Question about Fisher and Paykel Active Smart® E522BR Stainless Steel Bottom Freezer Refrigerator
How to assemble bottom tray - Fisher and Paykel Active Smart® E522BR Stainless Steel Bottom Freezer Refrigerator
My Dishwasher door keeps springing open - how do I fix this?
seems like it should have a lock on it someplace to keep door shut while operating .
May 16, 2015 | Dishwashers
While the washer is on and the water starts the door opens how to fix this? thanks
Hello Shirin;
My name is Peter. I am a retired field service appliance technician.
Push in the top and bottom trays. Close the door. Now, open the door. Are either the top or bottom trays pushed out?
In the bottom center is your water distribution vanes. Are they stuck up in the operating mode? Push the center water distribution vane down, push the top and bottom trays in, close the door and reopen. Are the upper or bottom tray sticking out? inspect the guide rails. Is there something blocking them?
So, your problem is:
1.) The trays are pushing against the door because they will not go in all of the way.
2.) You have a broken latch assembly.
You did not provide a model number. This is on a tag either on the top of the door or on the face of your dishwasher after you open the door
May 16, 2015 | Frigidaire Dishwashers
How do I replace my Samsung RF256AA ice tray on bottom freezer?
It's the ice maker assembly you can't just replace the tray put your model number in at repairclinic.com you can find one on there
Oct 26, 2013 | Samsung RF265AA Bottom Freezer French Door...
How i assemble di520 bottom tray lock
Step 1:
Remove the rear cover and in area of wastw tonwr box remove the tray blocking unit.2_3_2013_6_10_50_pm.jpg
Step 2:
Jan 22, 2013 | Konica Minolta Minolta Di520 Dialta Color...
Water from defrosting leaks into the bottom of the freezer and freezes into a solid sheet of ice, which I chip out every 1 to 2 weeks. Kenmore bottom freezer refrigerator Model 795.65002400.
If water leaks inside your refrigerator
(and it WILL, at some point) you can fix
it yourself.
In the good old models, one had to defrost the
fridge every few months manually.
In the recent models, the fridge defrosts automatically,
once or twice a day, and the water is supposed to drain
down a long drain tube into a pan located at the bottom of
the fridge. This collected water in the pan evaporates
by the heat under the fridge.
Now the drain tube can get clogged, by food debris and/or
ice. Thus when the water cannot drip through the drain tube
the water drips inside the fridge.
The drain tube is located behind the fridge, which is pretty
easy to take it out and clean. However usually the clog is
not in the long tube but in the connector assembly located
in the backside of the fridge that leads to the long drain tube.
To get to the connector assemble, you need to unscrew and
take out the back panel of the freezer compartment. You would
see the evaporator coil and a tray under the coil where the water
is supposed to drip through. If you find the tray completely frozen
with ice, let it melt off. To speed up melting, you may blow
hot air via a hair dryer. Once the ice is clear, you should see
a drain hole in the middle of the tray. This could be clogged,
which needs to be unclogged.
Next unscrew and open the thermostat control assembly located
in the inside of the back of the refrigerator compartment just above
the light bulb fixture. Once you take the take the cover off (you will
also have to take the knobs out) you will see a small tray cup about
2" x 2" x 1/2" into which water from the top freezer compartment
drain hole is supposed to drain. Pull out the tray cup, and if clogged,
unclog it, clean it and put it back.
To check if the drain works ok, pour some water on the tray
under the evaporator coil (top freezer compartment) and see if it
immediately drains into the tray located at the bottom of the fridge
at the floor level. If it does, you got it; and you can assemble things
back in the reverse order you took the pieces apart.
Needless to say, use a vacuum cleaner with a long suction tube to clean
out all the collected mess under the fridge. No matter how good
your housekeeping is, the bottom of the fridge will be full of dust.
Good luck and hope this helps
Aug 01, 2010 | Kenmore 65212 Bottom Freezer Refrigerator
Waititng for tray 2 to lift
if the tray doesn't lift than there may be a problem with the lifting motor. remove the right cover assembly and near the center bottom is the motor assembly. insert the tray and check to see if the motor is functioning. also check the tray, there is a gear on the tray that drive the tray up into position.
Sep 25, 2009 | HP LaserJet 4250n Printer
Upper paper tray does not raise, no error code
Swap trays, bottom plate mechanism may be damaged some kinda way.
Apr 04, 2009 | Toshiba E-STUDIO 650 Copier
A part fell out of the ice maker - makes 'soft' ice???
It goes on the bottom of the ice tray and snaps in that is the sencor that tells when the ice is frozen
Mar 28, 2009 | Samsung RF265AA Bottom Freezer French Door...
I can't reatach top( glasses) rack I can't figure out where the clips go into.
The clips attach to the upper tray assembly...you clip the little roller assemblies (all one piece) onto the bottom of the tray...along the lowest part of the tray...when clipped in place...(I'm not sure but there will be an even # on both sides) you then put the tray back into place and it will roll inside or along a silver track...which may have a slot cut out where the rollers drop down into and then the tray is pushed back...into place and the last roller drops into the slot and the tray will extend along with the arm that the rack is sitting in/on.
I hope this helps...any more ??...just ask....good luck...thanks for rating my effort...The Fang.
Feb 19, 2009 | GE Nautilus 24" Built-in Dishwasher
Prints in red only
Here's how I fixed mine... Looking at the inside closer, I realized that the ribbon tray (the metal assembly that the ribbon sits in) was bent upward in the bottom right hand corner; making the ribbon sit too high in the tray. I slipped a screwdriver under the bent area, applied presuure to straighten out the tray, and voila! It works fine now printing in both red and black. I'm guessing that people are are pulling back on the tray assembly when changing the ribbon resulting in slight bending over time.
- GWH
Apr 12, 2008 | Epson TM-U220 Matrix Printer
Fisher and Paykel Active Smart® E522BR Stainless Steel Bottom Freezer Refrigerator Logo
14 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
