Question about HP Omni 120-1130 20" All in One Desktop PC
How to open case to remove HD, video just lines and blocks and won't boot. Barely read top of screen about windows not shutting down correct.
Main thing is how to open up the case and remove HD in order to retrive files.
    New Friend:
  • 44 Answers
I'm not real familiar with the All-in-One systems, but I found this site
Adding or Replacing Hard Drive in HP Omni 120 1000 Series Desktop PCs explaining the HDD removal process. In the description is another link to HP's technical document on removing the rear cover. Hope this helps.
Posted on Feb 09, 2014
I have a toshiba satelite L655-s5117 laptop and it won't boot up even when i try and boot from windows 7 disk it won't
Probably a faulty hard drive. go into the setup screen and verify the HD setting is correct. save your settings and reboot. if this doesn't solve it, then take out battery and disconnect power, remove hard drive and reconnect. try reboot. if none of that works, then replace hard drive and reinstall OS.
Mar 10, 2013 | Computers & Internet
I'm in Australia and have one of the det student
the windows gone corrupt, it needs re-installtion from recovery or from the windows cd
Jan 14, 2013 | Computers & Internet
Silt, sand, something from deep water well has migrated past exterior washer hose screens into washing machine. Older Kenmore HD Series 70 top loading washer. How to fix?
probable but unlikely
the control valve for the water ( hot or cold ) has a diaphragm in the main flow with a small hole in it to act like a pressure regulator
so when the solenoid shuts off the water , water flows through that small hole and locks the diaphragm firmly on the seat
I suggest that the low flow is because that diaphragm has been compromised and is not opening correctly for full water flow
take it apart and clean it out or replace it
Feb 04, 2018 | Kenmore Washing Machines
I locked my hardrive and cant get into it now.......how can i unlock it
Need more information. How did you lock it? In the BIOS?
Assuming you did this in the BIOS you will need to enter the BIOS by hitting F1, F2 or DEL while the computer is booting in BIOS. Sometimes you will see the BIOS key noted on the bottom of the Boot screen. On the first BIOS screen check to see if your HD is listed. If so go to the BOOT screen. On the BOOT screen check the boot order. To move the HD to the top click on the HD and click on the "+" key to move it up of select it if you get an options window. In the BOOT SETTINGS screen click on the HD to varify that the correct HD is listed. If more than one HD you can move the boot drive up by using the "+" key or options window. Check your other settings. When done hit ESC and go to the last screen and select to SAVE and Reboot.
If you locked yourself out at the Windows Password screen. If you are using Windows XP Home, reboot and hit F8, F10 or F12 during BIOS boot. Select SAFE MODE. When Windows open go to the Control Panel - Users and delete the users. This will remove the passwords. Close windows and reboot computer. Windows will now start and open without passwords. If you are using XP Pro you will need to take the computer to a Tech who will have a Password Disc to clear the passwords.
Apr 14, 2011 | Computers & Internet
Shut dwn to prevent damage. laptop will not do anything. has blue screen. Turned off & then on pressed F8 NOTHING!
sounds like corrupt boot sector might need to format OS try to pull out the HD and transfer all your data first
Mar 02, 2011 | ASUS Eee PC 1005HAB Netbook - Intel Atom...
Cant boot up my toshiba lap top. it comes up asking for the BIOS password then shuts down after 3 tries! have tried all the F keys, shift key and removing battery!
the only way to get past the bios password is to open up the case and try to find a jumper on the main board that says bios reset, close that jumper and turn on the computer for one boot, power down and remove the jumper, after that the bios should be reset(bios passwords are usually set as a security measure that is not easy for the average user to bypass such as a windows one that can be removed by formatting the drive and reinstalling windows)
Jan 22, 2011 | Toshiba Portege S100-S1133 Notebook
Toshiba Satellite P205-S6237 won't Boot up after full shutdown
i think there is some issues with the OS because i noticed you can't shut it down properly so maybe the files needed in order to shut down had been corrupted but one more theory, the bios settings make sure that everythings configured properly there by checking the power options on the bios setup(the blue screen)so try setting it to default and change the boot priority to HDD,CDROM,FLOPPY.
Jul 14, 2009 | Toshiba Satellite P205-S6237 Notebook
Cant install powercolor 9600 pro on EliteGroup 845GV-M3 mobo... Fan will run in agp express slot but hardware not found on boot up (win XP)
HI findads,
You need to make a change in your bios. Still have your manual for the 845GV-M3 motherboard?
If not you can download it at this link: http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=465&DetailName=Manual&DetailDesc=845GV-M3%20%20(V1.0)&CategoryID=1&MenuID=82&LanID=0
You will also need Adobe reader to view the pdf file. Get Adobe for free at: http://www.adobe.com/products/reader/
If you have already installed the 9600 AGP card, please shut down your system. Unplug the power cord from the power supply. Open your case & remove the 9600 AGP card. One must follow an order of sequences’ when changing graphics cards. Once removed, reconnect the power cord to the power supply & boot the system. (It’s ok not to close your case). As the system starts to boot, press the Delete key on your keyboard every two seconds. The main bios menu will load. Read the instruction at the bottom of the menu which will show you how to move about in the bios.
(The mouse does not function while in the bios).
Using the manual to help change a settings.
Go to Advanced Chipset Features page 35, than into Integrated Peripherals, page 37.
Set Init Display First to [AGP]. Save the bios & exit. The system will auto restart. Once your screen goes to black, press & hold the power on / off button on your case until the system shuts off.
Unplug the power cord from the power supply. Install the AGP video card. Make sure it is completely seated & even in the AGP slot. Screw it down. Before closing the case, re-check all internal power connections to every device & all data connections. (Snug fit). Close your case & reconnect the power cord to the PC. Boot your system. You should have display & windows should load.
Install the CD software for the 9600 Pro video card. Restart the PC. Go to power color & check for any driver updates for the 9600 Pro card. http://www.powercolor.com/
Before installing any update from PowerColor check windows for updates.
Everything should work out ok.
Good luck findads!
Questions? Post here.
Mike
Oct 16, 2008 | EliteGroup 845GV-M3 Motherboard
Lap top wont boot up
Go to the BIOS menu and select the Main Tab... see if the computer sees your drive. If not send it to the manufacturer or look to see if you can get to the HD without cracking open the main case to the laptop
if you can... check the connection from the HD to the connectors to the motherboard
Apr 08, 2008 | Computers & Internet
Computer no responding
Restart the system press F8. New screen will appear in that select the safe mode. After that window will boot up. Do the these steps.
1. Goto start->accessories->system tool->system restore click this and then read the process and then select last properly work day and click next.
2. It will restore the system.
Feb 25, 2008 | Computers & Internet
HP Omni 120-1130 20" All in One Desktop PC Logo
80 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
