Question about RCA LED55C55R120Q 55" 1080p 120Hz LED HDTV Black
2 of the same pictures on 1 screen - RCA LED55C55R120Q 55" 1080p 120Hz LED HDTV Black
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
HOW TO DO PICTURE MESSAGE
Composing Picture Messages
1. On the All messages screen, tap Compose message. The Compose screen opens. 2. Enter the wireless phone number or email address of your message recipient in the To: box. As you enter the phone number or email address, matching contacts will appear on the screen. Tap a recipient or continue entering the recipient's phone number or email address. Tap the "Tap to compose" text box and then start composing your message. 4. Press Menu and tap Attach. 5. On the Attach window, select Picture.This opens Album to let you attach a picture to your message. 6. When you are finished composing the picture message, tap Send.
To open and view a picture message:
1. On the All messages screen, tap a picture message to open it. 2. Tap the Play button at the right side of a picture message to view it
To reply to a picture message:
1. On the All messages screen, tap a picture message to open it. 2. Tap the text box at the bottom of the screen, compose your picture message (see "Composing Picture Messages"), and tap Send.
Feb 22, 2011 | HTC Hero Smartphone
I am trying to SCAN a photo and save it to my SCREEN SAVER and at the same time enlarge it to fit the entire screen.
The photos in your computer can be used as screen savers (those files that pop up when you are idle).
1. Right click on your desktop and choose personalize.
2. Select Screen Saver
3. Select Photos
4. Click OK
All of the photos in your pictures folder will be your screen saver.
If what you want is this picture to be your background (the file that shows on your desktop all of the time)
2. Select personalize
3. Select Desktop Background
4. Change the "Location" to Pictures from its setting of Windows Backgrounds
5. Select a picture
6.Click OK. It is automatically sized to your desktop.
Dec 03, 2009 | Microsoft Windows Vista Home Premium with...
A 1/2
there are 2 possibilities 1. you have changed screen resolution by accident, try using that [right click desktop and properties, look in tabs there] or 2. your screen is old and it has "burned out" in some parts
Oct 14, 2009 | Relisys Intro TE988 19" CRT Monitor
Picture display format doen't fit 32'' screen
if you have cable box or a sattelite change the resolution of the STB to 4.3
Feb 06, 2009 | Sanyo DP32746 32 in. LCD Television
Television screen is showing mirror image not the actual image.
There's a button on the original remote control that does exactly that:
(Please vote or comment if my solution helped you!)
Adjusting PICTURE FLIP Settings
You can set the orientation of the picture.
Directly setting the PICTURE FLIP
Press PIC. FLIP to display the
PICTURE FLIP screen.
2 Press PIC. FLIP to change the
setting.
Setting the PICTURE FLIP on the
MENU screen
Press MENU to display the MENU
screen.
2 Press a/b to move the cursor to
PRESET, and press ENTER.
3 Press a/b to move the cursor to
PICTURE FLIP, and press
ENTER.
4 Press c/d to select the desired
picture flip setting, and press
ENTER.
5 Press MENU to return to the main
screen.
NORMAL MIRROR ROTATE
UPSIDE DOWN
A•
The PICTURE FLIP screen automatically
disappears in 3 seconds.
• [NORMAL]: normal image
[MIRROR]: mirror image
[ROTATE]: rotated image
[UPSIDE DOWN]: upside down image
Oct 22, 2008 | Sharp LC-15AV7U 15 in. LCD Television
Picture reduced to 1/4 on a black screen
Picture is reduced to a straight horizontal line across the center of the screen.
Aug 17, 2008 | Televison & Video
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
RCA LED55C55R120Q 55" 1080p 120Hz LED HDTV Black Logo
13 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
