Question about Goulds Pumps Goulds J10 - Convertible Jet Pump
Replace j10 goulds impeller - Goulds Pumps Goulds J10 - Convertible Jet Pump
How to replace impeller on guolds j10
What is the make and model of the "pump"?
Gould is a motor manufacturer.
The manufacturer of a pump, will use a third-party vendor like Gould, to provide them a motor for their pump. Gould is Century/Magnetek, which is now AO Smith.
BUT...
remove pump housing/volute covered, and access the impeller. Then on the back of the motor you should be able to access the shaft. Lock up the shaft so it does not spin, and then unthread the impeller. Some pumps, especially two speed pumps, will have a locking screw in the center of the impeller. That screw will be counter threaded or backwards thread. It keeps the impeller from spinning off the shaft during normal operation between high and low speeds.
again if we had more specific information, we would be able to assist you better.
Feb 09, 2015 | Pool & Spa
How do i remove impeller
Once you take off the front cover. You will see the impeller. Take of the rear cover and the shaft has a flat spot on it. You can hold it with a open ended wrench and spin off the impeller. It will be tight. There is no need to take it off unless it's broken.
Feb 09, 2015 | Goulds Pumps Goulds Pump JRD10 - 1Hp Jrd...
Dissemble pump motor from impeller
The impellers screw on. Hold motor shaft and unscrew.
Oct 08, 2014 | Goulds Pumps Goulds Centrifugal SS Pump &...
I HAVE PROBLEM REMOVING THE IMPELLER ON GOULDS
GOULD ..OH BOY HERE WE GO... YOU MUST HOLD THE SHAFT AT THE BACK OF THE MOTOR WITH A 7/16 TAKE THE CAPACITOR OFF (LOOK AT HOW WIRES ARE ROUTED ) OR 1/2 INCH WRENCH THEN UNSCREW IMPELLER..
>BEST TO BRING IT TO YOUR LOCAL POOL PUMP MOTOR REPAIR GUY OR PUMP REPAIR ,USE YOUR ZIP CODE IN YOUR SEARCH.. DON'T TRY TO REPAIR THIS IF YOU BREAK IT IT WILL COST YOU !
May 20, 2010 | Garden
How do I remove the impeller from a J5S pump?
most pumps arent made to be rebuilt and should just be replaced , its not worth fixing something and have it just go bad again.
Feb 09, 2010 | Goulds Pumps Goulds 1/3 Hp 115V 1 Phase...
Goulds Pumps Goulds J10 - Convertible Jet Pump Logo
50 people viewed this question
Top Goulds Pumps Plumbing Experts
Steve
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you a Goulds Pumps Plumbing Expert? Answer questions, earn points and help others
