Question about Hotpoint WMA64 Front Load Washer
Drum not turning
Belt is fine but drum not turning
barkencoa
  • 3463 Answers
SOURCE: WASHING MACHINE DRUM WILL NOT TURN
There is no adjustment provided for lining up the pulleys.
If it comes off then there are a couple of reasons that come to mind,the belt is too slack, the belt is worn,the drum is out of alignment with the motor pulley, caused by worn drum bearings, the motor is loose, a loose drum pulley, or you are not lining the belt up properly, overloading can also throw the belt off.
Hope this helps.
Plz leave feedback.
Ta.
Posted on Dec 09, 2008
barkencoa
  • 3463 Answers
SOURCE: drum not turning
If you are certain that the motor was turning, then the only things that come to mind are that:
  1. The belt is stretched or worn-Replace as there is no adjustment.
  2. The drum is stalled, either because it has seized, or there is something stuck in the drum.
  3. The motor brushes are worn, and will not cope with load of drum, check brushes.
Try running it on fast spin without the belt on , if it spins o/k, then that would indicate the motor is o/k.
Please leave a fixya rating for my solution.
Thanks.
Posted on Feb 12, 2009
SOURCE: hello i have a hotpoint wma40 the machine will go
Hi, i have a wma40s had it for 7 ears now same thing happended would start a cycle but then stop halfway through make the noise but the drum would not spin etc. i bought some carbon brushes of ebay for 7 quid and it works better than its worked in years bit nosiey for first few washes but after it settles it is as good as new.
Posted on Jul 21, 2009
barkencoa
  • 3463 Answers
SOURCE: My WF000 drum has stopped
The drum should spin freely with the belt off, there should be no resistance, if there is, then it could be main bearing problem, or somethig stuck between inner and outer drum.
Posted on Oct 31, 2010
  • 1525 Answers
SOURCE: My washing machine drum wont turn. The washing
hello. if it don't turn then it could be the brushes on the motor also check the interlock on the door. any spin problems could be the module control board get back to me if you still have problems
regards
shaun
Posted on Jan 03, 2011
Testimonial: "Many thanks for the advice regarding my washing machine. The brushes have now been replaced and the washing machine is once again working."
Hi, I've got a Kenmore model 110.70052991 and the drum won't rotate. It will intermittently. I have just replaced the belt and it still won't spin consistently. Could it be the
are u able to spin the drum manually? do u hear any sounds? squeaking? scraping? smell anything? the rollers (spinners lol) usually make funny noises when they go out and may still turn but roughly. Bad bearings may be an issue here? However if the motor has bad windings it may not have enough power to run (turn) drum consistantly, u can remove the drum and belt and housing and run the motor by itself and see if it turns and runs easily. with no pressure or weight added? Then add drum and belt, once the drum is added and it stops or runs half hazardly its ur motor ? In some cases the tensioner the belt sits on ( near the motor) can be damaged and cause similar problems , lastly u did add the belt correctly?
Dec 23, 2014 | Kenmore Dryers
I have whirlpool duet wed9200sq. The dryer seems to be working fine other than the drum will not turn. It heats fine and the drum will turn by hand, the belt is fine, no warning codes or other problems.
The drum and belt may be fine but the motor may not be. Since you seem to have access to the drum and belt, you can check to see whether the motor starts. Also check to see whether the belt and tensioner device are working OK
Sep 11, 2012 | Whirlpool Dryers
My kenmore dryer's drum does not spins. I checked for the belt and it's fine. Where do you suggest I check?
the drive motor if its not turning then the drum wont turn, also if its sliped the belt off thats another reson why and one more thing to look at is how tight is the belt on the drum,,, is it just sliping round it? is the drum very tight to turn by hand? are the drum bearings jamed up, is any thing stuck behind the drum? ??? like one of the kid's?
i hope this is helpfull to you
Oct 23, 2009 | Kenmore 63942 Dryer
Washer won't spin, motor sounds like its working, belt is fine...what do I check or do?
The belt may look fine, but if the motor is spinning, then the belt isn't transferring the motion to the drum.
First, make sure you can turn the drum by hand. Turn off the power. Reach inside the drum, grab the opposite sides and turn. If it moves more than a few inches, then it isn't the drum that's stuck. Possibly the belt tensioner has slackened and needs to be adjusted.
Jun 25, 2009 | GE WBSR3140DW Top Load Washer
Kenmore electric dryer won't start
it is possible that your belt is broken open the door manually turn the drum by hand if it turns frely then the belt is broken if not it could be your door switch that has failes but normally for this problem its a broken belt
Mar 15, 2009 | Dryers
Drum not turning
Thanks.
Feb 12, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Motor is fine but drum won't turn. What could it be?
is there a belt to turn the drum - if so it may need to be changed.
Jan 04, 2009 | Kenmore 73952 Gas Dryer
Hotpoint WMA64 Front Load Washer Logo
20 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
