Question about Whirlpool Duet GHW9150P Front Load Washer
Error F11 during the wash cycle
The machine stops in the middle of the wash cycle indicating F11. I cannot get it to stop nor continue. It doesn't seem to have any association with a heavy or a light load.
  • Whirlpool Master
  • 17,000 Answers
The error means that the controller is not talking to the other components. It is very expensive to repair,. If you want to run tests on it, there is a tech sheet behind the kick panel under the door.
Posted on Feb 09, 2014
SOURCE: washing cycle light won't stop blinking
The filter might be clogged. If you haven't found a fix or answer yet -it's been 2 days :o) There are two screws on the bottom panel, take it off, unscrew the round cap in the middle (make sure you have plenty of towels) and check the filter.
Posted on Apr 09, 2008
jonniewalker
  • 1031 Answers
SOURCE: Whirlpool top Loading washing machine won't spin on spin cycle
If the washer won't finish a spin cycle, it probably means that your timer went bad or stalled. You can take the control panel off and look at the contacts for scorching or corrosion.
Posted on Sep 21, 2008
  • 2976 Answers
SOURCE: Washing Machine Moves in Spin Cycle
There are 2 things you can do.
All washing machines have an off balance shut off, some are touchy, some let it run around the house. With wht machine empty, lean it towards you, on the 2 front feet, about 2 or 3 inches and let it drop. The self leveling feet in the rear must BOTH make good floor gontact and sometimes, just the weight of the machine will not adjust them. The other thing is, make sure the load is evenly distributed. Coats, blankets, small rugs etc. are very heavy when wet and they tend to throw all of the weight to one side.
There is no screw holding the yub in place. It hangs on the center post, where the agitator goes. There is however, what's called a snubber. It is a rubber device that looks like a flattened suction cup, that comes in contact with the tub. It helps keep the tub from jumping around too much.
Posted on Feb 02, 2009
57 varieties
  • 1653 Answers
SOURCE: My whirlpool duet front load washing machine stops in mid cycle
F21 = LONG DRAIN ERROR
If the drain time exceeds 8 minutes the water valves turn off. After 4 minutes the “Sd” error will be displayed, then 4 minutes later the F21 error code will be displayed.
Press PAUSE/CANCEL two times to clear.
Procedure:
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
5. If the above does not correct the problem, go to step 7.
6. Unplug washer or disconnect power.
7. Replace the pump.
Alternative Procedure:
If the machine cannot be forced to its diagnostic mode then:
1. Disconnect the washer from the power supply and water supply.
2. Remove the top panel by taking out the three screws in the back of the washer. The pressure switch is right on top.
3. Remove the Molex connector from the water level switch / pressure switch.
Refer to the picture below.
4. Reconnect the power supply but not the water supply.
5. Power the machine. The machine will enter diagnostic mode.
6. Power off the machine.
7. Replace the water level switch / pressure switch.
8. Reconnect the water supply.
9. Power on the machine it will work without error
Posted on Oct 02, 2009
SOURCE: GIVING ELECTRIC SPARK INSIDE THE WASHING MACHINE DURING RUNNING
washing machine motor sparks during spinning
Posted on Oct 03, 2009
My washer stops &and F-20 appears on viewer. Whats wrong with my washer
water problem check screens in hoses and valves !! rrors F1, F11 and F20
  • Error F1 indicates a communication error between the computer and the washer. Unplug the washer for a minute and plug it back in, as this may correct the problem. Error F11 indicates a motor control error. It can be caused by improper voltage. Unplug the washer and check the connections. This may fix the problem. Error F20 indicates lack of water entering the machine. If there is no water in the washer, check that the water valves are turned on. If there is water in the washer, press "Stop" twice to drain the washer. Unplug the machine and check the hose connections.
Read more : http://www.ehow.com/info_12006668_error-messages-kenmore-he2-plus.html
Feb 21, 2015 | Kenmore HE2 Plus Front Load Washer
IT OFTEN (MORE AND MORE LATEY) WILL STOP IN THE MIDDLE OF A WASH CYCLE AND FLASH F 11 AND SOETIMES DL- I CAN'T GET IT TO START AGAIN. IT USE TO HAPPEN ONLY DURING NORMAL WASH CYCLE, BUT MORE RECENTLY, IT...
F11 indicates a problem with the Motherboard that goes into the Computer Control Unit.
Is an expensive part (£150/$200) plus labour so maybe time to just move on......
Dec 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Stops on spin cycle and gives a f11 error code
F11 is a serial communication error. Communication between the main board and the motor control board is not being sent correctly. This could be a bad main board, motor control board or motor itself. The testing can get pretty involved. Try putting the machine in a self test mode and see if the error clears. Press Cancel, then by pressing the drain spin button once on the left side then move to the spin speed button the the right. Press this button until no-spin lights. Press the prewash button 4 times. C00 should appear in the display. Let it run it's tests, there will be 8 of them and end up on C08. If this doesn't work, it's best you wait for the service tech.
Mar 29, 2010 | Kenmore Elite 45986 Front Load Washer
Error Code F11
TRY UNPLUGING IT FOR A MIN OR TWO. I THINK F11 IS A CONTROL MODULE. CALL A TECH
Oct 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer stops washing and gives a p5 trouble code
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 12, 2009 | Kenmore Elite 45986 Front Load Washer
Washer stops during middle of cycle and post 02 F
f 02 is the error code for taking too long to drain the water disconnect power remove 3 torex 20 screws from lower front panel revove cap from pump asm to check for any obstructions beware there will be water in the pump
Dec 15, 2008 | Whirlpool GHW9100L Front Load Washer
F11 Error
probably bad control bd remove top control mounts to rear rail ck all wiring to control first just f11 usually indicates internal control failure
Nov 26, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore stacked washer / dryer 2002
hi thanks for the question so your saying your tub is full of water ,did it stop in the middle of the wash cycle or at the end of the wash if its at the end of wash and it doesn, drain then you have a lid switch problem . if thats the case reset your timer as if you want to start a new wash load if it starts to wash your timer is ok replace the lid switch
Aug 27, 2008 | Kenmore 98702 Stacked Washer/Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
63 people viewed this question
Dan Webster
Dan Webster
Sal De
