Question about GE A1455 Digital Camera
I have a picture but I can't copy picture to card
I want to download pictures from the internal memory and I attached the camera with the usb cable and it does nothing. I've tried pressing the shutter button nothing
The only way is copy pictuers from internal memory to the external memory using the camera Copy pictures or videos:
1 Press the Review button, then press the Menu button.
2 Press to highlight Copy , then press the OK button.
3 Press to highlight an option:
PICTURE or VIDEO-copies the current picture or video.
EXIT-returns to the Review menu.
ALL-copies all pictures and videos from your selected storage location to the
other location.
4 Press the OK button.
NOTE: Pictures and videos are copied, not moved. To remove pictures and videos from the original location
after copying, delete them
May 19, 2012 | GE X500 Digital Camera
Transfer pictures from camera to card on Panasonic Lumix DMC-FP2
There's a Copy command in the Playback menu that will copy photos from the internal memory to the card (and the other way around). Full details are in the "[Copy]" subsection of the Using [PLAYBACK] menu" section of the manual (page 73 in my copy). If you need a copy of the manual, you may download one here.
Mar 02, 2012 | Panasonic DMC-FP2 Digital Camera
Have "olympus sp 800uz" and
1. Put the SD card into the computers cardreader.
2. Connect the camera through USB with the computer .
3. Copy the pictures.
If you have trouble with the SD card:
1. Copy all the pictures to the computer.
2. Format the sd card in the camera.
3. Copy the pictures back onto the sd card.
Aug 31, 2011 | Olympus SP800UZ Digital Camera
Internal memory is full on our M580 Can not toke pictures
I copied this from Kodak website Good Luck!
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card?
Follow these steps:
On the camera, press Review and then Menu.
Select Image Storage.
Change to Internal Memory.
In the menu listing, scroll down to Copy, and select OK.
Select a single picture, or select All.
When you have finished copying pictures, reset the Image Storage location to your original setting.
NOTE: You can also use a card reader to transfer picture files to a memory card. For more information on card readers and memory cards, go to KODAK Memory Cards
Sep 05, 2010 | Kodak Easyshare M580 Digital Camera
How can i get the date and time shown on the developed picture
If you copy the data from the built-in
memory to the card, we recommend using
a card which has more free space than
the built-in memory (about 14 MB).
• If a picture having the same name as the
name of picture to be copied exists in the
copy destination, the picture will not be
copied.
•When you copy the data from the built-in
memory to the card and if the free space
on the destination recording medium is
not sufficient, the picture data can only be
copied halfway.
• DPOF settings on the original picture data
will not be copied. Set DPOF settings
again after the copy is completed. (P73)
• Only files conforming to DCF standard
(P49, 75) can be copied. (Files which do
not conform to DCF standard cannot be
copied.)
• It may take time to copy the data.
• Pictures which are recorded or edited with
other equipment may not be copied.
1 Select [YES] to format the
medium.
(The illustration is the screen when the
built-in memory is formatted.)
•When a card is not inserted, you can
format the built-in memory. When a
card is inserted, you can format the
card.
hope you can get something out of this...it came from user manual!
Jun 12, 2010 | Panasonic Lumix DMC-LZ2 Digital Camera
How do transfer pictures from internal memory to card?
Got this from the manual.
Copying pictures/videos
You can copy pictures/videos from a card to internal memory or from internal memory
to a card.
Before you copy, make sure that:
? A card is inserted in the camera.
? The camera’s picture storage location is set to the location from which you are
copying.
Copy pictures/videos:
1 Press the Review button, then the Menu button.
2 Press up and down arrows to highlight Copy , then press the OK button.
3 Press up and down arrows to highlight an option.
Apr 14, 2010 | Kodak V803 Digital Camera
Nikon coolpix 4600: How to transfer pictures from camera to card?
ok I figured out how to do it! put the memory card into the camera, then go to view the pictures. Then press the menu button and scroll until you see the copy button. Then you will see the option to copy from camera to card, or card to camera. Press the option to copy from camera to card and press select all....(or whichever pictures you want copied...I wanted all pictures copied). Then voila! it takes a few seconds to copy from the camera to the card, and there you have it! :)
Dec 26, 2009 | Nikon Coolpix 4600 Digital Camera
Copy to card
Try putting the card on your computer, and open up the file to see if the pictures are still there. Unfortunately, it is quite possible that you formated the card, thus causing the deletion of the pictures. If the pictures are still there on the computer, then copy them to your computer, then delete whatever is left on your card, reformat it on the camera, and then copy the pictures back from the computer to the memory card. If you have any questions, please contact me.
Mar 14, 2009 | Samsung Digimax i6 PMP Digital Camera
I can't transfer pictures from my computer to my digital frame. When I connect my usb cable to my computer from my digital frame , the frame displays "Connected to computer. Use PC interface to copy files....
You can start copying pictures to SV811 digital picture frame if you get the message “Use PC interface to copy files.” Here are the steps:
Copy pictures, videos, and music between your frame and computer, using your computer's normal file copying tools:
1. Connect the USB cable from the frame to your computer
2. On your computer, open My Computer or Windows Explorer.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, and USB devices.
3. Navigate to the pictures you want to copy. Then drag and drop them to the new location.
4. Unplug the USB cable to view your copied pictures.
Copying pictures from EasyShare software:
1. Install EasyShare software (free download at www.kodak.com/go/sw )
2. Connect the USB cable.
3. On your computer, open EasyShare software. Select the pictures in My Collection and drag them into the Picture tray.
4. In the menu bar, select File and then Copy to the Kodak Drive letter.
5. Select the frame source to which you are copying.
6. Select Best for Digital Picture Frame to reduce the resolution of the pictures you are copying. Full resolution is unnecessary and quickly fills up the frame's memory.
7. Click Copy. Pictures are copied to your frame.
8. Unplug the USB cable and press “Home” icon to navigate to your copied pictures.
Dec 26, 2008 | Kodak EasyShare SV811 (8858946) Digital...
Move images saved to the internal memory to the optional xD-Picture Card
The images saved to the internal memory can be copied to the xD Picture Card, but you cannot copy images from the xD Picture Card to the internal memory. Before you choose to copy the files to the xD card be sure that there is enough room on that card. To copy the images to the xD card make sure the camera is powered on, then and press the menu button. Use the down arrow key to navigate through the menu to the BACK UP feature. Use the right arrow key to enter the Back Up screen and select YES to copy the images to the xD card, or NO if you choose not to coy the image files.
Aug 31, 2005 | Olympus D-535 Zoom / C370 Zoom Digital...
GE A1455 Digital Camera Logo
15 people viewed this question
Top GE Cameras Experts
Steven Wander
Steven Wander
jjanesic
jjanesic
Level 1 Expert
Are you a GE Camera Expert? Answer questions, earn points and help others
