Question about Dell Dimension Computers & Internet
My monitor DELL E173FPc turns off by itself after 1-2 seconds. Don't find any indication of bulge or leaking capacitors. Any recommendation? Thanks.
My LCD monitor DELL 17" E173FPc turns off by itself after 1-2 seconds. Don't find any indication of bulge or leaking capacitors. Any recommendation? Thanks.
    Problem Solver:
  • 12 Answers
Hmmmm. Try calling DELL Support.
Posted on Feb 09, 2014
alocenar
  • 293 Answers
SOURCE: LCD Monitor
is it connected to a PC? is the power source good 110v or 220v?
Posted on Mar 30, 2008
  • 214 Answers
SOURCE: I have a 17" Dell
Try the monitors connections first, then try the monitor on some other computer (try the other cables as well).
If the connections fix the problem - all OK.
If it works on some other computer - then it is not the monitor, more likely the video card. If this is the case - replace the video card.
If the monitor still does not work on another computer, then send it in for inspection and repair (is it still in Warranty?) or purchase a new one (expensive).
By the way, I don't know what you expect to do once you get inside the monitor (unless you are an Electronics Engineer by Trade which I doubt from your question).
Good luck, and please post a response so I can see if anything worked.
Posted on Apr 09, 2008
ehsan_bba
  • 112 Answers
SOURCE: LCD show right picture for 1 second when I turn on, then go black
you need to read the monitor manual . other wise you can contract the dealer.
Posted on Jan 22, 2009
SOURCE: Monitor keep going into "sleep" mode
try to reseat the memory modules and restart the computer and computer boots to normal mode/then go to power options in control panel and disable the sleep mode option for the hard disk
Posted on May 14, 2009
SOURCE: dell 4600 desk top, at boot up lite stays yellow, at same time the 17" dell monitor lite goes from green to yellow in about 2 seconds. thanks-randy
bought a new one. thanks! rg
Posted on May 18, 2009
I Have A Dell e173fpc Monitor And When I plug It In The Light Turns Green Then Orange Then Shuts Off Over And Over Again What Could It Be And How Do I Fix It?
Try it another PC first, otherwise it can be fail components such as caps, transistors, cold solder joints, etc.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Replacement board: http://www.lcdrepair.us
Oct 19, 2010 | Dell E173FPc 17" TFT LCD Flat Panel...
Hi', have a problem with my dell 17" monitor. 'tis a e173fpc. green light would come for a split second then off. opened up . saw nothing physically wrong. please advise.
http://s807.photobucket.com/albums/yy352/budm/Dell%20E173FPb/
Check the fuse, transistors, solder joints (use magnifier), caps. Or replace the board if the lamps are good after testing.
Oct 16, 2010 | Dell E173FP 17" LCD Monitor
Powers on then shuts right down again
<span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">If you are going to DIY and have proper tools and know safety precaution then please read on:</span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: <a href="http://s807.photobucket.com/home/budm/allalbums">http://s807.photobucket.com/home/budm/allalbums</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">Post back what you see inside so we can guide you further and it will help out other people in the future also.</span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><a href="http://en.wikipedia.org/wiki/Capacitor_plague">http://en.wikipedia.org/wiki/Capacitor_plague</a><span style="mso-tab-count: 1"> </span></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">Capacitors kit: <span style="mso-spacerun: yes"> </span><a href="http://lcdalternatives.auctivacommerce.com/">http://lcdalternatives.auctivacommerce.com/</a><span style="mso-spacerun: yes"> </span>he can make you a set of caps for you.</span><br />
Aug 26, 2010 | Dell E173FPc 17" TFT LCD Flat Panel...
Dell e173fpc Display Issue
Check if the cable connected to your monitor and video card is fix and secure.. Check also if the video card is properly seated in the motherboard.... Try to check using other computer if the video card is working..
If the test is all ok.. then the last option will be to check the backlight inverter of your monitor....To do this, you need to bring the monitor to a credible technician to have it replace..
much appreciated if you could rate this help..thanks..
May 24, 2010 | Dell E173FPc 17" TFT LCD Flat Panel...
The monitor shuts off and will not come back on, if we turn the screen off and back on it cuts off again, can this be fixed or am I just going to have to buy a new one.
Please read below and look at my pictures of Dell monitors if you want to DIY.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Apr 18, 2010 | Dell E173FPc 17" TFT LCD Flat Panel...
Dell E173FPC Monitor stays black and the Power switch cycles
You need to disasemble and check for dry or burn capacitors first then check for the transistors near the inversors.Good luck
Apr 03, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Dell E173FPc monitor. Screen is black, power button color cycles
First, verify the monitor is functional.
Monitor STFC (Self Test Feature Check)
Turn off the monitor
Plug the monitor power cord directly into the wall socket to remove any
surge protectors or APCs from the troubleshooting equation
Unplug the monitor video cable from the back of the computer
Turn on the monitor
The floating dialog box should appear on screen against a black background.
If the issue appears during the STFC, the monitor is defective.
What are the results please?
Feb 24, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Dell E173FPc
VGA turns on after a few seconds turns off
Jun 29, 2008 | Dell E173FPc 17" TFT LCD Flat Panel...
Computers & Internet Logo
29 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
