Question about Mazda Miata Mx5 Nb T-Shirt
Mazda metro121 breaks down when hot - Mazda Miata Mx5 Nb T-Shirt
  • 35 Answers
You can buy new one :http://www.xcardiag.com/search/?q=Mazda+metro121 hope it can help you.
Posted on Mar 17, 2014
Climate control switch on 2005 mazda rx8 will not get hot air unless you wiggle it
Replace the switch. Th contacts on the inside are worn and bent from heat. Take it apart and try to fix it. I fix them and a lot of other switches. Some times a tab needs bent a little, sometimes they need cleaned with fine grit sandpaper. It's already broke, what are you going to do, break it more?
Jan 10, 2015 | 2005 Mazda RX-8
Mazda metro breaks down when hot
if the vehicle is overheating than its gonna do that .
Feb 09, 2014 | Mazda Miata Mx5 Nb T-Shirt
94 mazda will not start when hot
Your battery is going bad and will not handle the load when engine temperature is at normal or you have a bad bendix at your starter
Jul 16, 2012 | Mazda Cars & Trucks
Not getting any break peddle after I changed rottor pads and blead breaks
check the fluid in master cylinder if low could still have air in the brake lines also make sure that when bleeding brakes keep pressure on pedal until bleeder screw completley shut off
Jul 14, 2012 | Brakes for Mazda B4000
2001 mazda running hot, changed water pump, themerstat and themerstat case, still runs hot. Once the fans come on to coll the motor, it is so loud, could the fans motor be the problem?
Yes it could. Not turning fast enough will create an overheating problem. Also let it go long enough it could break and take out the radiator.
May 15, 2011 | 2001 Mazda Tribute
Mazda mpv 2000 no work reverse
Transmissions have a series of clutch plates, friction plates,bands,gears and solenoids located inside the transmission. As the vehicle moves forward, these plates operate similar to a clutch on a manual transmission, but using fluid pressure and momentum to do so. Usually these go bad due to lack of proper service intervals. If the fluid is not changed at recommended intervals, it breaks down, similar to engine oil,and causes the transmission to get hot and burn up these clutch plates and bands. Therefore you will get certain gears that will fail to engage. In your case, the reverse.
Oct 16, 2010 | 2000 Mazda MPV
Tempature gauge still goes to h
, ckeck the upper hose to see if it is hot , than ckeck the bottom hose , is it cool , the temp sould be about the same .if it is super hot on top and cold at the bottom hose , the raditor may be blocked, and the coolant is not flowing. you can try to flush the radiator . look to see if there metal shaving in the coolant . if there is the radiator is breaking down. this happen to me , my car would over heat change radiator car is a,ok easy fix . radiator barn .com
May 30, 2009 | 1996 Mazda 626
1994 mazda mx6 problems
It has a transmission problem. take it in for a scan. That should reveal the possible causes too.
Rate this
Mar 20, 2009 | 1994 Mazda MX-6
My front breaks jam up
This is the problem with hydraulic brakes line or the hydraulic brake system
is causing this problem in car ....
Good luck....
Feb 13, 2009 | 1998 Mazda Protege
My Mazda RX8 2004
I will never buy a mazda again. They have bad transmissions and engines. What is worse they use the same parts as Ford. How in the world do you combine a japanese and american parts into one engine? It keeps breaking down, thats what happens. I would ride it out since you are already gettin an engine but if you haven't purchased it, sell it and put that money towards another car, the dealer has used you like a gold digger.
Dec 07, 2008 | 2004 Mazda RX-8
Mazda Miata Mx5 Nb T-Shirt Logo
43 people viewed this question
Top Cafe Press Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Cafe Press Vehicle Part and Accessory Expert? Answer questions, earn points and help others
