Question about Kitchen Ranges
Is it possible to replace ecu board in Maytag Model MGR5710ADW?
Half of the numbers dont light up on the clock
2 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: Maytag Stand Alone upright Range/ Oven model
Self cleaning functions often blow fuses and relays when used.
Your relay that is blown is located behind the rear panel in the oven.
Posted on Apr 12, 2011
How do i replace ECU/ECM on 1996 toyota celica?
if it is just the fuel problem with the ecu, replace the chip in side the ecu from the new one you got as then you dont need to re program it then. the fuel chip and control is inside the ecu. you used to be able to get the chips for them and program the codes onto them. should be clip in type chips. if its soldered type as there are 2 types of ecu boards with same part number. you will need to un solder the chip.
Dec 20, 2013 | Cars & Trucks
Hi, We have a Maytag gas range. I believe it's a mgr5710adw the number is wore off and unfortunately we didn't write it down in our manual. Anyway, when using our bake burner sometimes it will...
IF the model number you have listed is what you belive to be correct thepart number for that gas safety valve is 74006427 this link i have included isa picture of it. Does it look EXACTLY like the picture if yes it will work http://www.repairclinic.com/PartDetail/Gas-Valve-Assembly/74006427/895773
GENE
Sep 23, 2011 | Maytag 30" Self-Cleaning Freestanding Gas...
When pushing the button bake and broil the red light starts to blink on lock ? this happened after i woke 1 morning n noticed there was no time where the clock was, it was all dark n nothing worked, after...
if the clock is blank it's bad and you have to change out the clock assy. if that's your model number MEW5527B it says your part is
WP74009198 and it's around 260 dollars but this must be an older wall oven because nobody has it in stock,you can go here,put your full model number in and go to control panel and look up your computer board or clock assy. same thing
https://www.searspartsdirect.com/model-number/MEW5527BAW/3048/0125300.html
Feb 06, 2018 | Maytag MEW5527B Electric Single Oven
No lights on the control panel including the clock. the burners work but no lights at all for the oven or timers ets. MAYTAG Model: MER6769BAW
I would check the wiring first. Look for any loose connections to the board or any burnt wires. If all that is good you have no choice but to replace the clock.
Sep 17, 2010 | Maytag MER6769 Gemini Electric Kitchen...
I'm getting an error message F2 and the broiler will not turn off. It came on bt itself while the bake was on!
F2 on most jenn-air ranges/wall ovens indicates a fault in the oven sensor or relay board. I'd first check the sensor, (part # 12001655) it should ohm out at approx. 1100ohm @ room temp. If it is OK, it's probably a faulty "broil" relay and suggest replacing the power relay board.
The board (usually seperate from the clock and just behind it), on earlier model jenn-air/magic chef/norge/maytag etc. where known to burn up. part # VO4100260. double check those numbers with your model number at your local parts depot or service provider, those are just the most common for maytag built units.
hope that helps,
good luck
Oct 03, 2009 | Ovens
My Maytag dryer model number MDE5500AYW has lights on, but won't switch settings. It is stuck in time dry at 18 minutes. Yesterday it was on sensor dry 47 minutes. Do I need a new control board inside...
OK, your control board and LED are integrated, so you will need to just replace the control board. I would try a hard reset before replacing the board. Pull the plug or, shut down the appropriate breaker switch for 5 minutes. Re apply power after the 5 minutes are up. if you continue to experience this fault, replace the control board asap.
CONTROL PANEL(CLICK HERE TO ORDER)
Aug 28, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Error message and alarm
These are the fault codes for your unit
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
Hope this helps, Please take the time to give this solution a fix ya rating
clarkco
Feb 27, 2009 | Maytag MGR5870 Gas Kitchen Range
Oben takes half an hour to heat up
I doubt its the igniter. It could be a faulty gas valve or maybe the orifice is blocked, and not letting enough gas into the burner
Jan 28, 2008 | Maytag PGR5710 Performa Gas Kitchen Range
Won't spin
you need part number 12002039. its a motor/ motorcontrol kit. there have been alot of problems with this motor so maytag redisigened it
Nov 26, 2007 | Maytag Neptune MAH5500B Front Load Washer
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
