Question about Zanussi ZEBF250W Bottom Freezer Refrigerator
Kenmore elite model 25344733102
Replace door area breaker kit
Microwave pops breaker on start
You probably have either a shorted high-voltage capacitor, or a shorted high-voltage transformer. And there is a 3rd possibility that should be checked first - the so-called "monitor switch" may be stuck in the closed position. There are usually 3 door switches in most microwave ovens, although some have 4. The monitor switch is usually the the one located in the middle of the door latch area.
Feb 15, 2015 | Kenmore Elite Microwave, Model...
Kenmore elite 106.44423603 ice/water dispenser housing - plastic broken off for ice door pin hinge. Any ideas for a fix?
Hi and thanks for using fixya!
There is actually a "kit" that replaces the hinge, housing for the hinge, dispenser door and bracket. Just be sure when you're taking everything apart you pay special attention to how it goes back together. Kit comes with metal bracket that will replace old housing. Now that I think about it the kit comes with instructions! Kit pt# 8201756 and you can purchase it here. Appliance Parts
Feb 04, 2015 | Kenmore Refrigerators
Kenmore elite oasis st model #110.68062801 won't run.
First check the breaker. You may have one leg out. Then check the starter switch. Also check the door switch. It could be broken or mislodged. When it is fully engaged, it will start up. Lastly the motor could be burned out. If it is an older model, then consider a new one. However, the repair on this is not that high if you can do it yourself.
Apr 26, 2014 | Kenmore Elite Oasis 6808 Electric Dryer
My kenmore elite dryer model 110 63032102 won't turn on
Check the door switch. Push it by hand and you should hear it click. If no click is heard, replace the door switch with this part.
If the switch is OK, then the only other problem will be with the thermal fuse located on the rear of the machine. Here is a link to that part.
Oct 15, 2012 | Kenmore Elite HE4 Electric Dryer
No power suddenly on the control panel... kenmore elite model 665-1374/665-1384 Worked one day and not the next. Breaker is on, no blockage at water line... connections all tight. It's only 14 months old!
Kenmore dishwashers should be recalled!! Their poorly designed computer circuit boards are all malfunctioning around 15 months. Look on the inside top of your door. Do you see a instructions? There should be some about your Heat Dry button and holding it down for 4 seconds to reset your computer board. Read and try it first. It's like rebooting a computer.
Dec 30, 2009 | Kenmore Dishwashers
Where can I find the model number on my kenmore elite washer?
TOP LOADERS
Look at following areas for the model number:
* Rear Center Of Lid Well
* Left Upper Back On Base Cabinet
* Back Top Control Panel
* Right Rear Corner Of Washer Top Lid
* Open Lower Left Front Base
FRONT LOADERS
* Rear Center Of Door Well
* Right Rear Corner Of Washer Door
Oct 26, 2009 | Kenmore Washing Machines
Kenmore elite won't start, I checked the house breaker box and breaker is okay. no light come on when you open the front dryer door either
kenmore elite won't start, Solve kenmore elite won't start, I checked the house breaker box and breaker is okay. no light come on... (More) kenmore elite won't start, I checked the house breaker box and breaker is okay. no light come on when you open the front dryer door either
Jul 03, 2009 | Kenmore 63942 Dryer
My kenmore elite he3 electric dryer control panel is not working. When the door is open the light inside is on, but with the door open or closed the control panel above does not turn on or light in any...
The control board is bad. You will have to replace it. You might aslo theck the fuse, sometimes they look a little different than you are used to. Refer to your owners manual and wiring diagram to find it. You can also find more info on the Whirlpool website. Whirlpool makes Kenmore.
Apr 10, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore Elite Dryer, Model: 110 60972990... will not restart.
yes, a DIY person can replace a thermal cutoff. just open the rear of the unit and look for parts with big red wires connected to it. it is round, one small and one big. both have two terminal clips.
if you can find the schematics inside the switch panel, then it would help you further. the thermal cutoff consist of two pc. replace both even one of them has continuity.
tnx 4 using fixya,
drcool
Sep 29, 2008 | Kenmore Elite HE4 Electric Dryer
Zanussi ZEBF250W Bottom Freezer Refrigerator Logo
Top Zanussi Refrigerators Experts
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
