Question about SanDisk Ultra Electronics - Others
Brother printer sd card - Ultra SanDisk Electronics - Others
How to download photos from SD card slot
If your computer has an SD card slot the appropriate program should automatically open for downloading. I am a Windows user so I can go into Windows Photo Gallery. From there I can view the pictures when I click the recent import icon
Jan 01, 2013 | Brother MFC-5460CN InkJet Printer
Can I scan to an SD card
If the scanner normally asks where you want to save the scan then yes, if it automatically saves to it's own default folder then it is just a matter of copy and paste onto your SD card..
Jun 22, 2010 | Brother MFC 210C All-In-One InkJet Printer
Won't read sd cards
the pc hooked to the printer will show the HD card as a hardware addition. Just hook everything up - start the software on the pc and plug the HD card in. There will be a window that opens on the pc showing the HD card. OR - go to my pc - check for drives - the HD card will read as the last or next to last drive on the list.
Jun 12, 2010 | Brother MFC 240C All-In-One InkJet Printer
How to view photos from sd card
If you are useing your sd from your printer go to my computer and you will see your sd there just click on it to open and you will see all your photos
Jan 23, 2010 | Brother MFC 420CN All-In-One InkJet...
Can the Brother MFC-210C read a Turbo SDHC Card ?
No, SDHC cards are not backwards compatible with SD formated devices. You will have to get an ungraded SDHC reader or SDHC device you can plug into your PC to read it that way.
Dec 28, 2009 | Brother MFC 210C All-In-One InkJet Printer
My smaller memory cards work, but my 4gb card says media error in my brother printer/scanner when I put it into the usb port (photo capture). Tried it dozens of time, doesn't work, but I was able to read...
Many older system will only support standard SD cards up to 2GB and HD SD cards will go above 2GB. It is a limitation of the printer and not an error with the card.
Nov 21, 2009 | SanDisk 2GB microSD Memory Card
Printer says: media error, please reinsert
The most likely problem is that the Printer cannot read SDHC cards. Most cards over 2 Gig are called SDHC you can see on the card if it is infact one of those cards. if this is the case then just plug your camera into the computer and transfer the files that way then you can print them.
Jul 22, 2009 | Brother MFC 420CN All-In-One InkJet...
Cannot copy photos from my SD card
If the printer is connected to your PC with the USB cable then as soon as you insert the SD card in the slot it acts as a drive. Open up "My Computer" and search for the new drive (e.g. E: or I:). You can explore the SD card as you would with your hard drive and you can copy the photos on the SD card to your computer as you would normally copy files.
Apr 05, 2009 | Brother MFC 210C All-In-One InkJet Printer
Sdhc memory card
Any SD card up to 2gb. Devices are just now coming out that can use High Capacity SD but no printers yet.
Jan 25, 2009 | Brother Multi-Function CenterĀ® MFC-215C...
Want to print pictures from camera card.
I received my Brother printer today (11/5). I also go mine mainly for the scanner because my Visioneer 9320 doesn't have any drivers for VISTA, and Visioneer isn't making any updates.
My camra uses a SD card. This is how I got mine to print pictures.
I place my SD card into the printer
I then press the PHOTO CAPTURE button The display on the printer reads CONNECTING TO PC
Then the display reads PRESS (up arrow or down arrow) & OK
When you press the up or down arrow, the display will read PRINT IMAGES or PRINT INDEX
I selected PRINT INDEX and then you have to press the OK BUTTON
The printer display then will ask 6 images per line or 5 images per line.
You pick what you want then you hit the OK button.
Don't forget to put the photo paper in the tray, upside down.
Hopes this helps
Nov 03, 2008 | Brother Multi-Function Center MFC-240C...
Electronics - Others Logo
24 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
