Question about Mad Catz Bluetooth Headset for PS3
After glow driver - Mad Catz Bluetooth Headset for PS3
96 Ford F-350 Turbo Diesel. Replaced 4 glow plugs on driver side. After replacing the glow plugs and the glow plug relay, the truck will crank slow and not start. Batteries power drained quickly while...
Have a load test done on the batter to check for failing cells. For diesels to start any thing less than a fully charged battery good battery is a waste of time as the engine needs fast RPM to heat the air to ignite the fuel and slow rpm's just doesn't cut it.
Jan 19, 2014 | Ford F-350 Cars & Trucks
How to charge the starter
Stephan, plug the wall charger into an outlet, then attached the glow driver to the end of the cable same as you would if attaching it to the glow plug. Generally and push and twist. When you get it on there, a charge light on the charger will light up. Let it charge overnight. Good luck
May 11, 2011 | Duratrax Ultra Slim Aa Glow Starter
PO380 and p1316 what do thies coads mean.
P0380 - Glow Plug/Heater Circuit "A" Malfunction
Bad glow plug. The glow plug system is used to assist in providing the heat required to begin combustion during cold engine temperatures. The glow plugs are heated before and during cranking, as well as initial engine operation. The engine control module (ECM) controls the glow plug ON times by monitoring coolant temperature and glow plug voltage. The California Glow Plug system has eight individual glow plug supply circuits between the controller and the glow plugs. If the feedback voltage from the controller to the ECM is not within range, DTC P0380 will set.
- The glow plugs are commanded OFF and the glow plug feedback is more than 2 volts. or
- The glow plugs are commanded on and the glow plug feedback is not between 5 volts and 6.2 volts.
Keep in mind that the "wait to start" light only comes on while the voltage is dropping in that circuit. This should only take 3-5 sec's. If it takes longer, refer to your "Likely problem" you listed above. That would be the Heater Module. If your glo plugs stay on, your batteries would be dead in no time. If any of your plugs go bad, they would each be listed on the reader per cyl 1-8. If you need to change the Module,
P1316 - Injector Circuit / IDM Codes Detected.
This code indicates that codes are stored in the IDM
Possible causes are as follows:
- Injector(s) or circuit(s)
- Open or shorted IDM enable circuit
- Open/short in EF circuit
- Open/short in FDCS circuit
- IDM relay
- IDM powering circuits
- Failed IDM
- Failed PCM
Check your Injector Driver Module wires, circuits 821 (Brown/Orange) and 818 (Grey/White) between the PCM and IDM. On the IDM side, the connector pin numbers are 17 for circuit 821, and pin 4 for circuit 818. You should check for high resistance in that circuit, short to ground, or open circuits. If wiring checks out good, you may need to replace your IDM. It's not uncommon for water intrusion into the module, due to its mounting location. Also check the engine wiring harness where it routes up over the driver side shock and/or driver side valve cover. That code is either a key-on/engine-off or a continuous memory code.
Hope this helps (remember to rate this answer).
Feb 04, 2011 | 1999 Ford F350 Regular Cab
Could a faulty coolant temp sensor make the glow plugs run all the time on a 1983 Mercedes 300CD?
No the glow plugs circuit is separate. They actually are on a timed delay shut off. Check the glow plug relay module behind the driver side headlamp assembly. If the light on the cluster is staying on all the time it's simply letting you know there is a fault in the glow plug circuit. Doesn't actually mean that the glow plugs are staying on all the time. You might just have a bad glow plug which is breaking the circuit therefor the glow plug light stays on. To check this use a test light and have someone turn on and off the ignition to see which plug doesn't light up.
Oct 11, 2010 | 1983 Mercedes-Benz 300-Class
I have a jeep cherokee and an engine light is on the fault code i am getting is p1265 any one help please
P1265 = glow plug #3 control circuit low.
Looks like a problem with your #3 glow plug,either the glow plug itself or the GP driver in the PCM.
This would explain the starting good one time then hard the next. I would test the glow plug if it is good there may be a problem in the PCM (power trans control module). Are you getting any other fault codes this would point to a bad PCM.
Hope this helps (remember comment and rated this) TY for using Fixya.
Apr 07, 2010 | 2005 Jeep Grand Cherokee
7.3 Liter Ford Diesel
check glow plugs wait a little longer beforecranking after light has gone out
Feb 26, 2010 | 1995 Ford F250
1985 Mercedes 300SD Glow plug light does not come on.
Glow plug fuse under hood of car, driver side close to head light . There is a cover pull off and see the blown fuse.
Nov 23, 2009 | 1985 Mercedes-Benz 300
Where can I find the schematics for a 1995 Ford F250 7 3 liter turbo diesel? We're able to start the truck on ether, but she won't continue to run. We're guessing it's the fuel pump, possibly the filter or...
drain water from filter. change filter. prime system.
If it doesn't fix it, check glow plugs to be sure they are preheating combustion chamber.
Fuel Supply System The fuel system consists of the following three major subsystems:
  • Fuel supply system
  • Injection control pressure system
  • Fuel injector assembly
The fuel transfer pump is a camshaft-driven, two-stage diaphragm/piston pump mounted in the engine "V".
