Question about Lowrance GPS
My lowrance x52 sounder has a black screen when turned on
Screen is black when turned on but if screen is on an angle you can see the graphics and writing on the screen.
hydetech
  • 113 Answers
SOURCE: GPSMAP 235 Sounder
Some 235s had a problem with the contrast setting. When the contrast is set to full the screen turns black.
When you turn on the GPS and the screen goes black, try tapping the left arrow on the track pad a few times. You should see the screen start to lighten. If that doesn't work, tap the power key and try tapping the left arrow a few times.
Posted on Aug 19, 2008
  • 10 Answers
SOURCE: transducer is mounted on a
Are you utilizing another unit in your dash? If so, sometimes when both units are on and in sonar mode, their frequencies will intefere with each other causing the vertical lines. I would suggest turning your dash unit off or lowering it's Hertz rate from 200Hz down to 50Hz.
Funny story...I saw this same issue on my boat years ago. I had an X102C up fron and an LCX-19c in the dash. I acutally thought it was some sort of man-made structure and spent time fishing it...DOH!
Posted on Mar 25, 2009
SOURCE: lowrance model 3500 digital depth sounder, unit is
i have the same problem can someone help
Posted on Mar 29, 2010
  • 320 Answers
SOURCE: My GPSMAP 168 Sounder has a black screen when
To fix the problem, the screen back light must be replaced.
Posted on Nov 17, 2010
kennethsweat
SOURCE: why does the screen on the lowrance x52 depth
can hear power on my depth finder but i do not see a display or anything when it turns on
Posted on Jul 07, 2012
Can i put lowrance 5hdi sounder and a lowrange sounder/gps 7hdi on the same transponder unit?
If you want to use two head units off of 1 transducer the answer is yes. You will require a transducer switch that allows you to select which head unit receives the sonar signal.
If you want to swap head units utilizing the same transducer the answer is also yes you can do that.
Dec 19, 2014 | Lowrance X515cdf 5" Color Lcd Sounder With...
Will power plug and transducer plug on lowrance x51 work with lowrance x52
I think your best bet would be to contact Lowrance support directly.
If you're in the US, here's their contact info.
Hope this helps
-Steve
Contact Us
Sep 02, 2014 | Boating
I have an older Lowrance, Model X65, which until a few weeks ago worked as if still new. I hadn't used the boat for the past few weeks and when I did the Lowrance screen now has a large brown spot in...
You need to contact Lowrance about the repair.
My really older, but loved, unit failed and Lowrance pointed out that techonlogy is SERIOUSLY imporved, and convinced me to upgrade to a new unit. I disliked the price, but LOVE THE unit. TONS easier to read, even in bright sunlight, depth sounder portion much improved...twin beams really makes accurate reading, and fast readings (unlike older units).
May 08, 2011 | Lowrance Boating
Can i install 2 x52 units on bow and stern with
Yes you can...you would have to install a rotary switch between the displays and the transducer. You would also have to make sure to turn both displays off before switching the switch.
May 15, 2010 | Lowrance X52 Sonar Fishfinder Without...
GPSMAP 235 Sounder
May 17, 2008 | Garmin GPSMAP 235 Sounder GPS Receiver
Powerin up - screen goes blank after a few swconds -
had same problem. the cause was corrosion in the boat wiring. the power wire was corroded 95%thru. there was enough voltage to start the unit but when the sounder kicks in the voltage dropped below minimum and the unit shut off. took a LOOOONG time to find.
Nov 15, 2006 | Lowrance LCX-19C GPS Receiver
GPS Logo
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
