Question about SuperMicro SUPER X5DP8-G2 (MBD-X5DP8-G2-O) (SUPX5MBDX5DP) Motherboard
Memory cache - SuperMicro SUPER X5DP8-G2 (MBD-X5DP8-G2-O) (SUPX5MBDX5DP) Motherboard
L2 cache Vs L3 Cache
Hello
That the CPU cache memory the 3MB L3 will be better the the 1 MB L2. This mean the CPU can perform faster. If you want to know whats the different between cache memory.
The video shows how cache works.
Apr 10, 2014 | Computers & Internet
What is the uses of the memory
Depends on what Memory you are referring to, yampratwum
1) Cache for a Processor;
A small memory area on the Processor.
(L1 and L2. Some Processors also went to L3 cache)
Cache operates at the same frequency rate ('Speed') as the Processor.
It is the First memory area the Processor accesses.
http://en.wikipedia.org/wiki/CPU_cache
http://computer.howstuffworks.com/cache.htm
http://www.hardwaresecrets.com/article/How-The-Memory-Cache-Works/481
2) Ram Memory;
Volatile memory.
Once the computer is turned off, all memory stored in Ram Memory is GONE.
Ram Memory typically operates at half, of the frequency rate of the Processor's Front Side Bus. (FSB)
It is the Second memory area that the Processor accesses.
http://computer.howstuffworks.com/ram.htm
3) Harddrive; (Hard Drive. Hard Disk Drive)
This is the Third memory area the Processor accesses.
There is also a small memory area on the harddrive.
This is it's Cache. It is called the Buffer.
http://computer.howstuffworks.com/hard-disk.htm
http://en.wikipedia.org/wiki/Disk_buffer
http://www.hardwaresecrets.com/printpage/177
4) Virtual Memory;
An area on the harddrive that Windows has allotted.
Rule of thumb is Virtual Memory is one and one-half, (1-1/2) the amount of Ram Memory.
Example;
2GigaByte (2GB) of Ram Memory?
Typically Virtual Memory will be 3GB.
http://en.wikipedia.org/wiki/Virtual_memory
5) BIOS;
Basic Input/Output System
A program that is flashed to an EEPROM chip. The BIOS chipset.
Another small memory area.
http://computer.howstuffworks.com/bios.htm
http://computer.howstuffworks.com/computer-memory.htm
Regards,
joecoolvette
Nov 05, 2012 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Machine check exception
it is hardware problem change power supply unit and try
May 16, 2012 | E-Machines eMachines Desktop PC
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
Cash Memory
You might want to read the following on cache memory and it's value to the PC. Lot of good information.
http://www.sun.com/blueprints/1102/817-0742.pdf
Jul 24, 2009 | Computers & Internet
Will removing the CMOS battery clear the BIOS
it's about the processor level caches
but also might be a bad memory slot (RAM)
resetting the bios is a good choice, maybe this will helpe either
Jul 01, 2009 | Acer Computers & Internet
Cache memory
A cache is a temporary storage area where frequently accessed data can be stored for rapid access. Once the data is stored in the cache, future use can be made by accessing the cached copy rather than re-fetching or recomputing the original data, so that the average access time is shorter. Cache, therefore, helps expedite data access that the CPU would otherwise need to fetch from main memory.
A cache is a block of memory for temporary storage of data likely to be used again. The CPU and hard drive frequently use a cache, as do web browsers and web servers.
A cache is made up of a pool of entries. Each entry has a datum (a nugget of data) which is a copy of the datum in some backing store. Each entry also has a tag, which specifies the identity of the datum in the backing store of which the entry is a copy.
When the cache client (a CPU, web browser, operating system) wishes to access a datum presumably in the backing store, it first checks the cache. If an entry can be found with a tag matching that of the desired datum, the datum in the entry is used instead. This situation is known as a cache hit. So, for example, a web browser program might check its local cache on disk to see if it has a local copy of the contents of a web page at a particular URL. In this example, the URL is the tag, and the contents of the web page is the datum. The percentage of accesses that result in cache hits is known as the hit rate or hit ratio of the cache.
The advantage of cache memory is that the CPU does not have to use the motherboard’s system bus for data transfer. Whenever data must be passed through the system bus, the data transfer speed slows to the motherboard’s capability. The CPU can process data much faster by avoiding the bottleneck created by the system bus
Jul 17, 2008 | Microsoft Windows Server Standard 2003 for...
From zthai
intel celeron M(mobile)530 (class) the 530 denotes the type of processor configuration, not a bus speed or anything else.The 64Bit architecture uses 530,523,and 520.
Level 2 cache memory is what is on the processor. 1Mb cache memory on a mobile processor allows the chip to process info quicker.
cache memory has nothing to do with ram memory except as transfer rate.
the laptop will support 2gig ram modules X 2 for 4gig total.
it can use speed of 667mhz max or the 533mhz clock speed.
You can use either clock speed and any sets of 2X512mb, 2X1024mb, or 2X2048mb just for best results keep the size the same and the speed the same...both at 533 or 667...both at 512mb, 1gig, 2gig,
Apr 24, 2008 | Computers & Internet
Cache memory
See page 13 of the MANUAL
There is no cache memory on this board.
Usually cache memory is on the processor these days and is known as L1 and L2 cache.
Years ago L2 cache was on the mainboard.
Jan 05, 2008 | Intel D915GAV Motherboard
Not Enough Memory errors
* Empty your Recycle Bin on a regular basis. * Delete unused programs and files. * Reduce the storage space reserved for Internet Cache. o Open Pocket Internet Explorer (PIE) o Select View, Options and Advanced. o Adjust the size of cache, select Empty Cache When Exiting or disable caching altogether by removing the check mark from Enable Caching. * Consider external storage as an alternative.
Sep 14, 2005 | NEC MobilePro 750
Computers & Internet Logo
13 people viewed this question
Top SuperMicro Computers & Internet Experts
Tony
David
David
Victorman
Victorman
Are you a SuperMicro Computer and Internet Expert? Answer questions, earn points and help others
