Aptio setup utility asus - Computers & Internet
2 Suggested Answers
  • 265 Answers
SOURCE: Black screen and flashing white underscore.
Hi .
when you go into your setup ,go to disply and see if anything has changed?
let me know ...................good luck Roy
Posted on Feb 18, 2012
I have an ASUS Q501LA and it is stuck in the Aptio Setup Utility. How do I fix this?
Here are some troubleshooting steps you can try but definitely it's the HDD if you've done most of the troubleshooting with Asus Support.
- Start by disconnecting other devices connected to that laptop.
- Next is to load Aptio Setup screen and make sure that the HDD is set as the first boot device.
- If these will not work try loading BIOS into its default by pressing F9 while your in Aptio setup screen.
- Lastly, remove the HDD off the laptop and see if it will get pass the Aptio setup screen because if it does that confirms that its the HDD that is faulty.....not saying this will work for you but please make sure you no what you are doing before you try this.
Nov 06, 2016 | ASUS Computers & Internet
Downloaded Windows 10. Why is pc screen stuck on aotio setup?
Hi there, please try these steps and see if it resolves your issue.
  1. Select the Boot menu in the Aptio setup utility, select 'Launch CSM' and change to enable.
  2. Select the Security menu n the Aptio setup utility, select 'secure Boot Control' and change to disable.
  3. Select Save & Exit and press 'yes'.
  4. Hold down the power button until the unit switches power off completely.
  5. Switch back on and continually press the F9 button for about ten seconds; this should now allow the unit to boot up into the Windows Recovery menu.
  6. Select 'Advanced Start Up' and wait until the recovery menu appears.
  7. Select ' Advanced Options'.
  8. Select 'System Restore' and select a date prior to when the problem occurred.
This is for an Asus laptop but even of you are not using an Asus the troubleshooting should be the same. Courtesy of Microsoft customer support. Asus Laptop Stuck in Aptio Setup Utility
Jan 28, 2016 | Computers & Internet
How do I get unstuck from Aptio Setup Utility?
About 5,420 results (0.43 seconds) Search Results
    How to Solve Problems With Aptio Setup Utility - Tom's Guide
    www.tomsguide.com/answers/id.../solve-problem-aptio-setup-utility.html
    Dec 6, 2015 - When I switched on my laptop it shows Aptio setup utility. How do I solve this? ... My Asus is stuck in this mode. The instructions to this seems ...
    ASUS Ultrabook Stuck on/in Aptio Utility Setup - Tom's Guide
    www.tomsguide.com/.../id.../asus-ultrabook-stuck-aptio-utility-setup.htm...
    Nov 14, 2015 - I have an asus si30401u ultrabook that refuses to exit aptio setup utility ive attempted the the fix at ...
    Computer stuck on Aptio setup utility screen. - Microsoft Community
    answers.microsoft.com/...stuck...aptio-setup-utility.../50be23d9-ea0c-483...
    May 17, 2014 - My asus laptop is stuck on the aptio setup utility screen how do I get it back to the start screen.
    Stuck in Aptio Setup Utility - Windows 8 and 8.1 - Geeks to Go!
Jan 05, 2016 | Computers & Internet
Why is my laptop comming up with aptio setup utillity
Try this
1/ Select the Boot menu in the Aptio setup utility, select 'Launch CSM' and change to enable
2/ Select the Security menu n the Aptio setup utility, select 'secureicon1.png Boot Control' and change to disable
3/ Select Saveicon1.png & Exit and press 'yes'
4/ Hold down the powericon1.png button until the unit switches power off completely
5/ Switch back on and continually press the F9 button for about ten seconds; this should now allow the unit to boot up into the Windows Recovery menu
6/ Select 'Advanced Start Up' and wait until the recovery menu appears
7/ Select ' Advanced Options'
8/ Select 'System Restore' and select a date prior to when the problem occured
System Restore worked perfectly for me; good luck
Aug 03, 2014 | ASUS Computers & Internet
Stuck in Aptio seup Utility
1. Power off the computer by holding the power button.
2. While holding down <Ctrl> and <Home> together, press the power button. Keep holding <Ctrl> and <Home> until you see "EZ-flash" start.
3. Let EZ-Flash run (will shut down automatically when finished running)
4. This is supposed to reset BIOS back to factory installed.
If this works, be sure to backup any data you may have on this machine. Then you may need to look on the manufacturer's site for any BIOS or driver updates.
Source: http://rog.asus.com/forum/showthread.php?35315-G75VW-stuck-on-Aptio-Setup-Utility-since-a-Bios223-updating
Apr 10, 2014 | ASUS Eee PC X101CH-EU17-BK Matte Black...
How do I exit Aptio Setup Utility ?
Try running the System Configuration Utility.
- press windows logo + R and type "msconfig"
-go to the startup tab and uncheck the application
-click apply, then ok
-restart your computer
Dec 16, 2013 | Acer Aspire 5100 Notebook
Can not get out of the aptio setup utility screen
if your notebook is a Samsung, just return it back. I had the same problem. samsung service changed my HDD, the problem was seem to be OK. but after 3 h I got my pc from service it crashed again.
Apr 01, 2013 | ASUS Computers & Internet
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
