Question about Advent 6552 Laptop
Small puff of smoke coming through the top right of the laptop
After turning it on, 3 seconds later a little bit of smoke came from the top right of the laptop. there was a smell of burning plastic but when i checked inside there was no burns anywhere. is it possible that the fan burnt out after 3 seconds?
  • Advent Master
  • 15,557 Answers
The fan usually wont fail in that manner, If it still works normally, you can go to www.almico.com and download a program called speed fan. It is free and it will tell you the temp of everything in that computer.
Posted on Feb 09, 2014
A small puff of smoke came from top right of laptop
Was it dust? Could be the power in socket/plug.
Feb 09, 2014 | Advent 6552 Laptop
Smoke coming steering column
is it puffs of smoke or like a vapor. does it smell like coolant
Sep 09, 2013 | Nissan Altima Cars & Trucks
Turned it on and after an hour I heard a sizzle and then a small black puff of smoke came out the back at the top right. I still get sound but the picture only comes on for less than a second and then the...
Sounds like the backlight or power supply for it failed. If the unit is out of warranty, try and open up the back and have a look for the area that burned up. Make sure it is unplugged. Damage to the power supply? or the inverter board? or the backlight panel itself?
Apr 12, 2010 | Westinghouse SK-32H240S Television
Overloaded grinder no longer turns after puff of smoke!
the shear pin, which goes through the grinder blade base and the motor shaft has 'sheared' off the protect the motor from overload. The metal bits of the pin need to be removed from both the grinder part and the shaft, a new one inserted. It is a 'pressed fit', so it will be hard to remove.
After the bits are removed, a common 'roll pin' of the proper diameter should be a suitable replacement
Feb 04, 2010 | DeLonghi DCG39 Electric Blades Grinder
While starting car little smock come for few mnt why ?
If you get a little puff of white/blue smoke just at start up , it probably means that one or more of your valve guide seals are worn.
While engine not running , a bit of oil gets in the cylinder , when it starts the oil burns off causing smoke. If it was smoking all the time , I would say rings are worn. If it is black smoke at start up , it indicates a fuel mixture problem. The valve guide seal problem may get worse over time.
On your post you say " for few mnt " if that means a few moments , than Valve guide seals , if you mean a few minutes , than more serious piston ring problem. Change your oil , and add a can of RESTORE , it will fill small scratches in cylinder walls , but will not fix badly worn rings.
Nov 09, 2009 | 2000 Mazda 626
Bmw 320d engine smoking
YOU MAY HAVE BLOCKED OIL RETURN HOLES,REMOVE VALVE COVER AND CH# THE 2 F/R
Aug 20, 2009 | 2002 BMW 3 Series
B&D MM850 starts then stops a few seconds later, then won't start
I was having a similar problem. I tried starting it up with the switch case open. I saw a very tiny puff of smoke come out of the switch. I replaced the switch and it was fine.
Apr 06, 2009 | Black & Decker 19" Electric Lawnhog...
The fan comes on but the burner won't kick on and then shuts off
Check your fuel line for cracks and also the air line. Most likely is the CAD flame sensor, easy to change and only 3 bucks or so. Might also want to check all of your filters. Mine was doing the same thing and it was the high heat limit control and the flame sensor.
Jan 22, 2009 | Reddy R155D Utility Heater
If I try to drag something into the dock it disappears...
Drag the file you are trying to put into the dock to the right of the silver line at the right of the dock. The file you want to delete, let it disappear in the 'puff of smoke' and then go into Macintosh HD and find the file and drag it over the trash icon. I hope it works!
Thanks, Logan
Jan 13, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Advent 6552 Laptop Logo
48 people viewed this question
Top Advent Computers & Internet Experts
Lee Durbin
Lee Durbin
Computer Links
Are you an Advent Computer and Internet Expert? Answer questions, earn points and help others
