Question about Dell Computers & Internet
My LCD monitor DELL E173FPc monitor turns off by itself after 1-2 seconds. The power button stays green. I found no indication of bulge or leaking capacitors. Can it still be a capacitor's problem? Thanks.
    Master:
  • 966 Answers
Does it say no signal? If yes, your CPU is not talking to monitor. Power on. If no, connect monitor to another CPU and see if it works.
Posted on Feb 09, 2014
Testimonial: "I did. The monitor does not work on another computer as well."
4 Suggested Answers
  • 32 Answers
SOURCE: Dell E173FPc 17" LCD Monitor Problem:
Although similar, this monitor and the associated repair is different than the "b" version. The link above is good to follow for finding out how to open your case but the actual repair is different. If you have minor soldering skills (really the de-soldering is the hard part) and can use a phillips screw driver you can make this repair.
I contacted Tom at a link I found on the "b" site and he sent me the typical components to fail for the "c" monitor. $20 and $1.35 for shipping. The site looks to be down now so I'm not sure if this is temporary or he's stopped selling parts. He is also willing to fix the board if you send it to him. Here's what you need to do:
Replace C922 and C923 with 1000uF 35V caps
Replace c924 and C925 with 470uF 25V caps
Re-solder L201 and L202 with fresh solder.
I did all of the above and the monitor works perfectly. When you take the monitor apart make sure you note where the blue and pink wires go (you'll know what I mean when you get to that stage). The connectors are identical and it would be easy to forget which way they were installed.
Posted on Aug 09, 2008
  • 1684 Answers
SOURCE: Dell E173FPc monitor worked fine yesterday.
The power supply in the unit has died. This is a very common problem with this series of monitor after 2-3 years of use. If you can solder then you should be able to do the repair yourself. Check out our step by step repair guide posted on our site at: www.ccl-la.com Our guide gives parts values and location information as well as how to open the unit up. If you don't feel like doing the repair we also offer repair services, see our web site for details.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Dec 31, 2009
Testimonial: "Excellent site"
  • 1684 Answers
SOURCE: my dell E173FPC monitor screen is black and
You have a unit with a failure in the backlight power supply. This is a common problem with LCD monitors after 2-3 years of use. Here is a link to an article we have posted that shows what needs to be done to repair the unit along with full parts list: http://www.ccl-la.com/blog/index.php/dell-e172fpc-e173fpc-repair/ If you can solder then you can do the repair yourself. If you don't care to do the repair we do offer a repair service for the unit, details can be found here: http://www.ccl-la.com/blog/index.php/service-request-form/
Buddy
Corporate Computer
www.ccl-la.com
Posted on Apr 29, 2010
Testimonial: "response was great and interesting.i am not a soldering professional although i believe its not difficult doing it.culd i get a solder iron alternativ"
Will a dell tft turn on with no source
Your monitor should turn on without a source and display the floating 'Dell - self-test Feature Check' message. If it does not, verify the power LED is on "GREEN" and indicating either power on / diagnostics mode or "Amber" power saving mode. If neither indication you have power problems. If these symptoms do not apply, shine a light on the sceen and see if there is a faint image. If this is true, you have backlight problems.
Nov 06, 2013 | Dell E173FPc 17" TFT LCD Flat Panel...
Dell e173fpc Display Issue
Check if the cable connected to your monitor and video card is fix and secure.. Check also if the video card is properly seated in the motherboard.... Try to check using other computer if the video card is working..
If the test is all ok.. then the last option will be to check the backlight inverter of your monitor....To do this, you need to bring the monitor to a credible technician to have it replace..
much appreciated if you could rate this help..thanks..
May 24, 2010 | Dell E173FPc 17" TFT LCD Flat Panel...
Montitor display turns off. Not power, green light stays on.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Dell monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Similar board: http://www.lcdrepair.us/SE178WFPcinverter-power.html
May 14, 2010 | Dell SE198WFP LCD Monitor
My dell E173FPC monitor screen is black and doesnot show for more than 2 seconds although the green power button is on.
Buddy
Corporate Computer
www.ccl-la.com
Apr 29, 2010 | Dell E173FPc 17" TFT LCD Flat Panel...
Dell E173FPc monitor worked fine yesterday. Today, the monitor only stays on for a split second and goes blank. The power light stays green. If we shut off the monitor using the power button and wait 10 to...
Buddy
Corporate Computer
www.ccl-la.com
Dec 31, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Dell E173FPC Monitor stays black and the Power switch cycles
You need to disasemble and check for dry or burn capacitors first then check for the transistors near the inversors.Good luck
Apr 03, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Dell E173FPc monitor. Screen is black, power button color cycles
First, verify the monitor is functional.
Monitor STFC (Self Test Feature Check)
Turn off the monitor
Plug the monitor power cord directly into the wall socket to remove any
surge protectors or APCs from the troubleshooting equation
Unplug the monitor video cable from the back of the computer
Turn on the monitor
The floating dialog box should appear on screen against a black background.
If the issue appears during the STFC, the monitor is defective.
What are the results please?
Feb 24, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
SCREEN BLANKS WITH POWER LIT GREEN
Look for bulged or leaking capacitors on the power supply board. If you can solder, you should be able to replace them with the same type and rating and that may just solve the problem. I've had luck with a couple of dozen monitors so far.
Mar 04, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Computers & Internet Logo
mukhtar21 shaikh
mukhtar21 shaikh
