Question about Hoover F5906-900 Upright Steam Vacuum
Brushes not spinning after change out
I just changed the brushes & now they wont spin! I changed around the spin speed & made sure they were in properley but I still get nothing.
  • 5dudlbugs Nov 17, 2007
    I am having the same problem with the brushes not spinning after I took them out to clean them. I know that I put them back in the right way. They just stopped spinning.
I got my brushes spinning by moving them while the unit was running. For mine it seems that they got stuck from sitting. The brushes move from the air driven motor unit. This works from the vacumm that is being put through the machine. I just spun the brushes while the unit was turned on. Don't get your fingers caught.
Posted on Dec 27, 2007
Hoover carpet cleaner brushes wont spin
First i would be checking for a mechanical restriction stopping the brushes from spinning like hair or similar wrapped around the brushes and jamming them, if all is clear it could be a belt broken or slipping, a stripped gear or an electrical fault, depends on what type of drive system the brushes on your particular vacuume cleaner uses. Hope this is helpful.
Aug 17, 2017 | Hoover Vacuums
The level selector light changes but not the levels. The brush stays on with the selector set on bare. What's the problem?
Make model? Maybe jammed make sure no hair is wrapped around the brushes by removing them (look up your model online I'm almost sure there is a how to video on YouTube) and clean it of all tightly twisted hair usually found where the brushes don't exist but on outer edges where you can't see between the plastic side of the vacuum and the brush roller (looks like rolling pin) where the bolt is that the brush spins on...hope that helps
Dec 11, 2014 | Vacuums
Ths spin scrub brushes wont spin
Be sure the speed switch is set to carpet. Also remember the brushes won't turn until the handle is tipped back. If this is not the problem, remove the brush and insert a flat screwdriver into the square hole the brush pin goes into, and be sure it turns ( there will be some resistance ). If it is seized up, the turbine will need replacement. There is also an air intake screen which must be kept clean. It is located behind a clear plastic cap on the upper front of the floor nozzle, just above the brush "spinner".
Feb 05, 2011 | Hoover SteamVac F5914-900 SpinScrub...
The brushes won't spin. I have removed and
On mine there is an air turbine that powers the brushes. There is a red screen that you squeeze and pull out to clean. Perhaps yours is clogged. If the screen is clear, perhaps the turbine has something binding it to keep it from turning. I hope this gets you on the path to repair your problem.
Oct 30, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Brushes won't turn and vacuum will not pick up sprayed cleaner
There's a Capt. Obvious fix to check before you go any farther. Like many vacuum cleaners, the brushes on the Bissell carpet cleaners, by design, only spin when the handle is not locked in the upright position, so be sure to plug it in, turn it on, and depress the foot pedal to lower the handle while watching the brushes one more time to be sure that the fix isn't that easy.
If the brushes still won't spin with the handle in the unlocked position, lift the handle back up into the locked position, power off and unplug the Bissell, and look down and see if either of the two belts that make the brushes spin are broken, as a broken belt, or a belt that's come off the track, is the next most likely problem. Both belts must be unbroken and in the right place for the roller brushes to spin.
These belts can be seen in the clear plastic pieces on either end of the roller brushes. If you're having trouble locating them, **with the Bissell unplugged so the brushes won't suddenly start spinning and hurt your hand**, try spinning the brushes with your fingers while watching for the belts. They're black, about the thickness of two quarters, and the bigger one of the two (on the left end of the roller brushes, as you face the front of the Bissell), is just big enough to fit around both roller brushes. The smaller belt, goes around the back roller brush on the right and to a smaller cog wheel behind it. If you see a broken belt, or a belt off the track, that's your problem.
Here's a video you can watch for free on Bissell's website that tells how to replace a belt. I'm sure the belts can be ordered online somewhere or found at some Bissell dealers or repair shops. Note, again, the two belts are different. If only one is broken, be sure to order the correct one.
http://cache.vendaria.com/vpop/VpopV6.html?ct=13&ctname=CT630X556D630X390&fw=630&fh=556&logo=49&fv=10&ap=vnd_bissell_change_belt_proheat_2x&purl=MAIN_bissell_change_belt_proheat_2x&iid=sbpgzLIuvIlJlJquLvumgwqKqvIqvv&bg=ffffff&nm=BZOpener&curl=&err=0&title=Bissell&tp
If the belts are intact and in the right place, does the metal cog wheel behind the roller brush right turn when the Bissell is on and the handle is dropped? If not, then the motor that turns that cog wheel must be burned out.
Jun 08, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
The brush on my Dyson DC-14 wont spin
hello, have you checked to make sure you have nothing wraped around the brushes ? also it sounds like your belt needs to be replaced.
Mar 31, 2009 | Dyson DC14 All floors Bagless Upright...
Brushes are not moving at all
There should be a switch to adjust the speed of the brushes. if it is off the brushes will not spin. The only time the brushes are supposed to spin is when the handle is tilted back, and the switch is on.
Mar 08, 2009 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Bissell carpet cleaner brushes won't turn
Make sure you have released the handle, as if you wanted to push the machine forward. If the handle is locked upright, the brushes do not spin.
If they still don't spin, you may have a broken belt. Look carefully at the base, on each side. As I face the front of mine, on the right side of the machine, a small belt goes around one brush and a small cog wheel. On the left side, a larger belt goes around both brushes. If either belt is broken, the brushes will not spin. This can happen if you let gunk build up inside the clear plastic side pieces or around or above the brushes. It's very important to constantly be cleaning your Bissell. The belts can be ordered online and replaced. See your owner's manual.
Sep 17, 2008 | Bissell Carpet Cleaner Powerbrush Deep...
Spin brushes spin freely on steam vac when not attached to cleaner indicator screen not dirty speed selector is in high position brushes are clean spin brush indicator when brushes attached to machine...
If this is a Hoover Steam vac, the turbine which drives the brushes is bad. If not a Hoover, then what is it, they are different, need brand and model number.
May 14, 2008 | Vacuums
My brushes are not turning. We checked the gear and it is turning, but brushes aren't
Take the brushroll out and see if it turns freely just by holding the end. Also make sure that the belt isn't stretched out. Also, before putting the head on the vac, you have to pick the belt up on the "finger" that's in the head. You can verify this by looking into the circle that's cut out of the metal. When the head is affixed to the vac, then turn the belt lifter back around to the proper position and all should be well. If you still need help, you may call us at 1-866-509-1952. Thanks
Apr 05, 2007 | Kirby G5 Bagged Upright Vacuum
Hoover F5906-900 Upright Steam Vacuum Logo
314 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
