Question about Prepac Furniture DC-2428 - Monterey Tall Two Drawer Night Stand: WDC-2428 Nightstand White
Drawers slide in but don't fit on top of each other properly
How do I fix the drawers so they fit properly?
I want to reinstall a oven storage drawer on a electric LG oven
I don't think you need to remove a slide rail. They should slide out by hand and then set drawer back into it. usually have to tile drawer up some to start.
Nov 06, 2013 | Kitchen Ranges
My bottom freezer not closing properly
Pull both drawers completely out of their locations, clean off the slides that they each normally rest on. Clean off the surfaces beneath where they sit. Now, if they are both the same width and height, switch them and see if the problem is solved. If not, check the actual drawers to see if their sliding surfaces are cracked or covered with any kind of junk. You should be able to get everything to fit with these procedures.
Jan 12, 2013 | Maytag MFD2560HES Bottom Freezer French...
Custom cool drawer sliding mechanism broke
Most of the rail slides, when they break apart, cannot be repaired. It would be better to replace the complete assembly.
Aug 18, 2012 | Refrigerators
Top dishes are not cleaning
check that the top spray bar is not stuck and rotates freely and that the grommet in the back of the machine (where you slide the top drawer in) is not missing and that the drawer is locating into it properly
Oct 04, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
I need to replace the 3 button control panel which is one piece along the top of the draw many thanks wayne
Hi - this should help you out ..... enjoy.
9.1 Drawer Front Removal
9.1.1 Slide open drawer.
9.1.2 Locate draw pin on either side of the tub.
9.1.3 Using a sharp pair of long nose pliers or slip jaw pliers grasp the center dividing web of the pin and pull away from the tub to remove the pin. Support the drawer front with your hand while doing this. Note: The pin web is vertical.
9.1.4 With both pins removed the bottom of the drawer front can now be eased out slightly.
9.1.5 Now carefully pull the drawer front down to allow it to come free from the handle and top locating slots.
9.1.6 Carefully remove the earth wire from the tab on the drawer front. (if it is an integrated model you will also need to unplug the integrated badge from the isolating module)
9.1.7 Refit in reverse manner ensuring the drawer slides are right forward and the pin secures through the hook on the front end of the slide.
Note: When reinserting the pins make sure the dividing web is vertical.
9.2 Tub Removal
9.2.1 Open the drawer fully.
9.2.2 Depress the right-hand tub clip and push it back about 30mm (1 inch). Repeat for the left-hand side.
9.2.3 The tub may now be lifted up off the drawer runners.
9.2.4 Slide both runners back into the product.
9.2.5 Refit in reverse manner.
Drawer and LCD Display Removal
9.3.1 Remove the drawer front as per instructions in 9.1.
9.3.2 The handle fits onto a lip at the top of the tub and then slides from left to right to lock into place. Push the right-hand end of the handle to the left until it feels free then remove it out towards you.
9.3.3 Disconnect the six wire harness from the electronic controller to the LCD interface.
9.3.4 The handle may now be lifted clear. The LCD display is held in place by a spring tab on one
end and a clip in the centre. Use a small blade screwdriver to carefully release the tab and centre clip as shown. The LCD assembly can now be removed.
9.3.5 The wiring harness can now be unplugged from the LCD.
9.3.6 Refit in reverse manner.
Jul 07, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
Why would clothes conditioner not be flushed into machine ?
The siphon tube in the soap dispenser drawer is blocked with either a fungal/bacterial biofilm or with clogged conditioner.
Pull the drawer right pout of the machine as per the user manual to clean it. the cover over the back of the conditioner drawer will flip up if you pull it. The top half has a dead end tube which fits over a tube with an open end. Clean out every last trace of the (very likely) pink or black slimy film, a cotton bud (US=Q-Tip) is useful for cleaning out the upper dead-ended tube.
Reassemble and pop the drawer back in, and then pour water into the conditioner drawer; if you have done the job properly it should just drain out via the siphon as normal.
