Question about TruTech T2000D TV
Set up Sony dvd player
Don't have original remotes to the television and cannot acquire an input through going through the menu
How to install a video machine if I don't have the tv remote?
I'm assuming by "video machine" you mean some kind of DVD player or Blu-ray player or something of the like. I will explain how to install a DVD player. There are two major cables: one sends the video to the TV and the other sends power to the DVD player. The power cord plugs into the wall with the other end attached to the DVD player. The video cable plugs into the TV. If you have an HD television, the video cable will have a male HDMI piece that plugs into the TV while the other end of the cable plugs into the DVD player. If you don't have an HDTV, then you will use an RCA cable which has three prongs: Yellow, White, and Red. These three colored male prongs plugs into the corresponding color coded holes in the TV. The other end goes into the DVD player. When you have everything plugged in correctly and the DVD player is on, all you have to do now is change the TV input. You will need the TV remote that came with your TV, or a universal remote that has been configured to work with your TV. Find a button on your remote that reads "Source" or "Input". This will cycle through the sources and inputs of your TV including AUX, VIDEO1, VIDEO2, etc. Keep going until you are on the correct input to see the DVD player menu. Good luck!
Jul 01, 2011 | Philips 42PFL5332D 42 in. LCD Television
How do you get to the auxillary channels or the channel where the DVD player or video games would go? I have a DVD player hooked up to the TV, but it only goes from channels 2-69 with no auxillary/video...
Do you have the original remote? If you do, you need to press the input button (on the left below 7 and above the DVD controls). The external device must be on before you scroll through the available inputs. Unfortunately, I'm not sure if the OnScreen Menu has an option to toggle the Input (since there is a Menu button on the TV it would work around the issue).
A substitute remote that should access all of the TV features including the Input is available here: http://www.remotes.com/remotes/servlet/rs?a=gmi&smodel=32V420T&brand_pn=RCA_32V420T&mode=large&uuid=12787350637590
I hope this helps.
Jul 10, 2010 | RCA 32V420T 32" TV
TV locked channel, TV won't allow up to go to
U can buy an original remote at website 1-800-Remotes Factory original.
Jan 20, 2010 | Proview PA-32JK1A 32 in. LCD Television
How do i get to video mode without original remote
you should have an input button. if so press the button until you get to the input that your dvr/vcr player is on. if you do not have a input button got to the menu button and you should be able to change the input thru the menu.
Jan 11, 2010 | Sanyo AVM-2759S 27" TV
Sony DA50 display reads UNLOCK. Will not play in 5.1 surround.
What type of DVD player do you have? I had the same problem with my Sony bdp-s1 bluray player. You might have to go into your menu on your player and set it up to decode the 5.1 signal.
Mar 02, 2009 | Sony RM-TP501 Remote Control
Hooking up & seeing a dvd player?
does the dvd have a coax output for coax antenna input on the tv? you can use that untill you can get the video input selection straight with the tv and a remote that supports rca's extra functions such as menu , tv/av button
or
also if there is a( wake-up) on/off timer in the tv menu , then you can also set it to come on with the video input instead of a tv station,set it a few minutes after the time it is when you set it( then just turn off the tv set after the time is set and you have exited the menu, then it will come on with the video input instead of a tv station)
otherwise you will need that remote that supports the video input selection on your tv
Jan 08, 2009 | RCA F20625 20" TV
I cannot figure out to switch input to use dvd player
I had a panasonic combo tv,,do you have the original remote,,,aux was in the middle of my remote,, maybe check ur menu,, good luck
Oct 05, 2008 | Panasonic Televison & Video
The input button
On some sets you can use the menu button to enter the menu and navigate to the page which shows what input is currently selected and change it there. If your set does not have that option, then you will need the remote to do it. I have found that on some universal remotes, the TV/VCR button switches the inputs on the TV when the remote is in the TV mode. If that button does not work on your remote for your set, and you have tried all possible codes for JVC TVs, then the only way to switch inputs is to invest a few dollars more and get an original remote from JVC or have the set repaired so that the input button on the TV functions again.
Jul 11, 2007 | JVC AV-27F702 27" TV
No Video
From the manual (search Google for CM27101S): Normally, your TV displays the signal coming through the antenna terminal. However, If you?ve connected another component to your TV(such as a VCR) using the Video/Audio input, you will want to be able to view the signal from the component. To do this, you will need to switch from the ? TV ? input to the ? Line1, Line2 ? Input, as follows: 1 With the TV on, press the MENU button twice, then ? Set-Up ? menu will appear. 2 Use the WCHVbuttons to select ? Input ?. 3 Press the CVOLB buttons to change from ? TV ? to ? Line1, Line 2 ?. 4 Wait 10 seconds, or press the MENU button to return to normal TV viewing.
Aug 07, 2006 | RCA F27676BC TV
TruTech T2000D TV Logo
16 people viewed this question
Top TruTech Televison & Video Experts
Radames Pagan
Radames Pagan
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
