Question about Pioneer VSX-523-K 5.1 Channel AV Receiver Featuring Made for iPhone Co
Can't get osd on samsung f8000 and pioneer vsx523
I have set up everything (well just tv at this stage) to the vsx523 with hdmi and yellow composite video cable to Samsung f8000 nothing. tv just says no signal, but it is plugged in well. The radio works fine on the receiver, but I need to see the osd in order to set up speakers. everything is plugged in like it says in the instruction manual. what else could I do?
SOURCE: Receiver: Pioneer Elite 72TXV Verizon
Called Verizon automated help desk. They rebooted DVR remotely and solved the problem.
Posted on Mar 29, 2008
SOURCE: Pioneer VSX-D608 Optical connection
The manual states that the default association of each digital input in as follows:
  • Optical 1: CD
  • Optical 2: MD
  • Optical 3: TV
  • Coax: DVD
Use the "Signal select" button to set the receiver to use a digital input, and the Dolby/DTS button (above "Signal select") to enable decoding.
As samz11 stated above, a remote is required to alter the digital input mapping.
Posted on Feb 18, 2009
dunnbiker
  • 8546 Answers
SOURCE: pioneer receiver vsx-d510 sub not working
Rear Surrounds are not supported on this unit, they would be the 6th and 7th channels in a 7.1 rig. I think you mean Surrounds (channels 4 and 5 in a 5.1 rig).
Lets ponder: How is there any relationship between Surrounds and your separately-amplified Subwoofer? I don't see it, unless you inadvertently chose OFF for the Sub definition when you were in the Speaker selection menus adding the Surrounds. Look again.
Posted on Jan 19, 2010
SOURCE: Sound Just Stopped Working
I have the same problem with my 49txi, and I called pioneer and a repair shop as well. Both told me that the 49txi has a known problem with over heating and that its boards unsolder themselves. I would have thought Pioneer would stand behind something this expensive, but that was the old Pioneer in the 80s, and the new Pioneer says we are on our own.
Posted on Feb 02, 2010
  • 15 Answers
SOURCE: Pioneer vsx-819H: MCACC setup won't display on tv
Its because the pioneer does not display menu options through hdmi. You have to hook up basic yellow composite to monitor out.
Posted on May 03, 2010
Trying to connecting my Bose lifestyle to my Samsung led smart tv to play a DVD with a yellow video cord and picture is blurry and double and has jo color? Any ideas how to fix Bose lifestyle is older...
Without the specific LifeStyle model # it's not easy to say for sure, but it sounds like you might have a composite cable plugged into a component video output of the Bose. Assuming it does not have HDMI output, it might have white/red/yellow (RCA-type jacks, aka "phono") and that yellow jack is a composite video output. It would plug into the same color jack on the TV. There are also RGB (Red/Green/Blue) component outputs on many devices and similar inputs on the TV, so you have to match like color out to same color in and make sure the TV is set to composite video input, not HDMI nor component.
Also could just be a bad cable. It's always the cheap things that we overlook, so with the same output/input setup, assuming you match type, try a different cable. The actual color of the end on the cable does not matter, but don't plug a yellow-colored output jack to a red, white, blue or green input jack on the TV - that won't work.
Feb 18, 2015 | Samsung Televison & Video
Tip
How to get OSD on TV for a Pioneer Receiver
OSD for on your TV for a Pioneer Receiver setup menu. (It doesn’t matter what make your TV is).
Connect the MONITOR OUT video jack on the receiver to a video input on your TV. Use a standard RCA video cable to the composite video jack.
Turn your TV on and put your TV onto AV3. Turn your receiver on, then on your remote control push the receiver button (this is not the on/off button, there is another button with receiver written on it) then push the setup button on your remote control. You should get the OSD menu on your TV for the settings for your receiver.
on Jan 03, 2010 | Audio Players & Recorders
Cannot get a display to appear
I imagine you can't see the set up menu to assign the proper type of video input (analog , composite , HDMI ) . On the 818 and previous series the set up menu will only appear through a Component (RCA green , blue and red ) or Composite (RCA yellow) BUT NOT THROUGH HDMI CONNECTION! That's why it will be necessary to run on of those two cable , match the input on the TV , on the Pioneer remote press Receiver then setup and the Menu should appear.
Hope i could help.
Jan 19, 2014 | Pioneer VSX-818V-K Receiver
Samsung lcd 720 ln32b360 doesn't fill screen in 16:9 mode. Went through tv setup, connected it to hd box (verizon Fios) plays all HD channels but does not fill screen as it should. TV is connected to set...
If by regular cables you are talking about the standard red/yellow/white composite cables, then, yes, it will affect HD as composite cannot send an HD signal. Only HDMI and component (red/blue/green video only) cables.
Change to HDMI and let us know if it works for you.
Jan 07, 2010 | Samsung LN32B360 32 in. LCD HDTV
I used to get OSD on the TV with my receiver, but it has gone and I don't know what setting to do to get it back. It is a Pioneer VSX-917V-s/-K. Thanks
did you happen to change to cable connecting the Reciever to the TV to an HDMI?
please note that the OSD will not appear if you have connected using the HDMI output to your TV.
Use component, S-video or composite connections for system setup.
Dec 30, 2009 | Pioneer VSX-917V-K Receiver
60GB PS3 had been hit by a power surge. HDMI not working.
hook up the ps3 thru the regular yellow composite and HDMI. Go into the settings and change the output to HDMI and then see if you can get video thru the HDMI, if you don't then the mainboard is bad and you would have to send it to Sony unless you can get your hands on another broken sony ps3 with a good main board.
Sep 04, 2009 | Sony Playstation 3 (PS3) Console
I'm trying to connect a WDTV to my SAMSUNG LE32R74BDX by HDMI but the HDMI source isn't found by the TV, it simply stays greyed out, should devices like this be plug and play or am i missing something?...
I had the same problem. Had to connect using the composite cable, when to settings, changed it to HDMI. This turn the display on my TV off again. Then plug in the HDMI and it worked!
I also expected it to be plug and play... Hope this works for you...
Jun 22, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
No OSD on TV connected thru composite video (Monitor Out)
hello you need the s-video/sound usually four pins in each end connect to s-video not composite video..saludos
Nov 22, 2008 | Onkyo TX-SR606 Receiver
Connection of PS3
You will have to connect it to the TV using the composite cable to change the settings. This is the cable with yellow red and white connectors. Connect it to one of the composite inputs on the TV. You should be able to leave to HDMI connected at the same time so that once you make the change, you can change to the HDMI input and see if it works.
Oct 26, 2008 | Televison & Video
Connection problem
The best hook up for this unit is to use the hdmi if your samsung box offers hdmi output. The panasonic vcr should be hooked to any one of the composit video inputs with the yellow video cable and the red and white audio cables. If the vcr does not have composite output then use a rf (coax cable) to antenna a input and put the tv on channel 3 or 4 as vcr is set for.
Jan 13, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Pioneer VSX-523-K 5.1 Channel AV Receiver Featuring Made for iPhone Co Logo
26 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
