Question about Dishwashers
Hobart lx30 Error code 35
5 Suggested Answers
  • 68 Answers
SOURCE: dishmachine won't fill
Your problem is as straightforward as your observation, the unit is not getting enough water flow.
First, if your DW water is hooked up with a braided stainless hose, there is usually a screen in the end of it, (check both ends). It gets clogged with debris and chokes off the water. Make sure the line is not kinked.
If that doesn't work, you are likely having trouble with your fill valve. It is under the front kick panel. It has a large castle like upper cap. It is common for debris in the water to make this valve malfunction. It isn't too difficult to open up without removing. Just watch how it is assembled. If you pay attention, it's easy. If you have a booster, the hoses are very brittle with age.
And otherwise, the fill valve may be bad. REMEMBER, verify your supply water flow where it connects to the machine first. Don't assume. You could have a pressure regulator or a line strainer that is part of your supply line. They do fail. But that's a plumber's fix, not a technician.
Posted on Jun 21, 2008
kermit854
  • 38 Answers
SOURCE: hobart lx30 E3 error
Error Code E3 relates to a problem with the fill. Specifically that the water level has not been recognized at the middle water sensor. This can be caused by a problem with the drain system as you describe, or by low water pressure to the machine (should be 15-25psi flow), or bad wire connection to this middle sensor.
Check for proper water pressure first (should be a gauge on the machine) during the fill. Then check / repair drain as needed. These will probably eliminate the problem
Posted on Aug 19, 2008
bigg t
  • 640 Answers
SOURCE: Hobart LX30 error code wrench & E5
What error code is displayed?e1,e2,e3,e4?I'm a hobart tech let me know.
Posted on Apr 12, 2009
  • 6 Answers
SOURCE: P1 error code on LX30 Hobart
This is a bad sump temperature probe. The unit will function, but will not heat nor display the wash water temperature.
This is a very easy fix. Order Hobart part number 328994 from your nearest Hobart parts dept.
Turn off and drain the unit. Kill the power to the unit at the circuit breaker. Remove the lower front cover. Locate the screw-in temperature probe at the front of the sump. Unplug the sensor from the wiring harness, remove with a 7/16" open end wrench. Screw in the new probe, using teflon tape of the threads, snuggly. It does not need to be super tight. Plug it into the harness, reinstall the front cover, turn the breaker back on, and start up the unit.
TURN THE BREAKER OFF AS EVEN WITH THE UNIT "OFF" THERE WILL BE 120 VOLTS PRESENT AT THE SUMP HEATER (yellow wires) DUE TO ONLY ONE LEG OF POWER BEING SWITCHED OFF!
Posted on Sep 12, 2009
Testimonial: "You were right! can you help mr with a P2 error code?"
Manufacture date hobart LX30 H. Serial 23-1044-007. ML 111 4354
If it is before Kitchen-Aid got involved, it is from the era before the 1986 buy-out by Whirlpool, so it is 30 years old at minimum!
Jul 12, 2016 | Hobart Dishwashers
E3 Error code on hobart lx30 dishwasher.
my dishwasher Hobart LX 30 will not shut off and displays 30
Jan 21, 2011 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Sep 04, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
E4 error after attempting to fill and get to temp
This is what I found for the E4 code...hope this helps...and thanks for rating my effort...The Fang.
Machine won't fill or won't fill high enough(LX18, LX30 display shows "E0," "E2," "E3," or "E4")
1.Low water pressure — check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
2.Make sure probes are clean.
3.No water pressure — main water supply valves may not be working.
4.Drain valve open - turn machine off to drain machine, then on. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the
OFF-ON procedure.
5. Delime machine.
Apr 28, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Apr 10, 2009 | Dishwashers
E-2 Error on LX30 Hobart Dishwasher
E-2 error is a fill problem. Water did not reach the lower probe within the time out. (innitial fill only
1- Is the bottom probe clean?
2- No fill water (check valve, hose,fill screen in end of hose, and fill source.)
3- low water pressure, should be 20 PSI flow.
4- Fuse 1FU blown.
5- Check wiring to fill valve.
6- Check relay board function.
Feb 15, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Detergent error
I'm a hobart tech---been away for awhile.What is the model lxih,lx30?Let me know if you still have a problem with it.
Jan 02, 2009 | Hobart 24 in. LXIC-5 Built-in Dishwasher
Hobart LX 30 P2 Error and unit overflowing!
Hi drogers77,
I'm not a Hobart technician, but here what I founded in my manual for the LX30 error message:
LX18 / LX30 display shows E0, E2, E3 or E4
1. Low water pressure - check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
2. Make sure probes are clean
3. No water pressure - main water supply valves may not be working
4. Drain valve open - turn machine OFF to drain machine, then ON. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the OFF-ON procedure. If problem persists, call your local Hobart Service Office.
5. Delime machine.
Hope it will help you.
pepsicrazy
Dec 27, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart lx30 E3 error
Jun 19, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart lx30 : rinse cycle
The rinse water in a LX30 is driven by water pressure. A solenoid valve, bottom front - gold body, opens up and allows the water to flow.
If you are referring to the rinse agent pump, there must be NO leaks in the tubing or the hose that runs through the pump. And if the unit has lost its prime, using your hand to "seal" it, and forcing water from the faucet into the line can prime it.
Good luck - Mike
May 13, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Dishwashers Logo
16 people viewed this question
Top Dishwashers Experts
Owen Barnes
