Epson Stylus CX6600 All-In-One InkJet Printer Logo
A
Anonymous Posted on Feb 09, 2014
Epson stylus cx6600 won't power up/scan light turns on then goes off.
My epson stylus cx6600 will not turn on. It worked fine a day ago but now the front screen is blank, when I press the power button either nothing happens or just the scan button lights up for a random time then goes off. The display screen stays blank the whole time. I have unplugged-repluged in everything, restarted my system, uninstalled-reinstalled the drivers all for nada. The printer just wont turn on/stay on. I'm hoping it's not a loss cause as I just bought more ink for the thing and have documents I -need- printed ASAP.
5 Related Answers
Anonymous
  • 8637 Answers
  • Posted on Jan 25, 2009
SOURCE: Epson Stylus Photo 1400 Not Printing
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
seanpwright
Sean Wright
  • 2045 Answers
  • Posted on Aug 27, 2009
SOURCE: Epson Stylus TX100 printer Woeks but scanner not
It is a scanner as well, but you have to access the scanner through the software that came with it
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Anonymous
  • 235 Answers
  • Posted on Nov 21, 2009
SOURCE: EPSON Stylus NX110 - 1st Ink Cartridge Replacement
you better have your printer check by a qualified printer tech thus avoiding any further damage to the printer the printer head is the most likely problem to
Anonymous
  • Posted on Jan 29, 2010
SOURCE: Continuous Ink System Epson R1900 "Ink on" light illuminated
hi, the most possible is that your chip on that cartridge is broken or damaged. You may need to replace a new chip.
Or you didn't contact well the chip with printer contact pins. Try many times.
If still problems pls feel free to ask me.
Danny
[email protected]
www.equnxin.com
Anonymous
  • Posted on Mar 16, 2011
SOURCE: Epson Stylus C62 Error Red light wont go off
Had a paper jam. Cleared it and the red light will not go off. Have turned C62 off and the back on. Problem continues.
Epson Stylus CX6600 wont power up/scan light turns on then goes off.
this may help...
Check that all the access doors and compartments are closed correctly.
Check paper isn't jammed.
Take out the all the ink cartilages and reset them in correctly
Make sure the rollers are set in place correctly, (if there removable)
Hope this helps a bit
I want to scan a document to my computer
have you installed all the scanning software that came with the scanner, Install them and go through these steps to scan a document using Twain;
Overview of the Basic Procedure
This section outlines the basic scanning procedure using a TWAIN-compliant application. For detailed procedure, see the Scanning an Image.
Make sure the CX6600's power cord is plugged in.
Place your materials on the document table.
Start a TWAIN-compliant application.
In the application, open EPSON Scan.
Full Auto Mode:
EPSON Scan automatically previews the images and recognizes the document source and type. images are automatically optimized and scanned.
Home Mode or Professional Mode:
Make settings to optimize images and click Scan.
The scanned images are sent to the application.
Save the scanned images in the application.
Scanning / How to Scan
Scanning an Image
Turning on the CX6600
Placing your materials on the document table
Starting the software and scanning an image
EPSON Scan provides three modes for you to make any scanning settings; Full Auto Mode, Home Mode, and Professional Mode. This section describes how to scan an image in the Full Auto Mode. The Full Auto Mode lets you scan images using automatically-adjusted settings. For more details, see Choosing a Scanning Mode.
Note:
You cannot scan an image with a size that exceeds the available memory or disk space. If you try to scan the image, an alert appears on the screen.
Note for Macintosh users:
Most illustrations shown in this section are for Windows, so they may vary in appearance from what actually appears on your screen. The instructions are the same, except as noted.
Caution:
Before starting the following steps, make sure that all the necessary software including EPSON Scan has been installed. For details about how to install the software, see the Start Here sheet.
Before turning on the CX6600, make sure it is connected to your computer.
Press the On button to turn on the CX6600. All mode lights flash, then the mode button for the mode you used last lights, meaning it has completed its initialization.
You can scan reflective documents (like photos or paper). See Placing Photos and Documents on the Document Table.
You can start EPSON Scan in the following ways.
