Question about Genuine OEM 1997 1998 Expedition Navigator 4x4 Genuine Ford GEM Module
After starting my expedition a clicking noise comes on clicks like three times then stops
Noise coming from 4x4 switch area
What is the noise coming from in my 1998 expedition 4x4 grinds when i stop and put in park.
Can you be more specific as to when the noise happens ? Is it while you're coming to a complete stop and then changing gear ? Or only after you have already come to a stop. Are you in 4 wheel drive ? Or are you in 2 wheel drive ?
Nov 04, 2016 | Cars & Trucks
I have a 2000 ford expedition 4x4 the front right side makes a clicking noise while driving. Any ideas
Clicking Noise From Left Front Tire Area - F150online Forums
www.f150online.com/.../47713-clicking-noise-left-front-tire-area.html
Aug 11, 2001 - I have a clicking type noise comming from the left front tire. It does not ... I can really hear it when I'm driving beside a sound wall or the side of a building. ... the sound. (Yeah right!) ... Almost forgot: 1999 Ford F150 XLT Supercab 5.4 4X4. ... My 2000 4X4 had a ting ting noise coming from the left front wheel. Intermitent Grinding Noise on 2004 F150 4x4 - Page 5
Jan 15, 2010
Popping noise in front end.
Oct 26, 2009
Clicking noise at low speeds.
Aug 7, 2009
Annoying clicking sound in rear of truck?!?!
Jun 8, 2009
More results from www.f150online.com
Jan 05, 2016 | Ford Cars & Trucks
Grinding noise when its in nuetral with engine running
There are many possibilities that can cause car to make noise.
It's actually from where the noise is coming from. Front end or rear end. From engine area or from inside the steering or from brakes.
There is N-number of possibilities for the car to make grinding noise or any other kind of noise.
For step by step troubleshooting this problem, I suggest you to refer the help links mentioned below. Its a complete solution with proper explanation to identify the cause of problem: ------
Click the link below: -----
ABS light comes on and Car makes Grinding noise?
http://repairhelpcenter.blogspot.com/2012/01/abs-light-comes-on-and-car-makes.html
Car makes clicking noise?
http://howtobyme.blogspot.com/2011/11/car-makes-clicking-noise.html
Car makes whining noise like driving on rough pavement?
http://howtobyme.blogspot.com/2011/12/car-makes-whining-noise-like-driving-on.html
Chirping Noise From Car?
http://technoanswers.blogspot.com/2011/11/chirping-noise-from-car.html
What are the possibilities for Clicking noise in car?
http://technoanswers.blogspot.com/2011/11/what-are-possibilities-for-clicking.html
Squealing at start up on car?
http://technoanswers.blogspot.com/2012/01/squealing-at-start-up-on-car.html
Chirping sound coming from engine?
http://technoanswers.blogspot.in/2012/01/chirping-sound-coming-from-engine.html
Vehicle making Clunk Thump Thud noise?
http://howtobyme.blogspot.in/2012/03/vehicle-making-clunk-thump-thud-noise.html
4X4 Truck makes roaring noise in the front end?
http://schematicsdiagram.blogspot.com/2012/01/4x4-truck-makes-roaring-noise-in-front.html
Heater makes clicking noise under dash on Ford Explorer?
http://technoanswers.blogspot.in/2012/01/heater-makes-clicking-noise-under-dash.html
Clicking noise under dash and front defroster not working?
http://technoanswers.blogspot.com/2012/01/clicking-noise-under-dash-and-front.html
Car Brakes Making Noise?
http://repairhelpcenter.blogspot.com/2011/12/car-brakes-making-noise.html
Car Alternator making noise?
http://repairhelpcenter.blogspot.com/2011/11/car-alternator-making-noise.html
Car Alternator Bearing Makes Grinding noise?
http://repairhelpcenter.blogspot.com/2011/12/car-alternator-bearing-makes-grinding.html
Engine makes noise and Cooling Fan belt Breaks?
http://howtobyme.blogspot.com/2011/12/engine-makes-noise-and-cooling-fan-belt.html
Vehicle Makes Clicking Sound While Taking turns?
http://schematicsdiagram.blogspot.com/2011/12/vehicle-makes-clicking-sound-while.html
These will help.
Thanks.
Nov 28, 2012 | 1995 Isuzu Pickup
I have a 02 passat when I start If up it sound like a truck. What do you think it can be. Its not turbo it just started doing it
There is N-number of possibilities for the car to make loud truck noise or any other kind of noise.
These will help.
Thanks.
Nov 28, 2012 | Cars & Trucks
My eclipse spyder 03 started making that noise like a week ago on the drivers side ? Anybody help plz!!!!
There is N-number of possibilities for the car to make whining noise or any other kind of noise.
These will help.
Thanks.
Chevrolet k1500 whining noise
Its actually from where the noise is coming from.Front end or rear end.From engine area or from inside from steering or from breaks.
There are N-number of possibilities for the car to make whining noise or any other kind of noise.
For step by step troubleshooting these problem,i suggest you to refer the help links mentioned below.Its a complete solution with proper explanation to identify the cause of problem:------
Click the link below:-----
These will help.
Thanks.
Nov 28, 2012 | Chevrolet Silverado 1500 Cars & Trucks
Clicking noise coming from emergency/turn indicator switch
For DIY, try to replace the switch 2. Locate the flasher unit and see if the noises coming from there.
Feb 04, 2018 | 2004 Pontiac Grand Am
2000 FORD EXPEDITION WHEN THE CAS IS STARTED AND
Fords systems will still blow air even when off. does the clicking get quieter wehn off?
also, you can get it to stop blowing by turning on the recirculator. its a button with a car on it and a u-shapped arrow on the ac controls in dash. IF it stops then then something is in the housing and the fan is hitting it.
Oct 08, 2009 | 2000 Ford Expedition
Clicking sound coming from the driver's side rear by the tire
We just recently purchased a 2000 Expedition. It is wonderful shape but it has started making a ticking noise from under the hood , when you start it. Can anyone help us?248c23f.jpg
Dec 26, 2008 | 2000 Ford Expedition
Genuine OEM 1997 1998 Expedition Navigator 4x4 Genuine Ford GEM Module Logo
Top Genuine OEM Wine & Spirits Experts
Don Hart
Dave braun
Dave braun
guymark
Level 1 Expert
Are you a Genuine OEM Wine and Spirit Expert? Answer questions, earn points and help others
