Question about Suunto Ambit GPS Outdoor Wristwatch
Suunto polarity charger - Suunto Ambit GPS Outdoor Wristwatch
Suunto Core watch - my watch is locked in the compass mode. How to I get it unlocked
RTFM
Suunto Core User Guide
ns.suunto.com/Manuals/Core/Userguides/Suunto_Core_Userguide_EN.pdf
This User Guide explains the Suunto Core features, how they work, and how ... nearest watch store to get the needed adjustments correctly done for you.
How to Set Up a New Suunto Core - YouTube
? 6:49
https://www.youtube.com/watch?v=_zywJcNNowU Jun 13, 2015 - Uploaded by Wearable4U
Great tutorial, clear and precise (beats reading the manual) many thanks ;-) ... Hi there. Just bought a suunto core ...
SUUNTO CORE USER MANUAL Pdf Download. - ManualsLib
https://www.manualslib.com > Brands > Suunto Manuals > Watch > CORE View and Download Suunto Core user manual online. Suunto Core: User Guide. Core Watch pdf manual download.
SUUNTO CORE QUICK MANUAL Pdf Download. - ManualsLib
https://www.manualslib.com > Brands > Suunto Manuals > Watch > CORE View and Download Suunto Core quick manual online. Suunto Core: Quick Start. Core Watch pdf manual download.
[PDF]Quick Guide - Trekkinn
www.trekkinn.com/images/pdf/especificaciones/eng_suunto_spec_10086.pdf Suunto Core brings together an altimeter, barometer and an electronic compass ... Please refer to the User Guide for detailed information on setting these. Suunto Core watch Google Search
Jun 17, 2017 | Suunto Watches
I have Problem with the Suunto Pc Pod Wireless Transmitter Driver for Suunto USB PC pod with windows 7...
I found out that this is because the wrong drivers are installed.
When you install the suunto software the usb drivers are stored under C:\Program Files\Suunto\USBDriver. This contains more than one driverset. See if you can find this.
Then go to Control Panel\Hardware and Sound\Devices and Printers and find your Suunto device. You probably have only one device and will miss Suunto Usb Serial Port.
Now open the deve and change the drivers, via manually select . Select browse and go to C:\Program Files\Suunto\USBDriver. Press Enter. The program will see that there is more than one driver set and offers you a choice.
Previously it has automatically selected the newest one, which unfortunately did not work in my case. Select the oldest set and the program will install the drivers,
Now you will see in Control Panel\Hardware and Sound\Devices that you have 2 devices suunto pc pod and suunto usb serial port. And the program will run and be able to connect to the watch
Good luck
Timco
Dec 13, 2010 | Suunto Pc Pod Wireless Transmitter
I have a suunto pc pod. my suunto t3d watch can connect to the pod but the pod cannot connect to the software installed (training manager lite) since my pc cannot find any drivers to install for the...
Good luck
Timco
Oct 02, 2010 | Suunto Pc Pod Wireless Transmitter
Driver for Suunto USB PC pod with windows 7 64-bit
I had a problem with the drivers for W7 32 bit, maybe it's the same problem:
Good luck
Timco
Aug 02, 2010 | Suunto Pc Pod Wireless Transmitter
I'm trying to reset the altimeter and sea pressure but the watch. I've followed the instructions but the watch more often that not reverts back to default settings or does not respond to the calibrations...
http://www.suunto.com/en/Products/Outdoor_Sports_Instruments/Suunto-Vector/Suunto-Vector-black/#Manuals
If you continue to have problems with your watch, and the instructions in the user manual don't resolve your problem, you may have to return the watch to Suunto.
Your watch must be registered with them, you'll need the serial number of the watch, which is located on the back case. You'll have to get an RMA from Suunto in order to send it back to them.
Here's their warranty info: http://www.suunto.com/en-us/Support/Warranty-information/
Oct 11, 2009 | Suunto Vector Wristwatch
Pressure gauge problem with Suunto Cobra 2
Salva,
The error in pressure is actually a "feature" of Suunto computers. Suunto is probably one of the most conservative brands out there, and many experienced divers tend to stay away from them for that very reason.
The manual actually calls out this "feature" on page 27.
The remaining air time calculation includes a 35 bar/500 psi safety reserve. This means
that when the instrument shows the air time to be zero, there is still about 35 bar/500 psi
of pressure left in your cylinder, depending on your air consumption rate.
http://media.suunto.com/media/suunto/manuals/en_US/cobra2_usersguide_en_v3_m56577569830698583.pdf
Regards,
Darlene
Jul 30, 2009 | Suunto Cobra Integrated Computer
Changing metric to Imperial on Suunto Vector
It's in the manual. I did it on mine.
Dec 25, 2008 | Suunto Vector Wristwatch
Suunto Ambit GPS Outdoor Wristwatch Logo
13 people viewed this question
Top Suunto GPS Experts
Are you a Suunto GPS Expert? Answer questions, earn points and help others
