991 Nissan sometimes drops to about 5 psi at idle when at operating temp. Other times it will drop to a more normal 25-30 psi. Is there is a high pressure relief valve sticking?
5 psi then 25 -30
what are these readings from ..an after market oil pressure gauge ?
oil light should come on if 5
what make of nissan
how many miles/kms on the clock
would first replace oil pressure sender
oil pressure relieve valve on the oil pump sticking is a possible
oil lower W rating used too thin at the moment
clogged oil filter or sump pick up
oil pump worn or
main bearings worn
Jan 20, 2017 | Nissan Cars & Trucks
Own Holden Cruze 2009 Where sump bolt to change oil
Possibly doesn't have one. Remove old oil from dipstick with trade pump unit.
Nov 16, 2016 | Holden Cars & Trucks
My Holden statesman 95. The oil light on the dash bord is coming on and off, i know that is the oil pump or a blockage.. what is the best way to fix it?
It may be the oil pressure sensor at fault.
It could also be a sticking oil pressure relief valve.
Before you start replacing expensive items like oil pumps, start with the easiest and cheapest first.
Presumably the engine oil level is ok? and it isn't overdue an oil/filter change?
Your car doesn't have an oil pressure gauge? Knowing what your oil pressure was would be of help. A workshop would be able to check your oil pressure using something similar to what you see in the link below:
***** in oil pressure tester
Check your oil level first.
If the car is due an oil/filter change - do it.
If changing the oil consider using an engine flush:
engine oil flush Google Search
Then, try changing your oil pressure sensor. You should be able to pick one up at any car shop. It screws into the block and has an electrical connection.
The link below shows generic images of oil pressure sensors:
holden statesman oil pressure sensor Google Search
Mar 23, 2016 | Holden Cars & Trucks
How can I solve the oil pump problem on my Toyota camry.200l. It's lazy it takes about 5minutes to pump the oil
check for an air leak in the pick up tube for the pump, loose pipe and gasket onto the pump
check that what you are reading is a faulty oil pressure sender unit as most motors running 5 minutes with out oil will be just about knackered
Mar 14, 2016 | Toyota Cars & Trucks
Price to replace oil pump on 98 gmc sonoma 2.2l 5speed truck. Also what else is a good idea or has to be replaced while this job is done. Truck only gets about 5 pounds oil pressure after started
There are a number of things that contribute to oil pressure, the pump has very little to do with pressure. I will say I have seen a lot of issues with the pick up screen inside the oil pan becoming clogged. I would suggest hooking up a manual gauge to verify actual oil pressure, then if it is actually low I would remove the oil pan and check the pick up screen first. You're looking at 11-12 hours labor at a repair shop plus 100-150 for the pump if you want it replaced. Plus gaskets and oil.
Jul 27, 2015 | GMC Cars & Trucks
2002 holden rodeo automatic transmision oil capacity
The filter doesn't take any oil, but when they figure the quantity, they figure either filter change or rebuild, the filter change uses about 5 quarts and the rebuild is 12 quarts. I don't have the exact amounts in front of me, but if you need them,I can look them up. Also, I am not familiar with the Holden dual cab, But most automatics are about the same. Hope this helps.
Mar 08, 2010 | 2002 Isuzu Rodeo
How to change the oil pump of a ford ranger 1993
You didn't post your engine size so please pick the one that works for you....I'll post them all separately:
2.3L Engine The oil pumps are not serviceable. If defective, they must be replaced.
  1. Follow the service procedures under Oil Pan Removal and remove the oil pan assembly.
  2. Remove the oil pick-up and tube assembly from the pump.
  3. Remove the oil pump retainer bolts and remove the oil pump.
To install:
  1. Prime the oil pump with clean engine oil by filling either the inlet or outlet port with clean engine oil. Rotate the pump shaft to distribute the oil within the pump body.
  2. Install the pump and tighten the mounting bolts to 14-21 ft. lbs. (19-29 Nm)
WARNING Do not force the oil pump if it does not seat readily. The oil pump driveshaft may be misaligned with the distributor or shaft assembly. If the pump is tightened down with the driveshaft misaligned, damage to the pump could occur. To align, rotate the intermediate driveshaft into a new position.
  1. Install the oil pick-up and tube assembly to the pump. If there is a gasket between the pump and the pick-up, use a new gasket when installing.
  2. Install the oil pan as previously described.
Jan 19, 2010 | 1993 Ford Ranger SuperCab
How to change oil pump in 4.7
Here you go:
1. Remove the oil pan and pick-up tube.
2. Remove the timing chain cover.
3. Remove timing chain and tensioners.
4. Remove the four (4) bolts, timing chain tensioner and oil pump.
5. Position the oil pump on the crankshaft and install two (2) mounting bolts.
6. Position the primary timing chain tensioner and install the two (2) remaining bolts.
7. Tighten the pump and tensioner retaining bolts to 21 ft lbs in the sequence shown in attached photo.
8. Install the secondary timing chain tensioners, chains, cover, pick-up tube, and oil pan with new gasket.
See the photo below. Hope this helped and best wishes.
Jul 31, 2009 | 2000 Dodge Durango
2004 Mustang Factory Wiring Diagrams Logo
23 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
