Question about Samsung P2770H 27 in LCD TV
Power supply board - Samsung P2770H 27 in LCD TV
Power 48v check
Hi
Either the power supply is
not generating a proper 48
Volts or the controller board
is not detecting a 48 Volt
output from the power
supply board.
1. Make sure the power supply
board is correctly connected to
the controller board.
2. Power on the printer. If the
message appears, do the power
supply operational check (page
195). If the power supply fails the
check, replace it. If it passes the
check, go to the next step.
3. Power on the printer. If the
message appears, replace the
controller board. Record the
message and return it with the
defective board.
Aug 11, 2014 | Printronix Matrix Office Equipment &...
Panasonic tv model txp42s20b red light flashing 4times over & over
Hi Muhammad
4 blinks Power SOS P-Board
BOARDS DESCRIPTION: P MAIN Board = Power Supply (VT30 Models) - Non-serviceable. Must be replaced for service.
P SUB Board = Power Supply (VT30 Models) - Non-serviceable. Must be replaced for service.
P Board = Power Supply (All Other Models) P2 Board = Power Supply (All Other Models)
Hope this helps
Len...
Mar 12, 2014 | Televison & Video
Power light flashing green. No other light or sound. Per directions I found here, I bought a new power supply board. No change at all. Any other ideas?
Ur tv still having the same result a flashing LED power light indication,after u change the tv power supply board.Mean only one thing the main logic Tuner signal board it is also dead too.The Tuner signal board that the board where the tv incomming broadcasting signal wire plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish main logic Tuner signal board for the replacement.Tries out the old power supply board with the new refurbish main logic Tuner signal board too 50/50 the old power supply could be still functioning.If ur old power supply board still good and functioning,than return ur new bought refurbish power supply to the vendor u bought it from to get some money back.
Sep 14, 2011 | Televison & Video
Hi, I have Plasma TV Power Supply Board. The model of board is: LJ44-00144A PS-506-PH. The stand-by voltage 5Vstb works just fine. When I turn on the TV the Stand-by let in front of it comes blue like...
I have the same problem. As I see, here is dead sub PCB with microcontroller on board. Small PCB with 26 pins, mounted verticaly on main, big power supply board. It is not available as a spare part. You must buy complete power supply board LJ44-001444A, as I have done.
Aug 09, 2011 | Philips POWER SUPPLY (41644158) Power...
Morning, My Panasonic Viera TH-42PZ70B TV will not start up the red led is flash 7 times.
Either there is problem in your power supply or main board. There are many SMPS on the power supply board. First check the voltages coming out of the power supply & supplying to the main board. The voltages are printed on the power supply board. The top one is power supply & bottom one is main board.
sonsunny
Jun 17, 2011 | Panasonic Televison & Video
Will not power up. Tested from plug to power board. Power does not leave power board from any terminals.
The power supply board could very well be defective. I would also check the Zsus board and the Xsus boards. If either of these boards fail it could also cause the power supply board to fail.
You can unplug the connectors to the zsus board at the power supply and try to turn the set on. If it does turn on, the power supply board is ok. If not, the power supply is bad. If the power supply board is ok, undo the plug connectors that power the Xsus board and hook up the plug connectors to the Zsus board. Turn the set an and see if it stays on or shuts down. Part numbers should be on the boards. Zenith is really LG Corp. Their customer support number is 1800-243-0000.
Hope this helps,
Steve
Nov 25, 2010 | Zenith Z50PX2D 50 in. Plasma HDTV
My lg tv is flashing at the bottom and will not turn on
Unplug,replug the tv to reset it self?Not.Take the tv aparts.Power supply board have dead parts,call capacitors,check power supply board,that the board have a a/c power cord plug into it.That the power supply board.Know basic electronic's?Know how to do soldering,have tools like soldering iron and solders?Check power supply board for those dying capacitors parts,alway bulges up on it tops or puff up on it tops.These capacitors must be replaced in the power supply board.Now the tv shuold have stable ur power light and work.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Jul 04, 2010 | LG RU-52SZ61D 52" TV
Help
The Power Supply Board is listed below. Please note, there are 2 models with the same beginning number (PDP4294). Verify your model number before selecting the Power Supply Board as each board is different depending on the model number.
For PDP4294LV use:
Akai PDP4294LV Power Supply Board Replacement
For PDP4294LV1 use:
Akai PDP4294LV1 Power Supply Board Replacement
Apr 01, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Samsung P2770H 27 in LCD TV Logo
15 people viewed this question
Henry  Thomas
Henry Thomas