Fuel is drawn from the fuel tank through the primary filter by the diaphragm section of the transfer pump. Pressurized fuel (approximately 28 kPa [ 4 psi]) is supplied to the secondary filter and returned to the second stage of the transfer pump. The piston-actuated second stage of the transfer pump supplies 276-345 kPa (40-50 psi) of fuel to the rear of each cylinder head where it flows to a fuel rail machined in each head.
Drillings in the cylinder head route the fuel to the plunger area of the fuel injector which can pressurize the fuel to 124,110 kPa (18,000 psi) for delivery to the combustion chamber via a conventional nozzle/valve tip arrangement.
Return fuel is plumbed from fittings at the front of each cylinder head to a junction block which contains a piston/spring type regulator valve that maintains pressure to approximately 414 kPa (60 psi). A de-aeration bleed orifice between the fuel filter and the regulator block vents air trapped in the fuel filter. Most of the fuel from the regulator is recirculated to the inlet of the piston (high pressure) stage of the transfer pump. Fuel return to the tank is limited to 30-38 liters (8-10 gallons) an hour through the use of a 0.0008mm (.020-inch) orifice. This prevents the fuel from overheating in the tank.
Injector Driver Module The injector driver module (IDM) is used in conjunction with the PCM to sequentially control power to the fuel injectors on the 7.3L DI turbo diesel engine. The PCM processor generates two digital control signals for the IDM: fuel delivery control signal (FDCS) and cylinder identification (CID). The FDCS signal is used by the IDM to control injection timing and injection duration. The CID provides synchronization to the engine's first and fifth injector (firing order). The IDM verifies that FDCS and CID occur at valid timing intervals. The IDM outputs an electronic feedback (EF) signal, to the PCM, which is a delayed mimic of the FDCS for verification. Selected diagnostic information is also passed to the PCM via the EF signal in run mode.
The IDM is a high-energy power supply which acts as an energy distributor to provide regulated injector energy and control to the unit fuel injectors, based on FDCS and CID commands from the PCM. All IDM components are solid state; there are no user serviceable parts or adjustments. The IDM internal power supply uses a DC-to-DC converter to boost the supply voltage (VBATT) up to 115V DC. This supply is required to overcome the initial impedance of the injectors, ensuring rapid turn on. There are two high side drivers, one for each bank (left and right cylinder bank), and eight low side drivers, one for each injector. One high and one low side must be turned on to energize an injector. Once synchronized with the PCM, the IDM will select the proper low side driver (enable) and control the corresponding high side driver to regulate the current to an injector.
Continuous and on-demand system diagnostic information is provided between the PCM processor and the IDM via the EF signal. During normal operation, the IDM can indicate to the PCM that an injector low side short to ground has been detected, or that the IDM has lost synchronization.
The IDM constantly performs self-diagnostics and also monitors the injector circuits for electrical faults. Any fault codes set are transmitted via the EF signal to the PCM during Key On/Engine Off On-Demand Self Test. If the PCM is unable to obtain diagnostic information from the IDM, DTC 1668 is set.
Glow Plug Control Glow plugs are used to warm the cylinders to improve cold-engine starting. The PCM uses the engine oil temperature (EOT) sensor and barometric pressure (BARO) sensor to determine how long the glow plugs will be on. The PCM energizes the glow plugs longer if the engine is very cold or if the barometric pressure is low at high altitudes.
The PCM controls the relay that supplies power to the glow plugs with the glow plug control (GPC) signal. When the GPC signal is grounded by the PCM the relay closes, turning the glow plugs on.
The glow plugs are controlled by the following sequence:
  1. PCM energizes the glow plugs.
  1. The PCM energizes the glow plugs immediately after the ignition is placed in the ON position.
  1. The PCM then determines how long glow plugs will be on based on EOT sensor and the BARO sensor. The required time to warm up the cylinder decreases the engine oil temperature and barometric pressure increases at low altitudes.
  2. ------------------------------------------------------
Glow Plug Lamp Control The glow plug lamp (GPL) signal controls the WAIT TO START light located on the instrument panel. This light is used to indicate when to start the engine. The cylinders are being warmed by the glow plugs during and after this light is lit. The PCM energizes the glow plug lamp longer if the engine is very cold or if the barometric pressure is low.
When the GPL signal is brought low, the "Wait to Start" lamp is turned on.
The glow plug lamp is controlled by the following sequence:
  1. PCM lights the WAIT TO START light after a key on reset occurs.
The PCM determines the glow plug lamp activation time based on engine oil temperature, barometric pressure and battery voltage.
  1. PCM turns off the WAIT TO START light.
The glow plug lamp is turned off when the timer counts to the number of seconds specified by the PCM. The glow plugs will normally remain on longer than the "Wait to Start" lamp.
Sep 22, 2009 | 1995 Ford F250
Prescario v6000 mute buttons and sound button dont work
you have to install the driver
get you driver driver through hp site
Oct 04, 2008 | HP Compaq Presario V6000T Notebook
Mad Catz Bluetooth Headset for PS3 Logo
Top Mad Catz Video Game Consoles & Games Experts
Robert Little
Level 1 Expert
Dave
Are you a Mad Catz Video Game Console and Game Expert? Answer questions, earn points and help others
