Starting problem gorenje Wa73161
The washing machine won't start. It just make a "beep" noise and nothing Else happens. There are no fault message in The display. The machine do not take Walter in, The water supply is okay.
catriver
  • 878 Answers
SOURCE: Error code F 9
Pfenn, If the overflow contact on the pressure switch is closed for more than 60 seconds this F09 code will appear. Here are some things to check: make sure the drain hose is not plugged or kinked., Open the bottom panel by removing the screws on the bottom and you will see the pump filter in the center. Open it and clean all the debris out of it. Check the harness to the drain pump motor itself. I believe your problem might be in a lot of gunk in the drain filter...Good luck
Posted on Jun 25, 2006
  • 1462 Answers
SOURCE: Wash starts it fills with water then stops and wont wash
problem may just be that drum is not turning so you think program is stopped. try cancelling and select spin program and see if you get spin
Posted on Apr 01, 2007
  • 1073 Answers
SOURCE: Electrolux 1087 E90
call frigidaire for factory service or have the dealer replace it
Posted on May 09, 2008
  • 1294 Answers
SOURCE: No movement, then loud beeping alert
Check your exit hose spigot, it may be clogged. This is if your filter is all clean(ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Posted on May 10, 2008
  • 127 Answers
SOURCE: gorenje washing machine on display shows F31. what
it means"The connection to the tacho generator is open or short-circuited". that means the motor is not turning. 99% it is the brushes (20 eu) and it wil work again.
marko
Posted on Aug 13, 2009
I have a Gorenje wAshing machine, model no. WA65205, for more than five years. Recently,its touch screen control display does not respond to my command. I touch it and nothing happens. I am so helpless. I...
I have the same problem on mine right now. Very annoying!!! I have had it before and it has solved itself somehow. My guess is moisture where it shouldn't be.
I will return if I get it to work again.
Jun 05, 2011 | Washing Machines
My fisher and paykel WG708 top load washer fills with water. No rotation of the washer occurs. No machanical sound happens. 4 lights stay on and makes beeping noise. Water will drain but no spin happens?
Hi just read your posting.Could you confirm the model number for me,Is it GW708?Now the lights that stay on when the machine is beeping will be in a row of 8 lights.Starting from left to right which ones are lit when the machine beeps,Is it the 2nd and 4th or the 1st and 6th ---etc---?Please reply with additional information and I can help you rectify this fault.
Aug 06, 2010 | Fisher and Paykel Washing Machines
Gorenje WA72145BK fault 6 displayed on my LED
I have the same problem. Any solution? Thanks!!
Dec 12, 2009 | Washing Machines
I have just bought a brand new top loader but it will not start
Probably too many clothes in the washer. Remove some and restart.
Aug 20, 2009 | Washing Machines
Beeping BUT not Starting
This sounds like a speed sensor problem located on the motor.e.g. when you turn your washer on ,as the water comes in the tub turns if it dosen,t the speed sensor (if crook)doesent send the message to the processor and will go into fault mode.If lid & out of balance switch are ok then this will be your problem.Kind Regards.
Jul 07, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Hi, My washing machine is not completing the washing cycle, it gets stuck when the water should go out of the tank. There is anormal noise like if something does not have the strengh to pull the water...
well Xavier, looks like you have a bad water pump in your machine, or its clogged up with debrie, either way you will have to have a qualified tech check it out unless you are extreamly handy with replacing pump motors, its not to easy to do, hope that helped ya
Jan 19, 2009 | Refrigerators
Gorenje PS400GX Shorting
likely the motor has developed a short. It may be wet from a failed tub seal.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 14, 2009 | Washing Machines
My tricity bendix washing machine flashing and beeping end light
Hi, we had something similar happen just before christmas. Our machine seemed to finish a cycle and started making beeping noise with end light flashing. Then when I switched it back on to do another load it just started beeping with end light flashing no matter what cycle was selected. Engineer has been out and advised that it is a fault with the motherboard so has ordered another one. Hope this is of some help. Machine was tricity bendix aw1400w.
Dec 14, 2006 | Tricity Bendix AW1400W Front Load Washer
Washing Machines Logo
60 people viewed this question
Top Washing Machines Experts
