Question about LG F1402FDS6 Front Load Washer
Water coming from the pump - LG F1402FDS6 Front Load Washer
We've bleed we've changed thermostat the water housing tank , in an o4 Sebring what's sign of bad water pump
Noise coming from water pump when engine is running, very slow or virtually no circulation of coolant in the radiator. To hear if the water pump bearing is going out..Take a long screwdriver or tire iron and touch and hold against water pump while engine is running, put ear to other end..works like a stethoscope..just be careful you have it in a steady place on water pump so belt doesn't turn it into a projectile!
if you feel like its the water pump, take serpentine belt off and see if pulley on water pump has any play up or down or front to back, and spin with hand should spin freely...if has play or doesn't spin freely or you can hear, usually a kind of whining noise coming from water pump, it needs replacing. The water pump also has a small hole onthe bottom side, if the diaphragm in waterpump goes bad it will usually have a slow steady drip coming from the hole. Have you had the radiator pressure tested?
Sep 18, 2015 | Cars & Trucks
I thought my water lines was frozen but after heating water line the pump won't kick on I can manually push the points on and the pump will run but won't stay on by itself and still doesn't pump water
The pump will probably need to be primed. Look for a drain plug at bottom of pump casing remove it and see if there is water coming out. You will need to get into the discharge side of pump to refill with water. Once you see water coming out of drain then replace and fill pump and line to where you broke into line (union joint). Then try pump once again..
Feb 21, 2015 | Plumbing
Water pumps turns on but o No water comes out of
Sounds like the pump needs priming. There must be a plug on top of pump. Remove this and fill the pump with water to top. Replace cap an turn on. If keeps loosing prime, you either have a fauly nrv, non return valve not opening or you dont have one at all. Essential bit of kit.
Aug 16, 2013 | Cars & Trucks
Dayton pressure washer motor runs no water coming out of wand
Not sure what model you have but take the high pressure hose off the pump and see if water in coming through the pump.
If water will not come through the pump then check the outlet port of the pump.
If water is coming out of the pump but wont come out the end of the want then you may have a clogged nozzle in the end of your wand.
Oct 23, 2011 | Heating & Cooling
Leaking water behind water pump seems to be a housing bolted behind the pump,thats where the water is coming from....does it come off with the pump?" dodge 360" is the timing belt here behind...
The Water is coming from the diaphragm . It may seem like its coming from the bolts but it isnt. Unless water pump was recently installed with a bad seal .
Dec 28, 2010 | 1990 Dodge Ram
I think water pump went out, but before all that work was to be done I noticed that I put water in the radiator and once I start the car water comes out from the water pump nipple and alot of water comes...
No it is not a cracked head, your water pump has a pressure hole to give you an indication that the pump is getting there. when the motor is running the pressure builds up and squirts the water all over, resulting in misleading you.
Sep 09, 2010 | 1993 Chrysler Lebaron
I have frigidaire FWT449GFSI,the water can cont come out
HI, check the following to address this issue.
1. Clogged drain line or water pump Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
Sep 23, 2009 | Frigidaire ATF6000ES Front Load Washer
I just replaced the water pump on my 1990 f150
You have to take the water pump back off and the peice between the water pump and the block and take it too and clean the surface off good with a metal scraper or sharp regular screw driver and put a new gasket on or if you cant get a gasket some high temp.rtv on the surface between the block and the adaptor to the water pump.
Sep 02, 2009 | 1990 Ford F150
How do you take fan off to get to water pump
A special fan tool is required to remove the fan from the water pump. Yes it does unscrew. One part of the tool holds the bolts of the pulley while the other part unscrews the large nut on the water pump. Tool rental is available at some auto parts stores.
Apr 24, 2009 | 1995 Dodge Ram
Paying extra labor to replace water pump when doing a timing belt?
that is true the water pump does not have to come off to change the water pump
Apr 16, 2009 | 2002 Nissan Xterra
LG F1402FDS6 Front Load Washer Logo
15 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
