Question about VXI Corporation Blueparrott B250-XT Bluetooth Headset
One wire broke going to earpeice ,parrot no work ,is there easy fix
  • 3 Answers
This is a new Bluetooth Parrot B250-XT
Posted on Feb 12, 2014
Parrot doesn't pair.
according to the wiring diagram the red wire goes to full time hot [+] and the orange wire connects to a switched hot [+]. See page 7 on this link: http://parrotcontact.parrot.com/website/user-guides/download-user-guides.php?pdf=ck3100/CK3100_Quick-start-guide_UK-FR-SP-DE-IT-NL-PT.pdf .
Aug 18, 2015 | Parrot SA Parrot Ck3100 Lcd Handsfree...
Speaker broke came off breaking both wires, where can i get this fixed? can i send it to blue parrot?
My guess is that the soldered piece broke? Does it look like it can be re-soldered? If so, do u have any friends who are good with a soldering iron? You can buy one for under $10 and fix it yourself, but if uncertain, check the following:
Radio Shack ... some have techs to repair in house stuff
Jewelers --- find one who is not busy at Christmas
Mr. Fix-It ... almost every mall has one.
You will most likely end up soldering the wires together to make contact. Keep the colors the same ... black to black ... white with a stripe to white witha stripe ... you get it? If you still have the female end of the wires that attached to the connectors you can test to see if it works by directly wiring to the female connector. If it works, then you can try a more permanent repair. If not, speakers are not a ton of money, unless they are huge AR15's or something nice!
I almost forgot the ABSOLUTE BEST place to take them ... go to any Automotive stereo installer ... most of them know how to solder and repair speakers, I would guess. Try that one! And if ALL of the above Fail! See if you have a ham radio seller in town and see if he'll do you a favor. Back also to Radio Shack or anyone who sells speakers.
Dec 12, 2014 | Parrot Blue B250xt Bluetooth Wireless...
I have a parrot ck3100 and had it installed and it worked well for a day or so then it stopped audio from the parrot. It still says connected but no sound is heard from any function. Can anyone help?
If the parrot kit sound comes from your car speakers and your radio is working then the problem may be a wire in one of the connectors that are plugged into the Parrot blue box, I have seen wires pushing out when the plug is inserted.
Feb 27, 2011 | Parrot SA Parrot Ck3100 Lcd Handsfree...
My Parrot CK3100 will not seem to switch off when the ignition is turned off and the car is locked. The display seems to remain on 24x7 and now seems to be draining the car's battery. Any idea how to...
Hi there, my Parrot CK3100 screen just says "Goodbye" how do I switch it back to the Parrot symbol, so I can pair it up to my Samsung Wave via bluetooth. My phone is connected to the device, but the divice is not connecting to my phone?
Jan 24, 2011 | Parrot SA Parrot Ck3100 Lcd Handsfree...
Will not connect
it sounds like it has been wired wrong, no signal is normally the result of the bad wiring or jump starting. you will need to have the software upgraded but it can only be done via update cable, i would go to parrot.com and find you nearest engineer, they will do this and check out the fitting.
Apr 27, 2010 | Parrot Hands-Free Car Kit with LCD Display...
My parrot will not automatically connect my mobile, it keeps saying memory full but it has no paired devices?
I had this problem. easiest way is to 'format' the kit by uploading the latest firmware. very easy to do with the parrot uploading software from the parrot website. simply go in to the settings, advanced settings. all the instructions are easily found on the Parrot.com website. it's also free.
Oct 31, 2009 | Parrot MINIKIT Bluetooth Hands-Free Kit...
Parrot CK3100 lcd control isn't working.
try pushing the wire into the bottom of the display, this comes loose easily and causes these problems.
Oct 21, 2009 | Parrot Ck3200 Ls - Color Cell Interface...
Wire broke right next to headphone jack; any easy way to fix?
if you are not handy, then no.
repair will require disassembly of the ear piece, splicing of the wire, and reassembly.
Sep 19, 2009 | Bose TRIPORT® Headphones
How do you fold lowrider headphones?
It's easy,
Step1: rotate the earpeices so that either the cushions face up or down
Step2: fold one side inwards by bending the rotating elboe inwards, this elboe is located one inch above the top of the cushion
Step3: now do the same for the other side
Step4: as you fold/rotate the second earpeice, do so in a way that this earpeice lies underneath or ontop of the first folded earpeice
Note: as you do step 4, you will notice that the middle of the top band starts to bend to accomodate the motion of this folding process
Add. Note: the mic may be sticking out at an odd angle by now, rotate it towards the rest of the mass that is now your folded headphones...... now they are ready for your pocket
Dec 26, 2008 | Skull Candy Lowrider Headphones
Parrot CK3000 Evolution
after a reset try to push the parrot in pairing with your phone.< for any G3 phone the below should work. The menu could be differnet on yours this is for a nokia G3 phone. Object Push: * From your phone go to MENU / COMMUNIC. / CONTACTS * Select the desired contact to send * Go to OPTIONS / SEND BUSINESS CARD / VIA BLUETOOTH / ALL CONTACT DATA * Phone will search for available bluetooth devices * Select from the list Parrot Product and press SELECT * wait until the contact is transferred. After contact is sent, it is neccessary to register "Contact's Name"
Aug 14, 2008 | Parrot Par Ck3000 Evolution Ck3000...
VXI Corporation Blueparrott B250-XT Bluetooth Headset Logo
165 people viewed this question
Top VXI Corporation Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a VXI Corporation Radio Communication Expert? Answer questions, earn points and help others