* Start EPSON Scan directly as a stand alone application
* Start EPSON Scan from a TWAIN-compliant application
This section provides information on how to start EPSON Scan from ArcSoft PhotoImpression. For details on starting EPSON Scan as a stand-alone application, see Starting EPSON Scan.
Note; if you are using Windows 98:
ArcSoft PhotoImpression 5 supports Windows 98 Second Edition or later. For version earlier than Windows 98 Second Edition, use EPSON Scan or other TWAIN compliant applications. See Starting EPSON Scan for details.
Start ArcSoft PhotoImpression.
For Windows users:
Click Start, point to All Programs (for Windows XP users) or Programs (for Windows 98, Me, or 2000 users), and select ArcSoft PhotoImpression 5. Click PhotoImpression 5.
For Macintosh users:
Double-click the Applications folder on your Macintosh HD, then double-click the PhotoImpression folder. Finally, double-click the PhotoImpression 5 icon.
Click the Camera/Scanner button.
Select a file format, location, and file name, then click Epson Stylus CX6600. EPSON Scan starts. See File formats for information on file formats.
Note for Windows XP users:
Do not choose WIA-Epson Stylus CX6600 from the menu to select the CX6600. If you select it, you cannot use the Epson scanner function fully.
EPSON Scan automatically previews the image, and recognizes the document source and type.
If you want to select more settings, click Pause, then click Options to open the Options dialog box. For more details on settings, click the Help button in the Option dialog box.
After EPSON Scan has previewed and recognized the document type, the following window appears. You can see the document type in the window.
EPSON Scan automatically locates the target images, modifies their skew, and starts scanning.
Caution:
Do not open the scanner unit during scanning or copying; otherwise, you may damage the CX6600.
Note:
Be aware that clicking Cancel on this screen closes EPSON Scan.
The scanned image is sent to ArcSoft PhotoImpression.
Note:
* Depending on the image you want to scan, you may not get the expected scanned image. In this case, scan the image in the Home Mode or Professional Mode.
* When you scan in the Full Auto Mode, black and white documents might be recognized as a color document. In this case, scan the image in the Home Mode or Professional Mode.
If you still experience problem scanning, un-install the entire software and re-install them all over. Install all the packages in the CD. Cheers!
Epson Stylus CX6600 does not print
Suggest you try resetting the waste ink counter on this printer to see if it will then allow it to print again.
  1. You will see big button on your printer like power on (this is on the left
  2. side), black & white photocopy, color photocopy, and then the stop button (these are on the right side).
  3. first turn off your printer
  4. push the b/w + color + stop buttons together and hold
  5. push the power on button and hold (so you'll now be holding down 4 buttons together)
  6. Don't release all the buttons until you see the light indicator is blinking and then a message display on the lcd
  7. release all the buttons
  8. push the color button (once)
  9. turn off the printer
  10. turn it on again
IF this works you will then need to fit an external waste ink tank as soon as possible to ensure you don't end up with a major headache (ie: ink swimming pool!) under your printer.
Instructions for completing the modification are available if you google your printer model and "waste ink".
Epson CX6600 printer does not print
Make sure the tape is removed from the cartridges and that they are the correct ones for your model printer.
Card reader not working
I think 1 MB is the limit. Get a cheapy multi USB card reader.
CX6600 SCANNER
Download the Reference guide for your machine from th eEpson web site. It will inform you what you need to do to complete the scanning options. you can also download the Epson Scan utility to help with scanning to email etc.
Epson stylus cx6600
hi-
are you using an intel based mac or power pc mac?
download the driver from this link
EPSON
and inform me if you have issues still
Will not turn on, have tried various outlets
1 of 2 things.
Either you have an inline fuse on the power supply that has failed.
If there is not a fuse, then the power supply itself has failed.
Film viewing and scanning
Sorry, but you won't be able to do that with a CX6600. In order to scan film negatives, you need a printer that includes a transparency unit in the lid, that is, a panel that lights the film from behind. Also, the CX6600's scan resolution wasn't designed for detailed film scans. Try the online Epson Store at www.epsonstore.com where you can often find good deals on refurbished stand-alone scanners with transparency units.
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
