Question about Sony BRAVIA Televison & Video
Sony bravia kdl374000
I have replaced the t-conn board, but screen still goes white when you turn on , and intermittently when watching
lebones337
  • 152 Answers
SOURCE: We were watching tv on
sounds like the lcd control board malfuntioned. call sony and im sure they will have you bring it to a repair shop at no charge
Posted on Jan 01, 2009
xCAUSALITYx
  • 210 Answers
SOURCE: My Sony Bravia KDL-26S3000 won't turn on and is stuck in standby.
There is a power fault with one of the PCB's inside, contact Sony if you are still in warranty, if not contact a Sony service center as it will need an engineer to open it up to repair it.
Thanks
Posted on Oct 09, 2009
  • 73 Answers
SOURCE: My brand new 40
This is a characteristic of the dynamic backlight used on this set.Turn off the dynamic contrast in the customer menu this should solve your problem.
Posted on Oct 15, 2009
rulds2008
  • 3866 Answers
SOURCE: i have a sony 40 inches bravia flat screen hd and
Could be the decoder:
1. unplug the TV ans wait a few mins.
2. If you have digital cable box or dish tuner reboot those as well (likely your issue)
What you have is artifacting what that means is tiling garbiling and freezing this happends when the data in the digital stream just stopped hence Frozen.
Try those things rule out your cable tv box first or your sat box, if this is OTA over the air your antenna.
1. Try DVD's if it happends during a DVD you do have a decoder issue if it does not you need to talk to your cable tv or sat operator.
So you got 3 possiabilites here 1. the worse Decoder, 2 cable company or satalite provider, 3 your antenna is in the wroung position.
I sure this will help.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Nov 30, 2009
Testimonial: "i just hope this works"
  • 84 Answers
SOURCE: Sony Bravia XBR4 52inch LCD cracked
It can be replaced, but it is probably going to cost you more then the cost of a new TV to do it.
Read the tech tip I wrote on this very subject.
http://www.fixya.com/support/r3831376-when_cracked_lcd_led_or_plasma_tv
Posted on Jan 07, 2010
Sony Bravia KDL-60EX500 no longer turns on.
Refer to Sony KDL 55EX500 Troubleshooting Manual Protection Mode Symptom...
5X Blink - TCON & HFR Failure
The 5X blink protection mode indicates a communications error between the TCON/HFR board and the MT5388 microprocessor on the A-Board.
First replace the TCON/HFR Board if the 5X protection mode blink pattern occurs. If the TCON/HFR Board does not repair the problem then replace the A-Board.
see schematics in Sony KDL 55EX500 Troubleshooting Manual Page 23
Sep 15, 2016 | Sony Bravia Kdl-60ex500 60" Inch 120hz...
WHITE SCREEN ON SONY BRAVIA
I wold open up the tv, reset the T-conn ribbon cable. If no fixed then the T-conn is to blame.
Hope it helps.
Jun 22, 2014 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
White flare top left of screen sony bravia ldl-52W3000.
The capacitors at the main power supply regulator board should be checked and replaced. If you are not familiar with electronics, do not attempt to repair! Whether you suffer fatal electrical shock! Instead, contact the nearest service center!
Jan 20, 2013 | Sony BRAVIA KDL-52W3000 52 in. LCD...
My Sony Bravia KDL-52W3000 when turned on after being off for a while has a weird double/distorted picture for about 15min. then it clears up and has a perfect picture for the rest of the time you watch...
CHANGED Z SUSTAIN BOARD.PICTURE PERFECT.APART FROM WHITE DOTS..THINK IT COULD BE DUST OR FINGER PRINTS ON RIBBON JOINTS,,WILL RE CHECK AND WIPE F/PRINTS TO SEE IF ANY CHANGE
Take care.....
Aug 04, 2011 | Sony BRAVIA KDL-46V3000 Television
We have a Sony Bravia KDL-40V3000 flat screen television. About 6 months ago, the screen started displaying white, green and black vertical lines and dots. This continued for a few weeks and then the...
It's a connection inside the TV that's faulty. It could be as simple as reseating the ribbon cables that connect the control board to the glass display. Or it could be that the fault is on the board and needs to be replaced. The fact that the problem comes and goes should tell you it's fixable.
Apr 28, 2017 | Sony BRAVIA KDL-40V3000 Television
My Sony flat screen bravia hdtv 40" when i turn it
Your LCD TV needs repair,abnormal display caused by a faulty LCD Control board. Replace the control Board.
Nov 12, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Left half of my TV screen is completely white
That is only available to Sony authorized servicers. See esupport.sony.com
Jul 31, 2010 | Sony BRAVIA KDL-52S4100 52 in. HDTV LCD
Sony KDL-40V2500 Screen is white
Remove the LVDS cable, the one going to the input of the tcon board and see if it goes dark, if it does the Tcon board has failed
Jan 29, 2018 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony Bravia KDL-40V2500
The panel or TCON board has failed, the solution is the same replace the panel. Not worth the cost, get a new TV
Sep 28, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Televison & Video Logo
16 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
