Question about Krups XL6 Power Combi Food Processor
Krups xl6 combi blender leaking
No signs of leaking when using the food processor. Only leaks when the blender is used. I suspect it is a gasket problem, but I cannot get the glass blender to separate from the base.
  • Rita Dunleavy Stone
    Rita Dunleavy Stone Feb 09, 2014
    After I found the instruction manual online, I figured out how to remove the base and located the problem. Now I need to buy a new D3 part because 1 of the 4 plastic locking fins chipped - which is what I believe is causing the leaking.
    Master:
  • 966 Answers
Broken fin may not cause the leak because it has no contact with the content. Bad gasket can cause leak. The are available at houseware stores.
Posted on Feb 09, 2014
4 Suggested Answers
goyosan
SOURCE: Krups Master Pro Compact model 703 -need a part
Dear J:
I may be able to help you to find your Part but I am wonder if it is possible you can help me with a copy of the Owner's manual of the Krups 703, I lost mine and i my need some part too.
I will really appreciate if you e-mail me a copy to goyosan@hotmail.com.
I will look for your part in local Parts shop.
We have here in Miami one which is very complete Goodsman.
Thanks,
Greg
Posted on Sep 18, 2008
  • 214 Answers
SOURCE: The unit spews/leaks liquid out the back
It sounds as if the seal is leaking where the blades go through the container.
Posted on Jan 22, 2010
SOURCE: Where can I get a replacement blade for a Krups
Which blade do you need? I am also having problems finding a replacement blade for the same machine - the only one we use is the one that grates but the centre melted recently. Can we do a swap?
Posted on Dec 15, 2011
How do you unlock the lid on the food processor?
The locking happens at the handle. You need to turn the lid counter clockwise to take it off and clockwise to lock it into position.
Jun 01, 2014 | Krups XL6 Power Combi Food Processor
Ultimate chopper/blender is leaking. Where can I get a replacement
probably its the rubber that hold the blade cover to the mug is damage..if you cannot get a rubber then you need to buy new blender.good luck.
Sep 23, 2011 | Ultimate Chopper Food Processor
How do i take apart the bottom of the blender to clean
If yo umean the blender cup then it should just twist of, if not, check the owners manual.
May 18, 2011 | Krups XL6 Power Combi Food Processor
Why won't the food processor start
Hello :
If the cord is OK , then it seems that the motor armature is burn .
If you can fix it by yourdelf , then dissemble the unit, remove the motor. Loosen the bolts running from end to end of the motor and with emery cloth, clean the small metal plates on the ehd of the armature. They should be bright copper color. If the armature is burnt, they will be dull brown. The other thing is to replace the brushes in the motor . Or take it to a repair shop if you are not sure that you can fix it by yourself .
good luck .
please rate !
Mar 28, 2010 | Krups XL6 Power Combi Food Processor
Oster In2itive blender leaks
The three most common sources of leakage are a worn/damaged gasket, a cracked jar, or a cracked blade assembly - all of these parts are available from Oster. If you are still under warranty, they might even be able to send whichever part you need for free. Their phone number is 1-800-334-0759 (they are owned by Jarden Consumer Solutions nowadays).
May 19, 2009 | Oster 6710 In2itive Food Processor
I have an Ovatio AT7 Blender that is leaking. It
Yes you can buy a replacement seal which you can get through your supplier. Do you have an exploded view. By the time we got the replacement and fitted it we were not sure how it went in and the user manual does not even mention the seal
Mar 15, 2009 | Moulinex DG6 Food Processor
Leaking Bowl on Moulinex blender, how to stop leak
http://www.belstar-electrics.co.uk/index.php?_a=viewCat&catId=34
has the spare part you need - the black rubber "washer"
Sep 01, 2008 | Moulinex DG6 Food Processor
Krups XL6 Power Combi Food Processor Logo
182 people viewed this question
Top Krups Food Processors Experts
Karl Kittsteiner
Jerry Kramer
Jerry Kramer
Tom Chichester
Are you a Krups Food Processor Expert? Answer questions, earn points and help others
