Model and make would help
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SETTING THE SERVICE ADJUSTMENT
MODE
1. Standby mode (Power off).
2. Press the following buttons on the remote commander within one
second of each other:
DISPLAY Channel 5 Sound Volume + Power
READING THE MEMORY
1. Enter into service mode.
2. Press 0 on the remote commander.
3. Press ENTER to read memory.
ADJUSTING THE PICTURE
2. Press 2 or 5 on the remote to select the device item.
3. Press 1 or 4 on the remote to select an item.
4. Press 3 or 6 on the remote to change the data.
RESETTING THE DATA
Note: Be careful when using the remote! It will clear and re-initialize
ALL NVM data including defl ection adjustment data if not reset
properly as follows:
5. Press MUTING then ENTER to write into memory.
RESETTING THE DEFLECTION NVM DATA
2. Press 7 , then MENU, and then press ENTER on the remote.
RESETTING THE SYSTEM NVM DATA
2. Press 7 , then 9 , and then press ENTER on the remote.
2. Press 8 and then press ENTER on the remote.
MEMORY WRITE CONFIRMATION
METHOD
1. After adjustment, pull out the plug from the AC outlet, then replace the
plug in the AC outlet again.
2. Turn the power switch ON and set to Service Mode.
3. Call the adjusted items again to confi rm they were adjusted.
Ok.