I hope that my speedy free reply means you'll be up and running again very quickly with your washing machine, please don't forget to take a moment to rate my answer.
Jun 26, 2011 | Bosch Classixx WFL 2066 Front Load Washer
When pushing the soap dispenser drawer it does not spring open any longer. Is there a way to fix this?
Re: Soap dispenser door not opening properly...(in case you still need to know)
You might want to use a small mirror (and flashlight) to see where the the spring assembly fits. Turn the rod facing towards you with the flat side up. It attaches at the rear, top left corner, near a small opening on the back wall (shaped liked the assembly). Fits into the "grooves". Apply enough pressure and you will feel it snap into place.
Dec 31, 2010 | Electrolux EIFLW55I Washer
Top drawer is hanging up on something
The only way to fix this is get the drawer out by
That way you can get access to the top seal - which is called the lid.
You will have to see how much of the lid is still left behind hanging on the top.
To remove lid
1 Remove tub assembly as per earlier instructions
2 On the right-hand side of the lid release the two tabs that clip the lid
to the yoke. Repeat for the left-hand side.
3 The lid is now free to slide out of the chassis.
4 Refit in the reverse manner taking care that the lid is fitted the
correct way around. The front is indicated on the top of the lid.
If the whole lid is intact then it may be a matter of fitting it back. Othwerwise you will get one from fisher and paykel parts
To fit the lid back you will have to check if the actuator yokes are not broken. In which case you will have to take these out and replace with the new one. (comes as part of lid kit if you buy it).
Remove Yoke
1 Remove the lid as per instructions above.
2 Release the lid actuator connecting arm from the bottom of the yoke
by squeezing the two tabs towards each other.
3 Slide the front of the yoke downwards at an angle until it moves out
of the track in the rear of the trim, and is clear of the chassis flange.
4 Refit in the reverse manner taking care that the yoke is the correct
way around.
When putting back you will need to align the lid actuator motors on both sides correctly so that the yoke moves the same distance when activated. Otherwise the lid will have a scew.
Hope all this helps. If unsure you will need to contact a technician.
Jun 01, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Sliding drawer in the top refrigerator section
hi i have the 700tc as well,,ok the best way to place the drawer,,,extend the 2 sliders all the way out,,there is one pin at the end of each slider and 1 hole on each side of the drawer lip which lays on the track ,,,the holes on the drawer must fall into the pins otherwise it will not close,,,so place the drawer on top of the slider ,,,what usually happens is the sliders tend to roll back into the housing of the fridge,,,so while the drawer is resting on the sliders reach under the lip of the drawer and pull each slider until the the holes of the drawer falls into the pins,,,when the drawer is seated in the pins it will close smooth,,,hope this helps
Feb 10, 2008 | Sub-Zero 700TC Bottom Freezer Refrigerator
Soap dispenser
I got my fixed last night. It was the "lid" for the softener despenser that was making the drawer stick. To remove it you need to take the top off of the washer. There is are two plastic "holders" on the back of the machine that hold the top onto the machine. Each of these "holders" have two screws, remove them, then remove the holder. You can then, with some effort, slide the top of the washer towards the back the then lift it off. You will then be able to see plastic tub that contains the drawer for the despensers. You can't remove this tub, but on the side facing the inside of the washer are a couple of tabs holding the top of the plastic down. You can gently release these tabs and pull up on the top slightly. This gave me enough "play" to then open the drawer. The problem, I believe, is that over time, that tub moves and makes it impossible for the drawer to open. With trial and error, I found that with removing the "lid" for the softener despenser, and completely closing the lid of the plastic tub, that that solved the problem.
Sep 03, 2007 | LG WM-2277HW Front Load Washer
Prepac Furniture DC-2428 - Monterey Tall Two Drawer Night Stand: WDC-2428 Nightstand White Logo
78 people viewed this question
Top Prepac Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Prepac Furniture Expert? Answer questions, earn points and help others
