Where do I regulate the water use I think it uses to much water
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 134 Answers
You cant regulate how much water a machine uses check your pressure switch
Posted on Feb 11, 2014
Hi I recently washed my ba falcon and now my ABS lights are on and my battery boiled, i think my battery is over charging? any idea what it mite be?
battery boiling indicates that the voltage regulator is faulty and not regulating the alternator output to 14.5-14.8 volts
if that unit is part of the alternator and you sprayed water into the alternator ,that regulator if internal would have shorted out
the ABS problem could be from water in the harness connections
take it to an auto electrician and have the charge system fully checked out
Apr 12, 2018 | Cars & Trucks
What type of oil does ryobi honda 3100psi 2.5 pressure washer uses ?problem that Im having is machine starts ok but there is no pressure Do u think having no water pressure is cuz being low on oil ?
extremely unlikely
most problems can be attributed to a blocked nozzle that will not allow the pressure regulator to bring the pump to full pressure
The system works like so
the pump uses the tap pressure to generate high pressure ( make sure tap is on and no kinks in the hose)
the pressure generated is fed through the regulator to the nozzle via a hand control
When the control is activated the regulator shuts of the by pass system and full pressure is achieved to the nozzle
when the control is released the pressure regulator by passes the water back to the inlet side and so releases the pump under load
Now if the nozzle is blocked it becomes the control and there will be no pressure
If it is partially blocked the pressure still need no pressure to work so at partial blockage it will still by pass water back to the inlet
Apr 18, 2015 | Honda Garden
Karcher G 3050 OH the pressure is not constant, I think that is the pumps pressure regulator but I'm not sure
Check the suction line for leaks. It needs constant water
supply to build a constant water pressure. You may also
check the pressure regulator for leaks. You may also
check the carbide or ceramic pistons for breaks. Send you e-mail for further assistance.
Sep 06, 2009 | Karcher G2500PHR Factory Refurbished 2,500...
96 Civic power window, driver's side
before replaceing check voltage from switch to regulator then to motor that will tell you which component is bad when you find that out look at the mounting styl off the failed component mos are held in with clips or rivets if they are riveted in you will have to drill them out
Jun 03, 2009 | 1996 Honda Civic
Need to lower 1750 psi to 300 psi on my portable power washer.
Don't starve the inlet to the pump. It will detroy it.
Buy a pressure regulating valve and plumb it in line per the instructions. Do not use a relief valve because you will have to have a return line or you will heat the water up on the inlet side of the pump depending on how the pressure washer is set up. It should already have a safety relief valve. You might look and also find a pressure regulator that is adjustable and all you problems will be solved.
Apr 24, 2009 | Garden
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
