Question about Tablets & eReaders
Haier hg 9041 boot up problem
I had to install firmware which I did by downloading to my pc and then to the tablet. now the tablet will not even turn on. any ideas?
Did you get it fixed or did you send the tablet back? I could not get mine fixed and I finally paid attention to another forum and I fixed it with that download. I was zipping the file then unzipping it then putting it on my sd card and it does not work that way. I saved the new firmware straight to sd card put in tablet and boom I was up and running in ten minutes. Just be patient with it cause it will act like its doing nothing but it is.
Posted on Feb 24, 2014
Why is my iPad showing the plug with an arrow pointing to the iTunes emblem
Your iPad is in restore mode. If you boot the device while holding the home button, it will boot into restore mode for a clean firmware install or a restore from backup.
you can either hard reset the device by holding the sleep/wake and home buttons down simultaneously for 8 seconds, tether it to a computer and complete the restore, or just leave it alone for about 20 minutes and the restore timeout wll kick it back into normal operation as long as there is a good firmware install present
Aug 26, 2015 | Apple iPad 32 GB 3G Tablet PC
My HG- 9041 9" Haier tablet won't even start up what do I do ?
Buy a new one, those are disposable. No replacement parts available
Dec 09, 2014 | Tablets & eReaders
Haier tablet
hold down power button and return at the same time
Jun 11, 2014 | Haier Tablets & eReaders
How to fix hard bricked Hyundai Hold X700 NoBluetooth tab?
you can format your OS and need to delete all application you use on your tab,you can format by go to your nearest hyundai show room
May 30, 2014 | Umi Hyundai Hold X Ultrathin 7 Inch IPS HD...
Haier 9" HG-9041 tablet stuck on reboot screen
press and hold the power button for about 20 seconds. Release it and it should go through it's reset. You may see some screen flash during this time. If this does not work contact your support group.
Mar 23, 2014 | Tablets & eReaders
How can I reflash the firmware for my Allwinner A13 tablet?
Try pressing and holding power and volume down until it boots up. you will need to go online from a PC to download the latest firmware ( look on Allwinner webpage) then download it to a formatted SDcard.
this works for Ainol tablets.
worth a try.
Feb 28, 2014 | Tablets & eReaders
Haier 9" tablet HG-9041 will not boot up
Have haier tablet hg 9041 locked out ... How do a hard reset...
Feb 02, 2014 | Haier Move 2-Ipad 2 Dock With Hdmi
Restore factory settings for a pendopad
I have resolved the pendo pad hard reset lack of procedure and can factory reset a pendo pad that is locked with a passkey or and password full factory reset
First download you pendo pad firmware from here
http://shop.pendo.com.au/index.php/su...
I used the generic firmware 1 download and it worked fine for the TPC7SlV
Then Extract the . img file to you computer
Then you will need the firmware update too called rktools found here
http://download1942.mediafire.com/le9...
extract the zip file to your computer
Now your ready to flash the firmware
1. Power off your tablet with the switch
2. Turn the power switch Back the the on Position
3. Press & hold Side Button with the home picture also called the back/esc key
4. While holding, connect PC and tablet with USB cable (if tablet boot normally, try again)
5. Install the driver for your computer included in the RKtools Folder
6. Tablet should be recognized as "RK281X Device" in Windows
7. Start RKAndroidBatchUpgrade from rktools folder
8. In the bottom of the batch RKAndroidBatchUpgrade programme there should be a green light in the device upgrade area. * if there is no light in the upgrade area and all the numbers are grey then repeat the previous steps
9. Under the setting heading click and select the image file you downloaded from pendo ( will be a .img file if its a .zip file you need to extract it)
10.Click the upgrade button
11. wait till operation is completed
BAM Your pendo is password free, i hope i have created the best and easiest way to do this
***Please note if your wireless or Mobile network do not turn on then you have chosen one of the wrong firmware types from the pendo download site !!! the wireless and mobile network hardware are the only distinguishing features between the firmwares apparently******
Mar 08, 2013 | Tablets & eReaders
Word BOOT on screen of zehnder sat box then blank...help
Sounds like the firmware has gone from the sat box
take it to a satellite repairer or if you feel competent enough you can use a null modem cable to download the version from your box and then you can then download the firmware from the internet and then install firmware onto box! this happens alot with topfield sat boxes but some wont accept the firmware its a 50/50 chance but give it a shot you cant get any worse!
hope this helps,ben
Aug 11, 2009 | Toshiba Satellite R10-S802TD Tablet PC
Tablets & eReaders Logo
1,337 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
