Question about Samsung HP-R5072 50 in. Plasma HDTV
Tv click tv just clicks like it wants to turn on but doesn't. was doing this evey now and then would turn off and then on then it became more frequent and now just sits there doing it over and over again without anything coming up on the screen
SOURCE: Tv makes clicking noise but won't turn on
Definitely a power supply problem.I had the same problem and changed the power supply, and TV works normally. Depending where you buy the unit, it shouls cost around $150/--, and it is very easy to replace.
Posted on May 06, 2009
MNfisherman
  • 11896 Answers
SOURCE: my tv keeps clicking and won,t turn on
It is very possible that the power supply may have gone out. Which unfortunately is common on many newer tv's and other appliances. You can use a multi-tester or voltage tester to see if there is any power coming out of the power supply.
Posted on Jun 15, 2009
  • 188 Answers
SOURCE: Tv will click on and off without sound or picture. Had been taki
Check power supply for bad caps.
Posted on Jul 27, 2009
  • 610 Answers
SOURCE: Samsung PN50B450 50 Inch On-Off Problem
POWER SUPPLY BOARD HAS FAILED. CALL1-800-SAMSUNG FOR NEAREST SERVICE CENTER.
Posted on Dec 09, 2009
budmrtn
  • 11361 Answers
SOURCE: The TV switches on and off with a click for
That is always the first place to look and make some voltage checking, you should have dc of 5, 12 and 24v at the power supply output connectors. Look for bad caps with bulging tops also.
Parts: http://www.shopjimmy.com/catalogsearch/result/index/?q=Samsung+LN-T4061F+&stock=all&limit=200
Posted on Jan 07, 2010
Testimonial: "Thanks. I'll check it out."
Turns on but doesn't do anything else. Screen doesn't come on. Can hear a clicking sounds like a turn signal sound.
looks like a( DLP) tv digital light proccessor . aka projection. most likely the bulb is burned out . if so cost is $65-125 bucks. aftermarket bulbs are available online but some dont work or burn out prematurely. if you decide to fix it or buy a new tv ,invest in a surge protector. it will save your tv from problems like this . good luck.
Feb 11, 2013 | Televison & Video
Hazzard switch clicks frequently
One easy and cheap repair is to replace the hazard switch.If that doesn`t fix it then you need to replace the multi-fuction switch.This would be the turn signal switch.This is a more expensive repair and part.Hope this helps.Good luck.
Dec 05, 2011 | 2003 Oldsmobile Alero
How to turn volume up so you can hear caller
in the center of the phone is a small square window with small arrow pointing up and one pointing down. volume inceases evey time you click on it and decreases every time you click on bottom arrow
Sep 03, 2011 | Uniden DECT 6.0 Cordless Phone ID
TV wont turn on
a bad power supply is most likely cause of this. Other possible cause is bad main circuit board.
May 03, 2010 | Samsung HL-S5086W 50" HDTV
IBM Travelstar 30gig harddrive refurbished paid 135 for it, clic
Hi
OOUchh! I would say the Hard drive is about to fail, back up data ASAP.
Cheers cbacer
Aug 11, 2009 | IBM TravelStar 10GT 10 GB Hard Drive
Vertical color lines when tv turned on. not evey time
i just took mine into the shop for the same problem, very irritating hearing it turn on and off all the time just to start, it would take like 10 minutes for my tv to finally turn on, the technician at the shop said the power supply was bad and i wasn't getting enough power to the main board to turn the TV on, 200 bucks later, I am happy, fix it, it is worth it.
Apr 04, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
Disney Cars TV-Model DTD1363-CAR 13" TV/DVD
I have 1 , exact same problem. I took it to a local repair shop and it turned out to be loose connections on the circuit board. It was explained to me that as the problem became more frequent it was the connections getting worse. It cost about $100 (give or take).
Nov 03, 2008 | Disney DTD1363-CAR 13" TV/DVD
Slow performance - Frequent Hanging of system
Do you run the Aero them with the glass windows effects etc. and have the windows sidebar running? I have found that this tends to slow down my computer a lot.
To turn off Aero:
  1. Right click on an empty area of the desktop
  2. click personalize
  3. click window colour and appearance
  4. select colour scheme:"windows vista basic"
  5. click ok
To turn off sidebar:
  1. go to start-> control panel
  2. Click windows sidebar
  3. deselect "start sidebar when windows starts"
  4. click ok
  5. on the task bar right click the windows sidebar icon
  6. click close
Mar 08, 2008 | Microsoft Windows Vista Ultimate Edition
Samsung HP-R5072 50 in. Plasma HDTV Logo
14 people viewed this question
Henry  Thomas
Henry Thomas
