Question about Canon EOS 1100D / Rebel T3 Digital Camera
Canon 1100d won't turn on
Tried different batteries and recharged one just in case. No help camera won't turn on.
advance
  • 107 Answers
SOURCE: camera will not go on
If you push the power button and do not see any signs of life at all, it is most likely a blown fuse. In this model disassembly is required to replace the fuse, and it is soldered onto the main power board. If there are signs of life, but the camera does not function there are other explanations. Jammed lenses are the most common cause of power-on failure. Check with your manufacturer for recalls and warranty service information. Failing that you can find a repair provider online. David Millier Advance Camera Repair
Posted on Mar 13, 2007
pishta68
  • 579 Answers
SOURCE: Err CF
TRy and reformat the CF card through the camera. Youll lose the pics for sure but you cant see them anyway. You can also check for bent pins in the CF slot. Sometimes if you shut down the camera in mid write to the card, itll mess up the cards FAT (file directory)
Posted on Feb 24, 2008
SOURCE: canon powershot sd900
I have the same problem, but i didnt drop mind. The lens where out when i put on da pack and now it won't start.
Posted on Apr 04, 2008
mcomijohns
  • 477 Answers
SOURCE: camera was working fine...all of a sudden,it would not turn on...thought maybe battery was dead,tried to recharge it,light would not go on,tried another charged battery,still would not work
This error is either a flash circuit or a lens error. One of the two need replacement.
Posted on May 25, 2009
SOURCE: Canon 5D won't turn on
my 5D have same problem 2......how much$ if i sent my 5D to canon and replace the power supply unit?
thx
Posted on Jan 05, 2010
What is error 30 for t3.
Error 30 means "Malfunctions related to the shutter have been detected". Recharge the battery, remove and replace it after about 20 seconds, then do a reset to default settings through the camera menu. If it still won't work you'll need send it in for repairs.
Aug 21, 2014 | Canon EOS 1100D / Rebel T3 Digital Camera
Why my charger is blinking
There is a problem with the battery charger. See "Troubleshooting Guide" on page 242 of the manual: http://gdlp01.c-wss.com/gds/0/0300004730/02/eosrt3-eos1100d-im2-c-en.pdf
Mar 22, 2014 | Canon EOS 1100D / Rebel T3 Digital Camera
Battery charger flashes yellow light
why my canon battery 1100d charger is blinking
Nov 13, 2012 | Canon EOS 1100D / Rebel T3 Digital Camera
My Canon Camera 1100D after take 1 shot an err30 appear
Err30 indicates a problem with the camera shutter. Turn off the camera. Then remove the battery, take out the memory card, and then remove the lens. Clean the lens contacts and replace the lens (make sure that it is a Canon lens). Then replace the memory card and the battery. Then turn the camera back on.
If the error recurs, the camera needs service. Contact Canon.
I hope the problem is resolved by the above steps.
Oct 11, 2012 | Canon EOS 1100D Twin Kit with 18-55 IS II...
Canon Powershop A430 Digital Camera wont work with new batteries. I tried switching and used both alkaline and some regular ones but it keeps saying the batteries are low. How can I fix this?
If the camera has a lens that extends when you power-on, it may have failed to park completely when power went off, due to the weak battery.
Gently press on the front of the lens barrel to attempt to seat the lens.
Then (with a good battery) turn-on the camera.
If you are currently using the NiMH AA rechargeable batteries, I would suggest you try standard Alkaline AA batteries. They have a bit more voltage than the NiMH and it might make a difference in this case.
If that does not work, you should phone Canon Service and see if they have any suggestions.
I am sure they have encountered this problem before.
Hope this helps,
Feb 18, 2011 | Canon PowerShot A430 Digital Camera
We have a cannon a2000is. After replacing the batteries and printing the pictures off the memory card the camera will not come back on. The screen says Cannon and the indicator light blinks for aprox 20...
It sounds like a low power startup. Are you sure the batteries that you are installing are good? If they're Dollar Store "Super Heavy Duty" batteries, that's likely your problem (shelf life has been exceeded).
Recommend trying to start the camera with premium alkaline, or best yet, rechargeable batteries (they have the most power, and save you money too!). If the above doesn't work, recommend contacting Canon, especially if your camera is less than a year old. The camera in that case would be eligible for warranty repair.
Oct 15, 2010 | Cameras
My camera won't turn on, even though the batteries are fully charged. HELP!!!
the batteries might be to old. rechargable batteries go bad after a lot of recharges. you can get new batteries at wallmart and other stores!! Good Luck!! :)
Apr 03, 2010 | Canon PowerShot SD400 / IXUS 50 Digital...
Battery Problem
I figured out the problem. My AA battery recharger was not making good contact, so although it said the batteries were recharged, this was not the case. After fixing this and getting full recharges, the problem went away.
Aug 31, 2005 | Canon PowerShot A70 Digital Camera
Canon EOS 1100D / Rebel T3 Digital Camera Logo
176 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
