Question about Ridgid Rd80702 3300 Psi 3.0 Gpm 7 Hp Subaru Ex21fi Ohc Gas Powered
Ridgid pressure washer motor runs choppy when choke is disengaged
The pressure washer is actually a 3300 psi and 2.8 gpm, however, starts right up when the choke is engaged, but when I turn the choke off (disengage it), the motor begins to run choppy and shake. In order to stop the shake, I need to engage the choke slightly until i reach the "sweet spot" when it stops shaking abruptly, which means that the joke is always on....any ideas?
  • Ridgid Master
  • 16,639 Answers
The choke reduces the air flow into the carb. If you are having problems with the choke off, it means that not enough fuel is getting into the engine and it is running lean. When you choke it, the reduced air flow causes the mixture to be correct and it runs fine.
Posted on Feb 09, 2014
Testimonial: "Thank you for your response! I will make sure the fuel lines are clear and I will clean the carb as well."
  • Brad Brown Feb 09, 2014
    The choke reduces the airflow through the carb. If it wont run without the choke being partially closed, the engine does not have enough fuel getting to it. It is running lean.
2 Suggested Answers
  • 6468 Answers
SOURCE: Gas is mixing with the oil on my ridgid pressure
the needle valve in the carb is not seating and gas over flows into the crank case
Posted on May 22, 2012
It starts easy and runs for about 10 minutes and cuts off. Have to wait 30-45 min. to restart with the same cutting off problem. Have always had a problem with restarting even when I shut it down on m
If your oil is too low or even a little bit low or if your machine is sitting on an incline, it will start and run until the oil is dispersed within the motor. Spreading the little amount of oil that is in there all around the inside of the motor would then reduce the amount of oil that is "sensed" by the "low-oil safety shutoff" switch, which would then shut down the engine. Its possible that your "low-oil sensor switch" is bad. You can test it by unplugging it. Just look for a wire that runs from your ignition switch or ignition coil to a sensor mounted on the engine block somewhere. Usually, it just unplugs right at the sensor. Simply unplug it and crank the engine and if it keeps running, then you know you have a bad switch (if you've topped off the oil, of course!).
Jul 07, 2014 | Ridgid Pressure Washer. 3000 psi 2.6 GPM...
My pressure washer just stopped while working, why?
Check your oil level. This machine has a "low oil shutoff" safety mechanism. If the oil is low it shuts down.
Jun 08, 2014 | Ridgid Pressure Washer. 3,300 psi 3 GPM...
Ridgid rd80702 will not start
Sounds like the float is stuck open. A few taps with a screwdriver handle on the fuel reservoir might fix the problem.
Apr 15, 2014 | Ridgid Rd80702 3300 Psi 3.0 Gpm 7 Hp...
What spark plug
Go here and input your model number to search for your manual. The number is in there.
https://www.ridgid.com/us/en/literature-search
Jan 02, 2014 | Ridgid Rd80903 3000 PSI 2.6 GPM 5.7 HP...
Engine stalls out while using pressure washer nozzle
Pump issue. There is not much you can do but try spaying silicone into pump output port to loosen up the bypass and load valves. If no glory you need a new pump.
Sep 21, 2013 | Ridgid 3300 Psi / 3.0 Gpm Gas Pressure...
Ridgid Rd80702 3300 Psi 3.0 Gpm 7 Hp Subaru Ex21fi Ohc Gas Powered Logo
242 people viewed this question
Top Ridgid Garden Experts
protojexxx
Lakeland Appliance...
Are you a Ridgid Garden Expert? Answer questions, earn points and help others
