Question about Acer Aspire 4752, AS4752 Charger, Power Cord
Power button when i click power button start laptop like as press F2 & F12 as a long time. then when i click any key starting windows. how to start a window normally?
  • mimibm100
    mimibm100 Feb 09, 2014
    Hi mimibm100 , I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    Master:
  • 966 Answers
Mimibm100, to start the system normally, don't pre the F buttons. It should boot normally. If it does not, check boot sequence in F2.
Posted on Feb 09, 2014
2 Suggested Answers
  • 4961 Answers
SOURCE: start up problem
Sounds like you need to do a complete system reinstall or bring it in to a repair shop and have them see if they can fix it for you.
Posted on Jun 25, 2012
How do I get to bios setup
This depends upon the manufacturer of the laptop and the BIOS installed in it. Almost all require you to press a key right at the beginning of the boot-up process, some even give a little display about what key to press at the start of the time window. The window of time available is short; miss it and you have to start over and reboot. Most common access is the DELETE key. Others use the F1, F2, F10, or F12 keys. Chances are one of these will work for your machine.
Aug 11, 2016 | Computers & Internet
Tip
How to repair Windows Vista or 7 when it will not start or boot
When your computer will not start, all is not lost. The windows install CD has a repair utility that is very useful. By running this CD you can get back into Windows and repair your installation!
  1. Get your copy of the Windows Install Disc (any copy will work) and put it in your CD or DVD drive
  2. Turn on your computer and press F12 until you see a menu come up. If F12 does not work try ESC, Enter or F2 - depending on the brand of computer this key can vary
  3. Select CD/DVD Drive from the menu that comes up
  4. When you see "Press any key to boot from CD or DVD . . ." press any key on the keyboard
  5. Wait for the files to load (you will see a white bar along the bottom of the screen)
  6. Click on the continue button when you see the Windows screen
  7. lick repair my computer in the bottom left of the screen
  8. Sometimes the repair will begin immediately, if not, click start-up repair and let the CD do it's work.
  9. Reboot your computer and see if it boots
  10. If your computer does not boot, follow steps 2-9 again. The repair can only fix one problem at a time. If after 5 times it still does not work, Windows may need to be reinstalled.
on May 30, 2011 | Computers & Internet
I need to access BIOS at start.
Hi, it's normally F2. Sometimes F12.
Keep pressing F2 or F12 repeatedly as soon as you have pressed the power button on the PC, this may get you into the BIOS
Apr 27, 2016 | Computers & Internet
What is the f2,f8, r f12 want work? only the Ctrl+ Alt+ del that wroks
F2 usually takes you to the BIOS setup screen, you need to hit the keys as soon as you power up.
F12 selects on a Dell instant boot menu to select booting from CD-ROM, USB, etc rather than the BIOS options.
F8 goes to safe mode start up for windows, this must be done before the windows logo comes up (ie when it is a black screen).
Control - Alt -Delete Keys together can be used any time, after windows boots as it tells it to re-boot the computer, back to start up.
Jan 30, 2015 | Computers & Internet
When system is start key f2 and f12 not work
It is tricky to get the timing right. Press F2 repatedly just before the boot screen.
Nov 30, 2014 | Fujitsu LifeBook AH532 Notebook
When i click start button lap is work with show like as press F2, F12. then when i pressed any key the widows is start. how to solve this problem.
If you leave it, does it boot after 30Seconds or so? If it does the bios is set to standard boot. Setting up fast boot will remove the F2/F12 option.
Feb 09, 2014 | Acer Aspire One PC Notebook
Belta notebook usb/network booting windows system?
When you press the power button normally the boot options will display on the screen. Most times it is the F12 key to select the boot option. This is a temporary change only good for the current boot cycle.
Also most times the F2 key will get you into the Bios or System Setup where you can change the boot option and make it a permanent change.
Apr 29, 2012 | Computers & Internet
When you push the power button, the button turns green but the computer doesnt start up. The lights are on but there is nobody home, there is no sound indicating that the computer is starting up.
Remove the battery, and unplug the A/C adapter and hold down the power button, for 40 seconds.Soon your laptop will reset,and run well.Now you will install all the accessories and start.
Hope this helps you.
Feb 18, 2011 | Acer Aspire 9300 Notebook
My HPdv6910 has stopped working. I see the power light and battery light on but the hard-drive light is not on and the screen is blank even after I plugged it for more than an hour
reset boot formate to f12 but first lets get that blank screen off keep pushing f2 f2 f2 f2 thre or four times intell first page starts up then push f2 then use arrow keys on key board and at bottom booting log you shoud be set up on f2 change boot log f12 then pressf10 to save restart computer then when computer starts up push f12 then run windows under d: drive the it will ask you start windows run windows from disc or trouble shoot go to run windows after that you shoud be ok.
Feb 17, 2011 | HP Pavilion Dv6910us Notebook
My Acer Aspire 5520 wont power up when i tried to turn on. Battery getting power supply. orange light is glowing. but i pressed power button, it does not turn on. pls give me a solution. I removed my...
start your computer keep pushin f2 now youll see first use arrow keys go to were it says change reboot to f12 then restart your computer then it be set on a f12 press f12 then it will ask to run your windows go to that one.
Jan 27, 2011 | Acer Aspire 5520-5908 Notebook
Acer Aspire 4752, AS4752 Charger, Power Cord Logo
63 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
