Question about Sony KLV32S400A 32 in. LCD TV
Negative picture - Sony KLV32S400A 32 in. LCD TV
Pictures all switched to negative lastnight
If the whole screen is looking like a negative mode: go into setting/general/accessibility and turn off Invert Colors
May 05, 2013 | Apple iPhone 4S
Negative picture when filming
I found the home website for your camera on sony.com's european website:
http://support.sony-europe.com/dime/camcorders/sd/d8/d8.aspx?site=odw_en_GB&m=DCR-TRV140E
I didn't see anything about a negative picture on screen when filming, though.
Good luck on finding a solution to your problem.
Jul 18, 2010 | Sony Handycam DCR-TRV140E Digital...
Negative effect on Bright areas of Monitor/TV
Try demagitizing the moniter. In the monitor's menu it will have a picture of a magnic , select it. Sometimes it is listed as degrous. After selecting this, your screen will seem to spin then settle. If your still have problems, a magnic may have come close to the moniter while it was being stored, and that will ruin the picture.
Sep 21, 2009 | Computers & Internet
Negatives scan as negatives and not as pictures with the plustek 7300
In the Twain driver for your intellscan, there should be a selection for the type of scan. It should be set to "black & White Negative" or "Color Negative". The program you use to edit the scanned file should be able to change it to a positive if the scanned result is still negative. Programs such as Photoshop, Paint shop Pro etc can use Twain to have the scanner scan directly into them. There the phot (negative) can be edited and saved.
May 30, 2009 | Plustek OpticFilm 7300 Film Scanner
Screen looks like a picture negative problem
Picture tube is weak. You can add a booster the Picture tube. I would replace the set.
May 28, 2009 | Sylvania 6620LFP 20 in. EDTV-Ready LCD...
No real color picture, looks like an undeveloped negative, ghost
The pictures are indeed negative.  When scanning negatives or transparencies make sure you have the scanner set to the appropriate setting, otherwise simply Invert the colors in Photoshop, or similar photo editing software.
Dec 03, 2008 | Cameras
Negatives to pictures
The manual didn't show negative and slide support. I recommend you some of the hp products like HP Photosmart C7180 All-in-One, HP Scanjet G3010, HP Scanjet G4010, etc.
Feb 02, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Negative picture,lamp indicator flahing 3 minutes after turning tv off
I changed my lamp in the 65dr650 but the picture still looks like a black and white tv and flickers
Jan 30, 2008 | Sharp 65DR650 65" Rear Projection...
Sony KLV32S400A 32 in. LCD TV Logo
23 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
